[技术问答] MS51 的看门狗 配置问题
 楼主| jcky001 发表于 2023-4-6 10:48 | 显示全部楼层 |阅读模式
set_CHPCON_IAPEN;
        IAPAL = 0x04;
        IAPAH = 0x00;
        IAPFD = 0x0F;
        IAPCN = BYTE_PROGRAM_CONFIG;
        set_IAPUEN_CFUEN;
        set_IAPTRG_IAPGO;                            //trigger IAP
        _nop_();
        _nop_();
        while ((CHPCON & SET_BIT6) == SET_BIT6);     //check IAPFF (CHPCON.6)
        //------------------------死机,无限待----------------
        clr_IAPUEN_CFUEN;
        clr_CHPCON_IAPEN;
        set_CHPCON_SWRST;
        _nop_();
        _nop_();
    TA=0xAA;TA=0x55;WDCON|=0x07;                //Setting WDT prescale
    set_WDCON_WDCLR;                            //Clear WDT timer
    while((WDCON|~SET_BIT6)==0xFF);             //confirm WDT clear is ok before into power down mode
    set_WDCON_WDTR;
cr315 发表于 2023-4-7 10:00 | 显示全部楼层
代码上看不出来什么问题,可以找一下看门狗复位的例程试试看
