CCU
介绍 RTOS 中CCU 驱动的接口及使用方法,为 CCU 的使用者提供参考。
模块介绍
CCU 驱动主要实现设备驱动的底层细节,并为上层提供一套标准的API 接口以供使用。
模块配置
其menuconfig 的配置如下:
Kernel Setup --->
Drivers Setup --->
SoC HAL Drivers --->
CCMU devices --->
[*] enable ccmu-ng driver
[*] enbale ccmu-ng hal APIs Test command
源码结构
│ common_ccmu.h
│ hal_clk.c
│ hal_reset.c
│ Kconfig
│ Makefile
│ platform_ccmu.h
│ platform_rst.h
├─sunxi
│ │ clk.c
│ │ clk.h
│ │ clk_factors.c
│ │ clk_factors.h
│ │ clk_periph.c
│ │ clk_periph.h
│ │ Makefile
│ │ platform_clk.h
│ └─sun8iw21p1 # sun8iw21p1平台实现(老平台,目前使用ng驱动)
│ clk_sun8iw21.c
│ clk_sun8iw21.h
│ Makefile
└─sunxi-ng # sunxi-ng 驱动实现
ccu-sun20iw2-aon.c
ccu-sun20iw2-aon.h
ccu-sun20iw2-r.c
ccu-sun20iw2-r.h
ccu-sun20iw2.c
ccu-sun20iw2.h
ccu.c
ccu.h
ccu_common.c
ccu_common.h
ccu_div.c
ccu_div.h
ccu_frac.c
ccu_frac.h
ccu_gate.c
ccu_gate.h
ccu_mp.c
ccu_mp.h
ccu_mult.c
ccu_mult.h
ccu_mux.c
ccu_mux.h
ccu_nk.c
ccu_nk.h
ccu_nkm.c
ccu_nkm.h
ccu_nkmp.c
ccu_nkmp.h
ccu_nm.c
ccu_nm.h
ccu_phase.c
ccu_phase.h
ccu_reset.c
ccu_reset.h
ccu_sdm.c
ccu_sdm.h
clk-divider.c
clk-fixed-factor.c
clk-fixed-rate.c
clk-fixed-rate.h
clk.c
clk.h
Makefile
rst-sun20iw2-aon.h
rst-sun20iw2-r.h
rst-sun20iw2.h
type.h
模块接口说明
头文件
#include <hal_clk.h>
#include <hal_reset.h>
#include <ccmu/common_ccmu.h>
返回值定义枚举
typedef enum
HAL_CLK_STATUS_DISABLED = -1,
HAL_CLK_STATUS_ENABLED = 0,
HAL_CLK_STATUS_ERROR_CLK_FACTOR_REFUSED = -11,
HAL_CLK_STATUS_ERROR_CLK_NEED_DISABLED = -10,
HAL_CLK_STATUS_ERROR_CLK_PARENT_DISABLED = -9,
HAL_CLK_STATUS_ERROR_CLK_ENABLED_FAILED = -8,
HAL_CLK_STATUS_ERROR_CLK_ROUND_FAILED = -7,
HAL_CLK_STATUS_ERROR_CLK_SET_RATE_REFUSED = -6,
HAL_CLK_STATUS_ERROR_CLK_NOT_FOUND = -5,
HAL_CLK_STATUS_ERROT_CLK_UNDEFINED = -4,
HAL_CLK_STATUS_UNINITIALIZED = -3, /**< Uninitialized clock driver. */
HAL_CLK_STATUS_INVALID_PARAMETER = -2, /**< Invalid parameter. */
HAL_CLK_STATUS_ERROR = -1, /**< Unknown error. */
HAL_CLK_STATUS_OK = 0, /**< Successful. */
} hal_clk_status_t;
时钟类型定义枚举
typedef enum
HAL_SUNXI_FIXED_CCU = 0,
HAL_SUNXI_RTC_CCU,
HAL_SUNXI_CCU,
HAL_SUNXI_AON_CCU,
HAL_SUNXI_R_CCU,
HAL_SUNXI_DSP,
HAL_SUNXI_CCU_NUMBER,
} hal_clk_type_t;
初始化CCU驱动
函数原型
void hal_clock_init(void);
参数:
无
返回值:
无
判断指定时钟是否已经打开
函数原型
hal_clk_status_t hal_clock_is_enabled(hal_clk_t clk);
参数:
clk:clk id
返回值:
HAL_CLK_STATUS_ENABLED:打开
HAL_CLK_STATUS_DISABLED:关闭
获得指定的时钟句柄
函数原型
hal_clk_t hal_clock_get(hal_clk_type_t type, hal_clk_id_t id);
参数:
type:时钟类型
返回值:
时钟句柄 hal_clk_t
释放指定时钟句柄
函数原型
hal_clk_status_t hal_clock_put(hal_clk_t clk);
参数:
clk:要操作的时钟句柄
返回值:
0:成功
负数:失败
打开指定时钟
函数原型
hal_clk_status_t hal_clock_enable(hal_clk_t clk);
参数:
clk:时钟id
返回值:
0:成功
负数:失败
关闭指定时钟
函数原型
hal_clk_status_t hal_clock_disable(hal_clk_t clk);
参数:
clk:时钟id
返回值:
0:成功
负数:失败
重新计算指定时钟的频率
函数原型
u32 hal_clk_recalc_rate(hal_clk_t clk);
参数:
clk:时钟id
返回值:
0:成功
负数:失败
设置一个跟指定频率最接近的时钟频
函数原型
u32 hal_clk_round_rate(hal_clk_t clk, u32 rate);
参数:
clk:时钟id
rate:频率
返回值:
0:成功
负数:失败
获取指定时钟频率
可能非实时
函数原型
u32 hal_clk_get_rate(hal_clk_t clk);
参数:
clk:时钟id
返回值:
0:成功
负数:失败
设置指定时钟的频
函数原型
hal_clk_status_t hal_clk_set_rate(hal_clk_t clk, u32 rate);
参数:
clk:时钟id
rate:频率
返回值:
0:成功
负数:失败
设置指定时钟的父时钟
函数原型
hal_clk_status_t hal_clk_set_parent(hal_clk_t clk, hal_clk_t parent);
参数:
clk:时钟id
parent:父时钟id
返回值:
0:成功
负数:失败
获取指定时钟的父时钟
函数原型
hal_clk_t hal_clk_get_parent(hal_clk_t clk);
参数:
clk:时钟id
返回值:
0:成功
负数:失败
模块使用范例
#include <stdlib.h>
#include <hal_log.h>
#include <hal_cmd.h>
#include "../../source/ccmu/sunxi-ng/ccu-sun20iw2-aon.h"
#ifndef CLK_RTC_NUMBER
#define CLK_RTC_NUMBER 0
#endif
int clk_number[] = {
CLK_SRC_NUMBER,
CLK_RTC_NUMBER,
CLK_NUMBER,
CLK_AON_NUMBER,
CLK_R_NUMBER,
int reset_number[] = {
RST_BUS_NUMBER,
RST_R_BUS_NUMBER,
0,
char *strict_clks[] = {
"pll-ddr0",
"riscv",
"pll-cpux",
"pll-periph0-parent",
"riscv-axi",
"apb1",
"fanout-27m",
"fix-losc",
"rc-16m",
"ext-32k",
"rc-hf",
"pclk-spc-1",
"pclk-spc-2",
"pclk-spc",
NULL,
char *clk_type_name[] = {
"HAL_SUNXI_FIXED_CCU",
"HAL_SUNXI_RTC_CCU",
"HAL_SUNXI_CCU",
"HAL_SUNXI_AON_CCU",
"HAL_SUNXI_R_CCU",
int is_strict_clk(hal_clk_t clk)
int i;
for (i = 0; strict_clks[i] != NULL; i++)
if (!strcmp(clk->name, strict_clks[i]))
return 1;
return 0;
int is_dcxo_clk(hal_clk_t clk)
if (!strncmp(clk->name, "dcxo", 4))
return 1;
return 0;
int cmd_test_ng_ccmu(int argc, char **argv)
int i, j;
hal_clk_type_t clk_type;
hal_clk_id_t clk_id;
hal_clk_t clk, p_clk;
u32 old_rate;
hal_reset_type_t reset_type;
hal_reset_id_t reset_id;
hal_clk_status_t clk_status;
struct reset_control *reset;
int reset_status;
u32 new_rate;
printf("clock\t\t\t\t\t type\t\t\t\t\t parent\t\t\t\t\t rate\n");
for (i = HAL_SUNXI_FIXED_CCU; i < HAL_SUNXI_CCU_NUMBER; i++)
clk_type = i;
for (j = 0; j < clk_number[i]; j++)
clk_id = j;
clk = hal_clock_get(clk_type, clk_id);
if (!clk) {
printf("fail to get clk\n");
continue;
p_clk = hal_clk_get_parent(clk);
old_rate = hal_clk_get_rate(clk);
if (p_clk)
printf("%-20s\t\t\t %-20s\t\t\t %-15s\t\t\t %d\n", clk->name, clk_type_name[i], p_clk->name, old_rate);
else
printf("%-20s\t\t\t %-20s\t\t\t NULL\t\t\t\t\t %d\n", clk->name, clk_type_name[i], old_rate);
for (i = HAL_SUNXI_RESET; i < HAL_SUNXI_RESET_NUMBER; i++)
reset_type = i;
for (j = 0; j < reset_number[i]; j++)
reset_id = j;
printf("reset: get reset control, type:%d, id: %d\n", reset_type, reset_id);
reset = hal_reset_control_get(reset_type, reset_id);
printf("reset: control deassert\n");
hal_reset_control_deassert(reset);
reset_status = hal_reset_control_status(reset);
printf("reset status: %s", reset_status ? "assert" : "deassert");
printf("reset: put reset control, type:%d, id: %d\n", reset_type, reset_id);
hal_reset_control_put(reset);
return 0;
FINSH_FUNCTION_EXPORT_CMD(cmd_test_ng_ccmu, hal_ccmu, sunxi - ng ccmu hal APIs tests)
