- /* Includes ------------------------------------------------------------------*/
- #include "LEDC.h"
- /* Private typedef -----------------------------------------------------------*/
- typedef struct
- char ch;
- uint8_t Data;
- } LED_CODING_TypeDef;
- /* Private define ------------------------------------------------------------*/
- /* Private macro -------------------------------------------------------------*/
- /* Private variables ---------------------------------------------------------*/
- MultiTimer LEDC_MultiTimer;
- const LED_CODING_TypeDef LED_CODE_Table[38] =
- {' ', 0x00},
- {'0', 0x3F},
- {'1', 0x06},
- {'2', 0x5B},
- {'3', 0x4F},
- {'4', 0x66},
- {'5', 0x6D},
- {'6', 0x7D},
- {'7', 0x07},
- {'8', 0x7F},
- {'9', 0x6F},
- {'A', 0x77},
- {'b', 0x7C},
- {'c', 0x58},
- {'C', 0x39},
- {'d', 0x5E},
- {'E', 0x79},
- {'F', 0x71},
- {'g', 0x6F},
- {'H', 0x76},
- {'h', 0x74},
- {'i', 0x04},
- {'I', 0x30},
- {'J', 0x1E},
- {'l', 0x30},
- {'L', 0x38},
- {'n', 0x54},
- {'o', 0x5C},
- {'O', 0x3F},
- {'P', 0x73},
- {'q', 0x67},
- {'r', 0x50},
- {'S', 0x6D},
- {'t', 0x78},
- {'u', 0x1C},
- {'U', 0x3E},
- {'y', 0x6E},
- {'-', 0x40},
- /* Private function prototypes -----------------------------------------------*/
- /* Private functions ---------------------------------------------------------*/
- /* Exported variables --------------------------------------------------------*/
- /* Exported function prototypes ----------------------------------------------*/
- * [url=home.php?mod=space&uid=247401]@brief[/url]
- * @param
- * @retval
- * [url=home.php?mod=space&uid=93590]@Attention[/url]
- uint8_t LEDC_GetCode(char ch)
- uint8_t SEGn[8] =
- 0x10, /* a :SEG4 */
- 0x80, /* b :SEG7 */
- 0x04, /* c :SEG2 */
- 0x20, /* d :SEG5 */
- 0x08, /* e :SEG3 */
- 0x01, /* f :SEG0 */
- 0x40, /* g :SEG6 */
- 0x02, /* dp:SEG1 */
- for(uint8_t i = 0; i < 38; i++)
- if(ch == LED_CODE_Table[i].ch)
- uint8_t Data = 0;
- uint8_t Temp = LED_CODE_Table[i].Data;
- for(uint8_t j = 0; j < 8; j++)
- if((Temp >> j) & 0x01) Data += SEGn[j];
- return Data;
- return 0x00;
- * @param
- * @retval
- void LEDC_MultiTimerCallback(MultiTimer *timer, void *userData)
- static uint8_t Index = 0;
- LEDC_SetData(4, LEDC_GetCode(LED_CODE_Table[Index].ch));
- LEDC_SetData(5, LEDC_GetCode(LED_CODE_Table[Index].ch));
- LEDC_SetData(6, LEDC_GetCode(LED_CODE_Table[Index].ch));
- LEDC_SetData(7, LEDC_GetCode(LED_CODE_Table[Index].ch));
- Index = (Index + 1) % 38;
- MultiTimerStart(&LEDC_MultiTimer, 250, LEDC_MultiTimerCallback, "LEDC");
- * @param
- * @retval
- void LEDC_Configuration(void)
- LEDC_InitTypeDef LEDC_InitStruct;
- CKCU_PeripClockConfig_TypeDef CKCUClock = {{0}};
- CKCUClock.Bit.LEDC = 1;
- CKCUClock.Bit.AFIO = 1;
- CKCU_PeripClockConfig(CKCUClock, ENABLE);
- /* SEG0~7 */
- AFIO_GPxConfig(GPIO_PA, AFIO_PIN_0, AFIO_FUN_LEDC);
- AFIO_GPxConfig(GPIO_PA, AFIO_PIN_1, AFIO_FUN_LEDC);
- AFIO_GPxConfig(GPIO_PA, AFIO_PIN_2, AFIO_FUN_LEDC);
- AFIO_GPxConfig(GPIO_PA, AFIO_PIN_3, AFIO_FUN_LEDC);
- AFIO_GPxConfig(GPIO_PD, AFIO_PIN_4, AFIO_FUN_LEDC);
- AFIO_GPxConfig(GPIO_PD, AFIO_PIN_5, AFIO_FUN_LEDC);
- AFIO_GPxConfig(GPIO_PD, AFIO_PIN_2, AFIO_FUN_LEDC);
- AFIO_GPxConfig(GPIO_PA, AFIO_PIN_7, AFIO_FUN_LEDC);
- /* COM0~4 */
- AFIO_GPxConfig(GPIO_PC, AFIO_PIN_4, AFIO_FUN_LEDC);
- AFIO_GPxConfig(GPIO_PC, AFIO_PIN_5, AFIO_FUN_LEDC);
- AFIO_GPxConfig(GPIO_PC, AFIO_PIN_6, AFIO_FUN_LEDC);
- AFIO_GPxConfig(GPIO_PC, AFIO_PIN_7, AFIO_FUN_LEDC);
- /* Frame = fCK_LED / (LEDC_DutyClockNumber * COM Number) */
- /* = 1600 / (8*4) = 50Hz */
- LEDC_InitStruct.LEDC_ClockSource = LEDC_SRC_LSI; /* LSI = 32Khz */
- LEDC_InitStruct.LEDC_ClockPrescaler = 20 - 1; /* fCK_LED = 32Khz / 20 = 1600 Hz */
- LEDC_InitStruct.LEDC_DutyClockNumber = LEDC_DTYNUM_8; /* Duty CLock Number = 8 Clock */
- LEDC_InitStruct.LEDC_COMxEN = LEDC_COM4EN | LEDC_COM5EN | LEDC_COM6EN | LEDC_COM7EN;
- /* Change the brightness, the parameter range is 0~Duty (CLock Number-1.) */
- /* 0: the brightest, 7: the darkest. */
- LEDC_InitStruct.LEDC_DeadTime = 0;
- LEDC_Init(&LEDC_InitStruct);
- /* Set the LEDC mode to COMMON_CATHODE. */
- LEDC_SetPolarityMode(LEDC_COM4POL | LEDC_COM5POL | LEDC_COM6POL | LEDC_COM7POL,
- LEDC_SEG0POL | LEDC_SEG1POL | LEDC_SEG2POL | LEDC_SEG3POL | LEDC_SEG4POL | LEDC_SEG5POL | LEDC_SEG6POL | LEDC_SEG7POL,
- COMMON_CATHODE);
- LEDC_IntConfig(ENABLE);
- NVIC_EnableIRQ(LEDC_IRQn);
- LEDC_Cmd(ENABLE);
- * @brief
- * @param
- * @retval
- * @attention
- void LEDC_IRQHandler(void)
- if(LEDC_GetFlagStatus())
- LEDC_ClearFlagStatus();
运行结果
软件工程源代码
Project.zip
(974.68 KB, 下载次数: 15)
