完善一下,补充上写入的
- #include "Wire.h"
- #define I2C_DEV_ADDR 0x50
- uint8_t read_fm24c02(uint8_t reg)
- uint8_t dat=0;
- Wire.beginTransmission(I2C_DEV_ADDR);
- Wire.write(reg);
- Wire.endTransmission();
- Wire.requestFrom(I2C_DEV_ADDR,1);
- if (Wire.available())
- dat = Wire.read(); // 读取数据字节
- return dat;
- void write_fm24c02(uint8_t reg,uint8_t dat)
- Wire.write(reg);
- Wire.write(dat);
- void setup()
- Serial.begin(115200);
- Wire.begin();
- write_fm24c02(11,0xF0);
- for(uint8_t i=0;i<0xFF;i++)
- Serial.print("REG[");Serial.print(i);Serial.print("]= 0x");Serial.println(read_fm24c02(i),HEX);
- void loop()
