[WIFI模块] Mesh network/IPQ6010 IPQ5018 QCN9074 High power industrial wifi router Wallys
 楼主| lilywallys 发表于 2022-11-25 10:04 | 显示全部楼层 |阅读模式
Wireless Mesh network is a combination of wireless LAN and mobile AD hoc network, which is a new network architecture. It is one of the key technologies of the next generation wireless network and has been widely concerned and developed rapidly in recent years. To achieve ubiquitous high-speed Internet at low cost, the new generation of wireless
The development of Mesh network is imperative. The new generation of wireless Mesh networks aims to provide high performance and high reliability services. This paper briefly describes the principle, architecture and protocol of wireless Mesh network technology, analyzes its advantages, and looks forward to its future application prospects.
In recent years, wireless networks have developed rapidly, and many new wireless communication technologies and standards have emerged according to different applications and needs, and wireless mesh network is one of the new technologies that attract people's attention. WMN is a new networking technology, namely mesh network. Its topology structure is dynamic, with self-organizing and self-healing functions, that is, it can automatically form the network without human intervention, and each terminal can join or exit freely. In the process of information transmission, the information is continuously forwarded to the destination terminal through the multi-hop method. If this technology is applied to network the technologies for Wireless sensors, Wireless Fidelity (Wi-Fi), and worldwide inter-operability for microwave access (WiMAX), Can extend their application range, strengthen their function, thus constitute wireless sensor network, improve the coverage of wireless local area network, set up a MAN. Because of its broad application prospects, people are more and more concerned and applied to life and work.
1 WMN technology
1.1 Technical Principles
Wireless Mesh networks are low-power multihop systems. They process messages by passing packets from one node to another until they reach their destination. Unlike point-to-point nodes, which filter out all but their own packets, mesh nodes receive packets destined for other nodes and transmit them again. Each wireless Mesh network node can be used as the access terminal, also can have the function of routing and information forwarding, has a high degree of freedom. Wireless Mesh networks operate much like factors
Special network and provide multiple redundant communication paths from source to destination. If a
When the path stops working due to hardware failure or interference, the mesh network automatically changes the message
The routing of packets so that they cross an alternate path.
1.2 Network Structure
WMNs nodes come in two types: routers or clients, where the routers that make up the backbone of the network are less mobile, and they provide the mesh network with other networks (e.g
Internet, cellular network, IEEE802, sensor network) gateway and bridge functions; Clients can be stationary or mobile. Clients can network by themselves or together with routers in the mesh network.
1.3 Main Features
Wireless multi-hop. By reducing the transmission power of wireless nodes, the multi-hop transmission between nodes is realized, which can effectively reduce the energy consumption of nodes, reduce the interference between nodes, improve the spatial reuse degree of wireless channel, and thus improve the network capacity.
Self-organization and self-repair ability. The wireless mesh network is flexible, easy to configure, self-healing, network nodes are distributed in a network, and the network scalability is strong. It can realize multipoint to multipoint wireless communication.
Mobility. Depending on the type of node, minimum mobility is required for routing nodes and flexible mobility for client nodes.
Access mode. It can be connected to the Internet, cellular network, and sensor network.
Energy consumption mode. There is usually no strict limit on the energy consumption of routing nodes, while the client nodes are usually required to implement power-efficient protocols
Compatibility and interoperability. It is compatible with existing wireless networks and has strong interoperability.
Wallys routerboard DR6018 and DR5018 are good solution to work with mesh network.The mainly information for these 2 boards are as follow and welcome to visit our website for download their datasheet.
DR6018:
CPU:Qualcomm-Atheros IPQ6010
Openwrt supported
802.11ax support QCN9074 wifi6e card
QUECTEL RM500Q-GL supported
https://www.wallystech.com/Routerboard/DR6018V4-wifi6-Qualcomm-IPQ6010-IPQ6018-FAMILY-2T2R-2.5G-ETH-port-supporting-5G-celluar-Modem-802-11AX-MU-MIMO-OFDMA.html
DR5018:
CPU:Qualcomm-Atheros IPQ5018
BT5.1 supported
M.2 Card Slot
https://www.wallystech.com/Routerboard/DR5018-wifi6-Qualcomm-IPQ5018-2T2R-2.5G-ETH-port-802.11AX-MU-MIMO-OFDMA-supporting-QCN9074-wifi-card.html
Wallys Communications(Suzhou) Co.,Ltd,known as a specialist in researching and developing and producing of wireless communication products,have star product as Routerboard,Network Card,Industrial Wireless AP,Antenna etc,is one of the suppliers of the Facebook.
With the professional R&D teams which possess over 15 years experience,we could not only providing OEM/ODM/JDM services,but also have the ability to supporting customization service for you.From idea design to manufacture to put the product into market.
Email us by sales1@wallystech.com
Visit our website: https://www.wallystech.com/
