N32G430与STM32F407 SPI通信问题
 楼主| DaveMa 发表于 2024-1-5 09:45 | 显示全部楼层 |阅读模式
用STM32F407作为主机,N32G430作为从机,主机发送一个8位数据,从机通过SPI2接收并存到变量rec里。目前主机信号发送正常,从机程序每次都跑死在 while (SPI_I2S_Flag_Status_Get(SPI_SLAVE, SPI_I2S_FLAG_RNE) == RESET)这一步。查了用户手册说这个标志位会在接收数据后硬件清除,不知道怎么回事。贴出部分程序,求大神解答qwq。
    SPI_Initializes_Structure(&SPI_InitStructure);
    SPI_InitStructure.DataDirection = SPI_DIR_DOUBLELINE_FULLDUPLEX;
    SPI_InitStructure.SpiMode       = SPI_MODE_SLAVE;
    SPI_InitStructure.DataLen       = SPI_DATA_SIZE_8BITS;
    SPI_InitStructure.CLKPOL        = SPI_CLKPOL_LOW;
    SPI_InitStructure.CLKPHA        = SPI_CLKPHA_FIRST_EDGE;
    SPI_InitStructure.NSS           = SPI_NSS_SOFT;
    /* It is recommended that the SPI master mode of the C version chips should not exceed 18MHz */
    SPI_InitStructure.BaudRatePres  = SPI_BR_PRESCALER_8;
    SPI_InitStructure.FirstBit      = SPI_FB_MSB;
    SPI_InitStructure.CRCPoly       = 7;
    SPI_Initializes(SPI2, &SPI_InitStructure);
    SPI_Set_Nss_Level(SPI2, SPI_NSS_LOW);
    SPI_CRC_Enable(SPI_SLAVE);
    SPI_ON(SPI_SLAVE);
   while (1)
        rec = SPI_I2S_Data_Get(SPI_SLAVE);
