[STM32G0] STM32G030Cx HAL库Flash擦除或编程操作出错的解决办法
 楼主| tpgf 发表于 2023-6-13 08:04 | 显示全部楼层 |阅读模式
STM32G0芯片对Flash操作容易出错,经常出现擦除失败或编程失败的情况,故有此记录。
STM32G0芯片LL库没有对Flash的操作需要自己实现,可借鉴HAL库。
STM32G0芯片对Flash的编程必须是双字(64位)。
一、宏定义及变量
#define FLASH_BASE                          (0x08000000UL)  /* FLASH base address */
#define FLASH_PAGE_SIZE                     (0x00000800UL)  /* FLASH Page Size, 2 KBytes */
#define SYS_ARGS_STORE_START_ADDER          (0x0800F800UL)  /* Store parameter start adress */
#define SYS_ARGS_TAB_SIZE             (20)
u64 SYS_ARGS_TAB[SYS_ARGS_TAB_SIZE] = {0};
#if ( SYS_ARGS_TAB_SIZE > (FLASH_PAGE_SIZE >> 3) )
    #error "System Argument Over Flash Page Size..."
#endif
二、获取页
/* 获取页 */
static u32 ulGetPage(u32 startAddr)
        return (startAddr - FLASH_BASE) / FLASH_PAGE_SIZE;;
三、写数据(双字)
/* 写数据(双字)*/
u8 vFlash_WriteData_DoubleWord(u32 startAddr, u64 * pDat, u16 num)
    FLASH_EraseInitTypeDef EraseInitStruct = {0};
    u32 Address = 0, PageError = 0;
    u8 i = 0, tryCount = 0;
    u8 res = 0;
    dprintf("Start Flash Erase Write...\r\n");
    EraseInitStruct.TypeErase = FLASH_TYPEERASE_PAGES;
    EraseInitStruct.Page           = ulGetPage(startAddr);
    EraseInitStruct.NbPages          = 1;
    EraseInitStruct.Banks          = FLASH_BANK_1;
FLASH_UNLOCK_TRY:
    /* 忙状态 */
    if(__HAL_FLASH_GET_FLAG(FLASH_FLAG_CFGBSY) != 0x00U)
        *(u32 *)(startAddr + 600) = 12323;/* 制造错误 */
        FLASH->SR = FLASH_SR_CLEAR;/* 清除所有错误标志 */
    /* 解锁 */
    if(HAL_FLASH_Unlock() != HAL_OK)
        tryCount++;
        if (tryCount < 5)
            /* 等待 */
            FLASH_WaitForLastOperation(50);
            /* 再次尝试解锁 */
            goto FLASH_UNLOCK_TRY;
        else
            dprintf("Flash Unlock Fail...\r\n");
            return 1;
    tryCount = 0;
FLASH_ERASE_TRY:
    /* 等待 */
    /* 擦除 */
    HAL_FLASHEx_Erase(&EraseInitStruct, &PageError);
    if(PageError != 0xFFFFFFFF)
        tryCount++;
        if (tryCount < 5)
            /* 再次尝试擦除 */
            goto FLASH_ERASE_TRY;
        else
            dprintf("Flash Erase Fail...\r\n");
            res = 2;
            goto FLASH_ERROR_EXIT;
    for (i = 0; i < num; ++i)
        while(tryCount < 5)
            /* 等待 */
            /* 双字编程 */
            if (HAL_FLASH_Program(FLASH_TYPEPROGRAM_DOUBLEWORD, startAddr, *(pDat + i)) == HAL_OK)
                startAddr += 8;
                tryCount   = 0;
                break;
            else
                tryCount++;
    if (tryCount)
        dprintf("Write Flash Fail...\r\n");
        res = 3;
    else
        dprintf("Write Flash OK...\r\n");
FLASH_ERROR_EXIT:
    HAL_FLASH_Lock();
    oPrintf("Exit Flash Opration...\r\n");
    return res;
四、调用验证
/* 调用验证 */
vFlash_WriteData_DoubleWord(SYS_ARGS_STORE_START_ADDER, SYS_ARGS_TAB, SYS_ARGS_TAB_SIZE);
版权声明:本文为CSDN博主「凌盛羽」的原创文章,遵循CC 4.0 BY-SA版权协议,转载请附上原文出处链接及本声明。
原文链接:https://blog.csdn.net/Ceosat/article/details/127027399
