安装官方的软件Embedded Builder出个教程嘛
 楼主| lichenglong 发表于 2024-2-27 14:42 | 显示全部楼层 |阅读模式
A Java Runtime Environment (RE) or Java Development Kit (UDKmust be available in order to run Embedded Builder. No Java virtuamachinewas found after searching the following locations:E:\mi\EmbeddedBuilder v1.3.5.21587EmbeddedBuilder jre\binVjavaw.ex
avaw.exe in your current PATH
