[Cortex-M0技术交流] 新塘的NUC120的I2C中断出问题了,求解决
 楼主| oyljxilige 发表于 2012-4-13 10:06 | 显示全部楼层 |阅读模式
我用的nuc120的I2C作为从机只能发送和接收一个正确的数据,大于一个数据接受到主机的数据就不正确,主机用的是模拟的I2C,从机用的是自带的I2C,我用串口打印出主机信息,显示是主机在发送完第二个数据后没收到从机的应答 ,我看新塘的数据手册上有这样一段话file:///D:/QQ/Users/350744253/Image/pgkc6kavg0y%7Ddod2%7B%25tfdks.jpg
是不是他发送或接受到一个数据之后就不会发送AA应答了 ,
下面是我的I2C初始化和中断程序
void I2C_init(void)
   /* Set I2C I/O */
    DrvGPIO_InitFunction(E_FUNC_I2C0);
DrvI2C_Open(I2C_PORT0, 400000);
    DrvI2C_SetAddress( I2C_PORT0,0,Device_Addr>>1,0 );
    // 设置I2C 地址1,并将广播命令关闭(高七位为地址,最低一位为读写位)
    DrvI2C_Ctrl(I2C_PORT0, 0, 0, 0, 1);
    //设置为从机模式
    DrvI2C_EnableInt(I2C_PORT0);
    // 使能I2C_PORT
    DrvI2C_InstallCallback(I2C_PORT0, I2CFUNC, I2C0_Callback_Slave);
    //使能中断
void I2C0_Callback_Slave(uint32_t status)
//    Power_Off();
    if ((status == 0x60) || (status == 0x68))       /* SLA+W has been received and ACK has been returned */
    {//从机接收模式
        DataLen1 = 0;
        DrvI2C_Ctrl(I2C_PORT0, 0, 0, 1, 1);     //产生应答,清中断SI
    else if (status == 0x80)                        /* DATA has been received and ACK has been returned */
        Addr1[DataLen1++] = DrvI2C_ReadData(I2C_PORT0);
        if (DataLen1 == 2)
       aaa = 0;
//    DataLen1=2;
        if ((DataLen1 == 5))
       aaa = 1;
          DataLen1 = 0;
//   if(DataLen1==1||DataLen1==2)
        DrvI2C_Ctrl(I2C_PORT1, 0, 0, 1, 1);
//  else
//  DrvI2C_Ctrl(I2C_PORT1, 0, 0, 1, 0);
    else if ((status == 0xB0) || (status == 0xA8))  /* SLA+R has been received and ACK has been returned */
    { //从机传输模式
        DrvI2C_WriteData(I2C_PORT0, Addr2[DataLen2++]);
  if(DataLen2>=3)DataLen2=0;
    else if (status == 0xC0)                        /* DATA has been transmitted and NACK has been received */
    else if (status == 0xA0)                        /* STOP or Repeat START has been received */
        DataLen1 = 0;
    else
        printf("Status 0x%x is NOT processed\n", status);
 楼主| oyljxilige 发表于 2012-4-28 15:10 | 显示全部楼层
经过今天上午一上午仔细检查,问题终于解决了,我用的是PORT0,在中断收到数据时竟写成DrvI2C_Ctrl(I2C_PORT1, 0, 0, 1, 1);太粗心了,改为DrvI2C_Ctrl(I2C_PORT0, 0, 0, 1, 1);就ok了
我主机用的是中星微的816芯片模拟I2C,从机是nuc120,修改后经我验证,以上程序作为从机是完全可以收发数据
296895536 发表于 2013-3-21 16:43 | 显示全部楼层
顶个。 求个源码~:)
缥缈九哥 发表于 2013-3-22 20:20 | 显示全部楼层
新唐的BSP包源码。我用过很多例子,没有发现有任何问题。
lqc754 发表于 2014-9-25 15:23 | 显示全部楼层
学习!
