main程序代码
- /* USER CODE BEGIN Header */
- * [url=home.php?mod=space&uid=288409]@file[/url] : main.c
- * [url=home.php?mod=space&uid=247401]@brief[/url] : Main program body
- * @attention
- * Copyright (c) 2023 STMicroelectronics.
- * All rights reserved.
- * This software is licensed under terms that can be found in the LICENSE file
- * in the root directory of this software component.
- * If no LICENSE file comes with this software, it is provided AS-IS.
- /* USER CODE END Header */
- /* Includes ------------------------------------------------------------------*/
- #include "main.h"
- #include "tim.h"
- #include "usart.h"
- #include "gpio.h"
- /* Private includes ----------------------------------------------------------*/
- /* USER CODE BEGIN Includes */
- #include "stdio.h"
- #include "string.h"
- /* USER CODE END Includes */
- /* Private typedef -----------------------------------------------------------*/
- /* USER CODE BEGIN PTD */
- /* USER CODE END PTD */
- /* Private define ------------------------------------------------------------*/
- /* USER CODE BEGIN PD */
- /* USER CODE END PD */
- /* Private macro -------------------------------------------------------------*/
- /* USER CODE BEGIN PM */
- /* USER CODE END PM */
- /* Private variables ---------------------------------------------------------*/
- /* USER CODE BEGIN PV */
- /* USER CODE END PV */
- /* Private function prototypes -----------------------------------------------*/
- void SystemClock_Config(void);
- /* USER CODE BEGIN PFP */
- /* USER CODE END PFP */
- /* Private user code ---------------------------------------------------------*/
- /* USER CODE BEGIN 0 */
- /* USER CODE END 0 */
- * @brief The application entry point.
- * @retval int
- int main(void)
- /* USER CODE BEGIN 1 */
- uint8_t USART_TX_Buff[32] = {0};
- uint32_t Duty, Duty_High, ARR, PWM_f;
- /* USER CODE END 1 */
- /* MCU Configuration--------------------------------------------------------*/
- /* Reset of all peripherals, Initializes the Flash interface and the Systick. */
- HAL_Init();
- /* USER CODE BEGIN Init */
- /* USER CODE END Init */
- /* Configure the system clock */
- SystemClock_Config();
- /* USER CODE BEGIN SysInit */
- /* USER CODE END SysInit */
- /* Initialize all configured peripherals */
- MX_GPIO_Init();
- MX_TIM2_Init();
- MX_TIM3_Init();
- MX_USART1_UART_Init();
- /* USER CODE BEGIN 2 */
- HAL_TIM_PWM_Start(&htim3, TIM_CHANNEL_1); //开启PWM输出通道:PA6
- // TIM3->ARR = 1000-1;//自动重装载值
- TIM3->CCR1 = 300;//捕获/比较计数值,PWM占空比5000/1000=50% f=1MHz/1000=1KHz
- TIM2->PSC = 36 - 1; //预分频;f=2MHz
- HAL_TIM_IC_Start(&htim2, TIM_CHANNEL_1); //开启输入捕获上升沿:PA0
- HAL_TIM_IC_Start(&htim2, TIM_CHANNEL_2); //开启输入捕获下降沿:PA0
- /* USER CODE END 2 */
- /* Infinite loop */
- /* USER CODE BEGIN WHILE */
- while(1)
- /* USER CODE END WHILE */
- /* USER CODE BEGIN 3 */
- HAL_Delay(1000);
- ARR = (TIM2->CCR1) + 1; //捕获从上一个上升沿开始到下一个上升沿结束的计数值,也就是一个完整周期的计数值
- // ARR = HAL_TIM_ReadCapturedValue(&htim2, TIM_CHANNEL_1) + 1;//同上
- Duty_High = (TIM2->CCR2) + 1; //捕获从上一个上升沿开始到下降沿之间的计数值,也就是高电平计数值
- //Duty_High = HAL_TIM_ReadCapturedValue(&htim2, TIM_CHANNEL_2) + 1;//同上
- //f = f/psc=1000 000
- //计一个数的时间T:1/f
- //PWM_f = ARR/f
- PWM_f = 2000/ARR;//KHz, 1/ARR*(T)= 1/ARR*(1/f)= f/ARR
- Duty = Duty_High * 100 / ARR;
- sprintf((char*)USART_TX_Buff, "PWM_f:%dKHz,ARR:%d,Duty_High:%d,Duty:%d%%", PWM_f, ARR, Duty_High, Duty); //打印输入捕获总计数值,高电平计数值
- printf("%s \n", USART_TX_Buff);
- memset((char*)USART_TX_Buff, '\0', strlen((char*)USART_TX_Buff)); //清空数组
- /* USER CODE END 3 */
- * @brief System Clock Configuration
- * @retval None
- RCC_OscInitTypeDef RCC_OscInitStruct = {0};
- RCC_ClkInitTypeDef RCC_ClkInitStruct = {0};
- /** Initializes the RCC Oscillators according to the specified parameters
- * in the RCC_OscInitTypeDef structure.
- RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSE;
- RCC_OscInitStruct.HSEState = RCC_HSE_ON;
- RCC_OscInitStruct.HSEPredivValue = RCC_HSE_PREDIV_DIV1;
- RCC_OscInitStruct.HSIState = RCC_HSI_ON;
- RCC_OscInitStruct.PLL.PLLState = RCC_PLL_ON;
- RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSE;
- RCC_OscInitStruct.PLL.PLLMUL = RCC_PLL_MUL9;
- if(HAL_RCC_OscConfig(&RCC_OscInitStruct) != HAL_OK)
- Error_Handler();
- /** Initializes the CPU, AHB and APB buses clocks
- RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_HCLK | RCC_CLOCKTYPE_SYSCLK
- | RCC_CLOCKTYPE_PCLK1 | RCC_CLOCKTYPE_PCLK2;
- RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_PLLCLK;
- RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1;
- RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV2;
- RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV1;
- if(HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_2) != HAL_OK)
- Error_Handler();
- /* USER CODE BEGIN 4 */
- /* USER CODE END 4 */
- * @brief This function is executed in case of error occurrence.
- * @retval None
- void Error_Handler(void)
- /* USER CODE BEGIN Error_Handler_Debug */
- /* User can add his own implementation to report the HAL error return state */
- __disable_irq();
- while(1)
- /* USER CODE END Error_Handler_Debug */
- #ifdef USE_FULL_ASSERT
- * @brief Reports the name of the source file and the source line number
- * where the assert_param error has occurred.
- * @param file: pointer to the source file name
- * @param line: assert_param error line source number
- * @retval None
- void assert_failed(uint8_t* file, uint32_t line)
- /* USER CODE BEGIN 6 */
- /* User can add his own implementation to report the file name and line number,
- ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
- /* USER CODE END 6 */
- #endif /* USE_FULL_ASSERT */
