/****************撬动月球**************************/
 楼主| 34af9uc 发表于 2023-10-13 19:51 | 显示全部楼层 |阅读模式
/****************id:共同学习stm8*******************/
/****************qq:774145445**********************/
/****************20231012**ide0.98*****************/
//            pms150g_sot23-6
//           _______   _______
//      in1-|1 pa4  \_/  pa3 6|-out1
//          |2 gnd       vdd 5|
// feng-key-|3_pa6_______pa5_4|-out2
#include        "extern.h"
in1                        bit                pa.4;
out1                bit                pa.3;
out2                bit                pa.5;
key                        bit                pa.6;
feng                bit                pa.6;
void        FPPA0 (void)
.ADJUST_IC        SYSCLK=IHRC/4                //        SYSCLK=IHRC/4
$                in1                        in,ph;
$                out1                out,low;
$                out2                out,low;
$                key                        in,ph;
while (1)
.delay 10000;
if(in1 ==1){out1 =1; out2 =0;} else{out1 =0; out2 =1;}
if(key ==0)
        .delay 10000;
        if(key ==0)
                out1 =0; out2 =0;
                $        feng        out,low;
void        Interrupt (void)
        pushaf;
        if (Intrq.T16)
        {        //        T16 Trig
                //        User can add code
                Intrq.T16        =        0;
        popaf;
qiaodong.zip
5.19 KB, 下载次数: 1
319
