请问谁有合泰的32位的芯片使用USB读取SPI FLASH模拟成U盘在电脑端读取和写入文件吗?我现在按照例程中读写SD的方案写了一个读写flash的,但是只能在电脑端读文件,不能写入文件。现在是USB读写flash的函数,其中读函数是一次两个字节,所以读取长度需要少一半,即右移了一位
- u32 FLASHDISK_Write(u32 uId, u8 *pBuffer, u32 uBlockAddress, u32 uLength)
- u32 i;
- u32 uResult = TRUE;
- if (uId == FLASHDISK0_ID)
- uResult = TRUE;
- if (gDiskWriteStatus == FLASHDISK_IDLE)
- gDiskWriteStatus = FLASHDISK_WRITE;
- guWriteBufferOffset = 0;
- for (i = 0; i < uLength; i++)
- guWriteBuffer[guWriteBufferOffset + i] = *(pBuffer + i);
- guWriteBufferOffset += uLength;
- if (guWriteBufferOffset == FLASHDISK0_BlockSize)
- gDiskWriteStatus = FLASHDISK_IDLE;
- uBlockAddress = uBlockAddress<<12;
- SPI_FLASH_SectorErase(uBlockAddress);
- FATFS_SPI_FLASH_BufferWrite((u8 *)guWriteBuffer,uBlockAddress,FLASHDISK0_BlockSize);
- else
- uResult = FALSE;
- return uResult;
- u32 FLASHDISK_Read(u32 uId, u8 **pBuffer, u32 uBlockAddress, u32 uLength)
- if ((uBlockAddress / CACHE_CNT != uCachePage / CACHE_CNT) && (uCachePage != uBlockAddress))
- /* Calculate the cache start address which shall be aligned with the cache size. */
- uCachePage = (uBlockAddress / CACHE_CNT) * CACHE_CNT;
- QSPI_FLASH_BufferQuadReadByDMA((u16*)guReadBuffer, uCachePage, (FLASHISK_READ_BUFFER)>>1);
- if ((uCurrentBlock != uBlockAddress) || ((guReadBufferOffset % FLASHDISK0_BlockSize) == 0))
- uCurrentBlock = uBlockAddress;
- guReadBufferOffset = (uBlockAddress - uCachePage) * FLASHDISK0_BlockSize;
- *pBuffer = &(guReadBuffer[guReadBufferOffset]);
- guReadBufferOffset += BOT_MAX_PACKET_SIZE;
- else
- uResult = FALSE;
- return uResult;
