MSP430F5510头文件里定义
#define CM_0 (0*0x4000u) /* Capture mode: 0 - disabled */
#define CM_1 (1*0x4000u) /* Capture mode: 1 - pos. edge */
#define CM_2 (2*0x4000u) /* Capture mode: 1 - neg. edge */
#define CM_3 (3*0x4000u) /* Capture mode: 1 - both edges */
下边是我用MSP430F5510单片机做的捕获,我想捕获的是双沿,但是我先选的上升沿捕获,当上升沿捕获中断后再改为下降沿捕获,下降沿捕获中断后再改为上升沿捕获。
//初始化程序
void Init_TA(void)
TA0CCTL1 = CCIE + CM_1 + SCS + CAP; //对应CCR1使能,上升沿同步捕获
TA0CTL = TBSSEL__ACLK + MC_2 + TACLR + TAIE;//时钟源选择ACLK,连续数模式,清计数器
//中断程序
#pragma vector=TIMER0_A1_VECTOR
__interrupt void TIMER0_A1_ISR(void)
switch(TA0IV) //TA中断向量查询
case 2: //是捕获中断 2为CCR1捕获中断向量值
if (TA0CCTL1 & CM0) //上升沿捕获
TA0CCTL1 &=~ CM_1;
TA0CCTL1 |= CM_2; //改为下降沿捕获
start = TA0R;
if (TA0CCTL1 & CM1) //下降沿捕获
TA0CCTL1 &=~ CM_2;
TA0CCTL1 |= CM_1; //改为上升沿捕获
end = TA0R;
break;
case 14: //是溢出中断
overflow++; //溢出次数自加1
break;
default:
break;
//那么你捕获的脉宽就是time = (overflow * 65535 + end - start)*时钟周期;
