- uint16 ecx_statecheck(ecx_contextt *context, uint16 slave, uint16 reqstate, int timeout)
- uint16 configadr, state, rval;
- ec_alstatust slstat;
- uint32_t timer2;
- if ( slave > *(context->slavecount) )
- return 0;
- timer2=<span style="background-color: yellow;">DrvTimer_InqCount();</span>
- configadr = context->slavelist[slave].configadr;
- do
- if (slave < 1)
- rval = 0;
- ecx_BRD(context->port, 0, ECT_REG_ALSTAT, sizeof(rval), &rval , EC_TIMEOUTRET);
- rval = etohs(rval);
- else
- slstat.alstatus = 0;
- slstat.alstatuscode = 0;
- ecx_FPRD(context->port, configadr, ECT_REG_ALSTAT, sizeof(slstat), &slstat, EC_TIMEOUTRET);
- rval = etohs(slstat.alstatus);
- context->slavelist[slave].ALstatuscode = etohs(slstat.alstatuscode);
- state = rval & 0x000f; /* read slave status */
- if (state != reqstate)
- <span style="background-color: sienna;"> DrvTimer_DelayUs(1000);</span>
- while ((state != reqstate) && ((<span style="background-color: yellow;">DrvTimer_InqCount()</span>-timer2)<timeout));
- context->slavelist[slave].state = rval;
- return state;
在nicdrv.c文件中修改网口发送和接收函数
- int ecx_outframe(ecx_portt *port, int idx, int stacknumber)
- int lp, rval;
- ec_stackT *stack;
- if (!stacknumber)
- stack = &(port->stack);
- lp = (*stack->txbuflength)[idx];
- MAC_Send((*stack->txbuf)[idx], lp);
- else
- stack = &(port->redport->stack);
- // dm9k_send_packet((*stack->txbuf)[idx], lp);
- rval =1;
- (*stack->rxbufstat)[idx] = EC_BUF_TX;
- return rval;
- int ecx_inframe(ecx_portt *port, int idx, int stacknumber)
- uint16 l;
- int rval;
- int idxf;
- ec_etherheadert *ehp;
- ec_comt *ecp;
- ec_stackT *stack;
- ec_bufT *rxbuf;
- // stack = &(port->stack);
- if (!stacknumber)
- // if(ETH_CheckFrameReceived()) //检测是否收到数据包
- gEtherCatPara.receiveLen=0;
- memset(gEtherCatPara.receiveBuffer, 0, sizeof(gEtherCatPara.receiveBuffer));
- // DrvETH_lwip_pkt_handle();
- memcpy((uint8*)(*stack->rxbuf)[idx], (uint8*)gEtherCatPara.receiveBuffer, gEtherCatPara.receiveLen);
- else
- gEtherCatPara.receiveLen_DM9000 = 0; /* Çå³ý½ÓÊյij¤¶È */
- memset(gEtherCatPara.receiveBuffer_DM9000, 0, sizeof(gEtherCatPara.receiveBuffer_DM9000));
- // if(dm9k_receive_packet())
- // memcpy((uint8*)(*stack->rxbuf)[idx], (uint8*)gEtherCatPara.receiveBuffer_DM9000, gEtherCatPara.receiveLen_DM9000);
- rval = EC_NOFRAME;
- rxbuf = &(*stack->rxbuf)[idx];
- /* check if requested index is already in buffer ? */
- if ((idx < EC_MAXBUF) && ((*stack->rxbufstat)[idx] == EC_BUF_RCVD))
- l = (*rxbuf)[0] + ((uint16)((*rxbuf)[1] & 0x0f) << 8);
- /* return WKC */
- rval = ((*rxbuf)[l] + ((uint16)(*rxbuf)[l + 1] << 8));
- /* mark as completed */
- (*stack->rxbufstat)[idx] = EC_BUF_COMPLETE;
- else
- /* non blocking call to retrieve frame from socket */
- if (ecx_recvpkt(port, stacknumber))
- rval = EC_OTHERFRAME;
- ehp =(ec_etherheadert*)(stack->tempbuf);
- /* check if it is an EtherCAT frame */
- if (ehp->etype == htons(ETH_P_ECAT))
- ecp =(ec_comt*)(&(*stack->tempbuf)[ETH_HEADERSIZE]);
- l = etohs(ecp->elength) & 0x0fff;
- idxf = ecp->index;
- /* found index equals reqested index ? */
- if (idxf == idx)
- /* yes, put it in the buffer array (strip ethernet header) */
- memcpy(rxbuf, &(*stack->tempbuf)[ETH_HEADERSIZE], (*stack->txbuflength)[idx] - ETH_HEADERSIZE);
- /* return WKC */
- l=(*stack->txbuflength)[idx] - ETH_HEADERSIZE;
- rval = ((*rxbuf)[l-2] + ((uint16)((*rxbuf)[l-1]) << 8));
- /* store MAC source word 1 for redundant routing info */
- (*stack->rxsa)[idx] = etohs(ehp->sa1);
- else
- /* check if index exist? */
- if (idxf < EC_MAXBUF)
- // rxbuf = &(*stack->rxbuf)[idxf];
- // /* put it in the buffer array (strip ethernet header) */
- // memcpy(rxbuf, &(*stack->tempbuf)[ETH_HEADERSIZE], (*stack->txbuflength)[idxf] - ETH_HEADERSIZE);
- // /* mark as received */
- // (*stack->rxbufstat)[idxf] = EC_BUF_RCVD;
- // (*stack->rxsa)[idxf] = etohs(ehp->sa1);
- (*stack->rxbufstat)[idxf] = EC_BUF_EMPTY;
- else
- /* strange things happend */
- return rval;
发送函数
- uint8_t MAC_Send(uint8_t *data, int length)
- ETH_BufferTypeDef Txbuffer;
- uint8_t i;
- ETH_TxPacketConfig TxPacketCfg;
- TxPacketCfg.ChecksumCtrl = ETH_CHECKSUM_IPHDR_INSERT;
- Txbuffer.buffer = data;
- Txbuffer.len = length;
- TxPacketCfg.Length = length;
- TxPacketCfg.TxBuffer = Txbuffer;
- HAL_ETH_Transmit_IT(ð_handle, &TxPacketCfg);
- // memcpy((u8*)(DMATxDescToSet->Buffer1Addr), (u8*)data, length);
- // /* Prepare transmit descriptors to give to DMA*/
- // i=ETH_Prepare_Transmit_Descriptors(length);
- return i;
根据使用ETH的THAL_ETH_Transmit_IT中断发送,将数据从网口中发出去,再将接收到的数据存储在gEtherCatPara.receiveBuffer_DM9000(之前是在DM9000的PHY上移植的),复制到内部缓存里memcpy((uint8*)(*stack->rxbuf)[idx], (uint8*)gEtherCatPara.receiveBuffer, gEtherCatPara.receiveLen);
至此,移植功能完成,下一部是对针对电机进行配置和控制。
