[无线通信] Wallys/DR9574/Qualcomm-Atheros ipq9574/4*4 2.4G/support for some GPIOs .
 楼主| Cindy@wallys 发表于 2023-6-26 14:05 | 显示全部楼层 |阅读模式
DR9574  is  chipseted  with   Qualcomm-Atheros IPQ9574.
This is the main chipset used in the system.
Memory:
DDR: DDR4 2GB
Flash: 32MB Nor flash + 256MB Nand Flash
Wireless:
Frequency Range: 4x4 2.4G
This indicates support for 4x4 MIMO technology at the 2.4GHz frequency range.
Ethernet Ports:
2x10G: Two 10 Gigabit Ethernet ports
4x1G: Four 1 Gigabit Ethernet ports
Expansion Slots:
M.2 slots: Four M.2 slots
These slots can be used for expanding storage or adding additional functionality using M.2 modules.
LEDs: NA
There are no LED indicators specified.
Power:
Power Input: 12VDC
If Power over Ethernet (PoE) is required, it can be specified separately.
USB:
One USB 3.0 connector
Other Interfaces:
GPIOs: The chipset has some General Purpose Input/Output pins.
Additional features: If there are specific requirements for other interfaces or features, they can be specified separately.
Size:
Mainboard: 138mm x 204mm
Module: 62mm x 57mm
Power Consumption: NA
The power consumption information is not provided.
IPQ9574 — Quad-core Arm Cortex-A73 (up to 2.2GHz), Wi-Fi 7(802.11be); 16Gbps peak speed; 320MHz channel support; 4K QAM; OpenWrt & Linux Kernel 5.4 support; 14nm process
Built with 4x M.2 slots, the DR9574 board offers enhanced expansion capabilities, allowing users to integrate additional features or accessories, such as storage modules or wireless adapters, to meet their specific requirements.
In addition to its ethernet interfaces, the DR9574 offers support for some GPIOs (unspecified). The company mentioned that if other additional features are needed, customization options are available upon request (i.e. Power over Ethernet support).
