[电源电路] AP3301 DC-DC降压IC 0.6-5.5V 高效率 低功耗 监控驱动应用
 楼主| ww18923706103 发表于 2023-4-25 16:41 | 显示全部楼层 |阅读模式
Features
Up to 95% Efficiency
Current Mode Operation for Excellent Line and Load Transient Response
700mA Output Current
Low Quiescent Current: 200μA
Output Voltage: 0.6V 5.5V
Automatic PWM/PFM Mode Switching
No Schottky Diode Required
Frequency Operation: 1.0MHz for Fixed Output Voltage and 1.4MHz for Adjustable Output Voltage Short-Circuit Protection
Shutdown Quiescent Current: <1μA
Low Profile TSOT/ SOT-23-5L Package (lead-free packaging is now available)
Applications
Digital cameras and MP3
Palmtop computers / PDAs
Cellular phones
Description
The AP3301 is high efficiency synchronous, PWM step-down DC/DC converters working under an input voltage range from 2.2V to 5.5V. This feature makes the AP3301 suitable for single Li-Lon battery-powered applications. 100% duty cycle capability extends battery life in portable devices, while the quiescent current is 200μA with no load, and drops to <1μA in shutdown. The internal synchronous switch is desired to increase efficiency without an external Schottky diode. The 1.0MHz/1.4MHz switching frequency allows the using of tiny, low profile inductors and ceramic capacitors, which minimized overall solution footprint. The AP3301 converters are available in the industry standard TSOT/SOT-23-5L power packages (or upon request).
Wireless handsets and DSL modems
Portable media players
PC cards
