[无线通信] Wallys/QSDK IPQ6010/wifi mesh function supports qcn9074/qcn6024 M.2 E Key Interface
 楼主| Cindy@wallys 发表于 2023-4-19 17:00 | 显示全部楼层 |阅读模式
What does a WiFi mesh do?
A mesh network is a group of connectivity devices, such as Wi-Fi routers that act as a single network, so there are multiple sources of connectivity around your house instead of just a single router.
Mesh technology is smart and intuitive, letting you stay online even if one of your mesh nodes fails. You can skip signing into a new network every time you go upstairs and stay connected to a single sturdy network no matter where you are.
A mesh refers to rich interconnection among devices or nodes. Wireless mesh networks often consist of mesh clients, mesh routers and gateways. Mobility of nodes is less frequent. If nodes constantly or frequently move, the mesh spends more time updating routes than delivering data. In a wireless mesh network, topology tends to be more static, so that routes computation can converge and delivery of data to their destinations can occur. Hence, this is a low-mobility centralized form of wireless ad hoc network. Also, because it sometimes relies on static nodes to act as gateways, it is not a truly all-wireless ad hoc network.
Mesh clients are often laptops, cell phones, and other wireless devices. Mesh routers forward traffic to and from the gateways, which may or may not be connected to the Internet. The coverage area of all radio nodes working as a single network is sometimes called a mesh cloud. Access to this mesh cloud depends on the radio nodes working together to create a radio network. A mesh network is reliable and offers redundancy. When one node can no longer operate, the rest of the nodes can still communicate with each other, directly or through one or more intermediate nodes. Wireless mesh networks can self form and self heal. Wireless mesh networks work with different wireless technologies including 802.11, 802.15, 802.16, cellular technologies and need not be restricted to any one technology or protocol.
How to use wifi mesh and IPQ6010 chip perfectly
IPQ6010 is a high performance network processor widely used in WiFi mesh systems to achieve more stable and reliable wireless network coverage.
In WiFi mesh system, IPQ6010 chip can be used as the main control chip to control and manage the whole system. It can handle large amounts of data traffic and network traffic, and supports high-speed data transfer and seamless roaming between multiple devices.
At the same time, the IPQ6010 chip is highly integrated with multiple built-in network interfaces, including multiple Ethernet ports and multiple WiFi ports. These interfaces can be used to connect to other devices and networks for wider network coverage and higher data transmission speeds.
In addition, the IPQ6010 chip also has a variety of built-in network security functions, including encryption, identity authentication, access control, etc., to ensure the security and confidentiality of network data.
Therefore, in WiFi mesh system, the IPQ6010 chip can be used to achieve more efficient, stable and reliable wireless network coverage, while also having network security performance.
The IPQ6010 features a quad-core ARM Cortex-A53 processor that runs at up to 2.2 GHz. It also includes a dedicated dual-core network accelerator that provides hardware acceleration for a range of networking functions, including routing, bridging, and ***s.
One of the standout features of the IPQ6010 is its support for Wi-Fi 6E, the latest iteration of the Wi-Fi standard. Wi-Fi 6E operates in the 6 GHz frequency band, which is largely unoccupied by other wireless devices. This allows for faster speeds, lower latency, and more reliable connections than previous Wi-Fi standards.
With WiFi Mesh, the transmission distance and mobility of WiFi Mesh network will be greatly improved. Especially, it is compatible with WiFi function. Therefore, WiFi Mesh network provides great help to increase the transmission distance and mobility of wireless network and expand the application of wireless network. At the same time, the growth of mobile terminal devices also brings favorable factors for the popularity of WiFi Mesh network products. Traditional WiFi network and WiFi Mesh network can be mutually complementary and integrated in the product matrix.
For more products please visit: https://www.wallystech.com/product.html
Follow us in the Youtube: https://www.youtube.com/channel/UClmu7LBz_OWxe2VckkQr3tw
Email: sales2@wallystech.com
