- #define LED_D4 12
- #define LED_D5 13
- #define BUTTON_BOOT 9
- volatile bool ledState =false;
- void timerISR()
- ledState = !ledState;
- digitalWrite(LED_D4, ledState);
- hw_timer_t* timer = NULL;
- // the setup function runs once when you press reset or power the board
- void setup()
- // initialize digital pin LED_BUILTIN as an output.
- pinMode(LED_D4, OUTPUT);
- pinMode(LED_D5, OUTPUT);
- digitalWrite(LED_D4, 0);
- digitalWrite(LED_D5, 0);
- // pinMode(BUTTON_BOOT, INPUT);
- timer = timerBegin(0, 80, true);
- timerAttachInterrupt(timer, &timerISR, true);
- timerAlarmWrite(timer, 1000000, true);
- timerAlarmEnable(timer);
- // the loop function runs over and over again forever
- void loop()
- // digitalWrite(LED_D4, HIGH); // turn the LED on (HIGH is the voltage level)
- // delay(1000); // wait for a second
- // digitalWrite(LED_D4, LOW); // turn the LED off by making the voltage LOW
- // if(digitalRead(BUTTON_BOOT)==0)
- // digitalWrite(LED_D5, 0);
- // else
- // digitalWrite(LED_D5, 1);
