[WIFI模块] IPQ6010 QCN9074 high power industrial wifi router support openWRT/Wallys 802.11ax boards DR6018CV01
1512|0
 楼主| lilywallys 发表于 2022-12-12 13:13 | 显示全部楼层 |阅读模式
802.11ac and 802.11ax are different wireless (WiFi) technology standards that are present in WiFi routers or gateways.WiFi and Internet capabilities are constantly evolving. Up until 2019, the most common wireless standard called for 802.11ac, also referred to as WiFi 5. However, in late 2019, 802.11ax (also known as WiFi 6) was launched, providing enhanced capabilities over its predecessor. These two WiFi standards are important to understand because they determine what devices you will need for your home network, which features they support, and the overall performance of your WiFi.
Here are wallys 802.11ax boards and cards.
DR6018 V4
DR6018C V01
DR6018-S V02
DR8072 V01
DR5018
DR9074-6E(PN02.7)
DR9074-5G(PN02.1)
DR9074-2.4G(PN01.1)
We have introduced DR6018V4 in previous article and today lets talk about the DR6018CV01.
DR6018C V01
This is a router board integrated with Qualcomm-Atheros IPQ6010 CPU,Processor with Quad-core ARM 64bit A53 @1.8GHz,and the System Memory is 1GB DDRL3L.32MB NOR Flash, 256MB NAND Flash,Supports Dynamic Frequency Selection (DFS),2x2 On-board 2.4GHz radio, up to 573Mbps physical Data Rate,2x2 On-board 5GHz radio, up to 1201Mbps physical Data Rate,support: QUECTEL RM500Q-GL,support: QCN9074 WiFi 6E Card.
Regard to the Absolute Maximum Rating of DR6018V4,well introduce from 4 perspectives parameters:Supply Voltage,Operating Temperature Range,Storage Temperature Range and Operating Humidity Range.
For the Supply Voltage,it is 24V~48V.
For the Operating Temperature Range,it is -40ºC to +70ºC.
For the Storage Temperature Range,it is -45ºC to +105ºC.
For the Operating Humidity Range,It is 5 to +95 (non-condensing)%.
Regard to the Hardware Specifications of DR6018V4,well introduce from 17 perspectives:CPU,CPU Frequency,system memory,ethernet port,NGFF Slot,SD card Slot,USB,POE,DC Jack,LED header,Serial Port,Wireless,Bluetooth,Nor Flash,Nand Flash,DDR and Dimension.
For the CPU,it is Qualcomm-Atheros IPQ6010.
For the CPU Frequency,it is Quad-core ARM 64 bit A53 @1.8 GHz processor.
For the System Memory,it is 1GB (2x 512MB) DDR3L 16-bit interface with 32-bit memory bus design.
For the Ethernet Port,It is 1 x 1Gbps Ethernet Ports & POE3 x 1Gbps Ethernet Ports , 1x 2.5Gbps Ethernet Port.
For the SFP Port,it has 1 x SFP port.(different from DR6018V4)
For the NGFF Slot,It is M.2 (NGFF) E KeySocket with MiniPCIe 3.0
For the SD Card Slot,It is 1x SD Card Slot
For the USB /header,It is 1x USB 2.0 Port
For the POE,It is 24V~48V passive POE/Active POE(Suport 802.3bt)
For the DC Jack,It is 24V power supply
For the LED header,It is FFC/FPC Connector
For the Serial Port,It is 1x Serial Port 4 Pin Connector
For the Wireless,It is On-board 2x2 2.4GHz MU-MIMO OFDMA 802.11b/802.11g/802.11n/802.11ax,max 23dBm per chain;On-board 2x2 5GHz MU-MIMO OFDMA 802.11a/n/ac/ax, max 20dBm per chain;4 x MMCX Connectors
For the Bluetooth,CSR8811 BLE 4.2(different from DR6018V4)
For the Nor Flash,It is 32MB(different from DR6018V4)
For the Nand Flash,It is 256MB
For the DDR,It is 256~512MB(different from DR6018V4)
For the Dimension,It is 185mm x 116mm.
Wallys Communications(Suzhou) Co.,Ltd,known as a specialist in researching and developing and producing of wireless communication products,have star product as Routerboard,Network Card,Industrial Wireless AP,Antenna etc,is one of the suppliers of the Facebook.
With the professional R&D teams which possess over 15 years experience,we could not only providing OEM/ODM/JDM services,but also have the ability to supporting customization service for you.From idea design to manufacture to put the product into market.
For more information,visit our website:https://www.wallystech.com/
