[PCB设计资料] Unleash next-level network performance with IPQ5018 and QNC6102
 楼主| wallysj 发表于 2023-3-16 15:55 | 显示全部楼层 |阅读模式
The combination of Wallys' RouterboardDR5018 and QCN6102 can provide a powerful and versatile networking solution forbusinesses and individuals alike.
Wallys' Routerboard DR5018 is a high-performancerouter that features a powerful 1.8GHz dual-core CPU RAM IPQ5018, and dual-bandWi-Fi, making it an excellent choice for handling demanding networking tasks.It also includes multiple Gigabit Ethernet ports, allowing for easy integrationwith other devices on the network.
The QCN6102, on the other hand, is ahigh-speed network switch that provides up to 10Gbps of bandwidth per port,making it an ideal choice for high-bandwidth applications such as videostreaming, large file transfers, and online gaming. It is a 2x2 MIMO (MultipleInput Multiple Output) LTE modem, which means it supports two antennas for bothreceiving and transmitting data.It also supports multiple VLANs, allowing foreasy segmentation of the network and enhanced security.
Together, these two devices can provide apowerful and versatile networking solution that can meet the needs of a widerange of businesses and individuals. Whether you're looking to build ahigh-speed home network or a robust corporate infrastructure, the combinationof Wallys' Routerboard DR5018 and QCN6102 can help you achieve your goals.
