[WIFI模块] 802.11ax and 802.11ac which is better/Wallys 802.11ax series High power industrial wifi router IPQ6010 IPQ5018 QCN9074
 楼主| lilywallys 发表于 2022-11-30 09:48 | 显示全部楼层 |阅读模式
802.11ac and 802.11ax are different wireless (WiFi) technology standards that are present in WiFi routers or gateways.  WiFi and Internet capabilities are constantly evolving. Up until 2019, the most common wireless standard called for 802.11ac, also referred to as WiFi 5. However, in late 2019, 802.11ax (also known as WiFi 6) was launched, providing enhanced capabilities over its predecessor. These two WiFi standards are important to understand because they determine what devices you will need for your home network, which features they support, and the overall performance of your WiFi.
What is 802.11ac (WiFi 5)?
802.11ac is the 5th generation in WiFi standards and was introduced around 2013.  802.11ac is commonly referred to as WiFi 5 and was developed by the Wi-Fi Alliance to achieve gigabit speeds, meaning WiFi 5 could provide speeds up to 3.5 Gbps under optimal conditions.  In addition to faster speeds, WiFi 5 offered wider WiFi frequency channels that allowed wireless devices to send and receive more data, resulting in faster overall performance.  WiFi 5 (802.11ac) also introduced MU-MIMO technology that facilitated data to be sent to multiple devices simultaneously.Most notably, WiFi 5 was developed to only use the 5GHz wireless frequency, rather than both 2.4 GHz and 5 GHz frequencies.
What is 802.11ax (WiFi 6)?
802.11ax, or WiFi 6, is the latest WiFi standard and is the highest performing.  WiFi 6 is capable of speeds up to 9.6 Gbps which means its faster than WiFi 5, making it better for video streaming, online gaming and more high-bandwidth applications.  WiFi 6 offers more efficient data management for faster speeds and supports both the 2.4 GHz and 5 GHz frequencies for faster Internet across both frequency channels.  A new feature called Targeted Wake Time (TWT)allows your router to put the WiFi connection to sleepwhen not in use, saving the battery life of your smartphones, laptops and other connected devices until they are needed.  WiFi 6 has the power to higher number of connected devices and deliver more data to those devices, meaning you will have a much faster and more efficient Internet connection to all devices.
So, is WiFi 6 better than WiFi 5?
Yes, but with that yes comes an explanation as to WiFi 6s key benefits and what ultimately makes it better than WiFi 5. WiFi 6s key benefits include:
Next-generation WiFi technology
Faster speeds and performance
Can handle more connected devices without additional latency or lag
Better 2.4 GHz and 5 GHz spectrum performance
Increased MU-MIMO capacity from 4×4 (WiFi 5) to 8×8 (WiFi 6)
More capacity to deliver more data simultaneously to many connected devices
With any latest and greatest technology (wireless protocol included), increased capabilities are a given. WiFi 6 is no different. WiFi 6 offers multiple access channels, meaning one wireless channel can be divided into several different sub-channels, allowing more devices to be connected with the same fast speeds.  WiFi 6 is especially useful for areas with a large number of people who are connected to WiFi and/or Internet, such as at hotels, airports, and stadiums.
Additionally, WiFi 6 promises faster speeds and increased range across compatible devices, so lag-times and disrupted connectivity are things of the past. While WiFi 6 still uses 2.4 GHz and 5 GHz bands, the dual-band capacity helps more devices stream faster than they could on WiFi 5. Overall, WiFi 6 is faster, but it also is more efficient with its signal.
Are WiFi 5 devices compatible with WiFi 6 devices?
Even though WiFi 6 (802.11ax) has been around for over a year, it is still important to transition your WiFi 5 hardware to hardware that is compatible with WiFi 6. You will need a WiFi 6 router and modem to truly reap all the benefits of WiFi 6, regardless of how many WiFi 6 devices in your home the router is key.  If you are experiencing a slow Internet connection, consider a WiFi 6 router since it is the newest and highest performing WiFi standard on the market.
Wallys 802.11ax boards
Here I would like to introduce you wallys 802.11ax boards and cards.
They are:
DR6018 V4
DR6018C V01
DR6018-S V02
DR8072 V01
DR5018
DR9074-6E(PN02.7)
DR9074-5G(PN02.1)
DR9074-2.4G(PN01.1)
DR6018 V4
n Qualcomm-Atheros IPQ6010
n Quad-core ARM 64bit A53 @1.8GHz Processor
n 1GB DDRL3L System Memory
n 32MB NOR Flash, 256MB NAND Flash
n Supports Dynamic Frequency Selection (DFS)
n 2x2 On-board 2.4GHz radio, up to 573Mbps physical Data Rate
n 2x2 On-board 5GHz radio, up to 1201Mbps physical Data Rate
n Support: QUECTEL RM500Q-GL
n Support: QCN9074 WiFi 6E Card
DR6018C V01
DR6018-S V02
n DR6018-S V02 IPQ6010/IPQ6018/IPQ6000
n 8MB NOR Flash, 256MB NAND Flash
DR8072 V01
■ Qualcomm Atheros IPQ8072A AR Quad Core CPU
■ On-board 5GHz radio, up to 2475 Mbps physical data rate,On-board 2.4GHz radio, up to 1147Mbps physical data rate
■ 8 MB NOR Flash, 256MB NAND FlashNAND Flash can be up to 1GB as optional
■ Support 11ax TX Beamforming,Support 11ac/ax MU-MIMO DL and UL,Support OFDMA DL and UL
■ Supports Dynamic Frequency Selection (DFS)
■ DDR 1GB DDR3L(Support DDR3L can be up to 2GB as optional)
■ M.2 connector can support QCN9074 production
DR5018
n Dual-core ARM 64bit A53@1.0GHz Processor
n 512MB DDRL3L System Memory
n 4MB NOR Flash, 128MB NAND Flash
n 2x2 On-board 2.4GHz radio,up to 573Mbps physical Data Rate
n Support BT5.1
n M.2 Card Slot for 5G (QUECTEL RM 500Q-GL) ;
n M.2 Card Slot for QCN9074 WIFI 6E Card
DR9074-6E(PN02.7)
■ Qualcomm Atheros QCN9074
■ 6GHz, max 23dBm per chain, up to 4949Mbps
■ Single Band 6GHz 4x4 WiFi 6E (802.11ax)
■ 4 spatial streams (4SS)
■ M.2 E Key Interface
■ PCI Express 3.0 Interface
DR9074-5G(PN02.1)
■ 5GHz, max 23dBm per chain, up to 4949Mbps
■ Single Band 5GHz 4x4 WiFi 6 (802.11ax)
DR9074-2.4G(PN01.1)
■ 2.4GHz, max 23dBm per chain, up to 1147Mbps
■ Single Band 2.4GHz 4x4 WiFi 6 (802.11ax)
Wallys Communications(Suzhou) Co.,Ltd,known as a specialist in researching and developing and producing of wireless communication products,have star product as Routerboard,Network Card,Industrial Wireless AP,Antenna etc,is one of the suppliers of the Facebook.
With the professional R&D teams which possess over 15 years experience,we could not only providing OEM/ODM/JDM services,but also have the ability to supporting customization service for you.From idea design to manufacture to put the product into market.
For more information about our products,Email us by sales1@wallystech.com Or Visit our website:https://www.wallystech.com/
