[技术讨论] 全志R128 SDK HAL 模块开发指南——PMU
 楼主| 神棍地海棠 发表于 2024-4-12 10:05 | 显示全部楼层 |阅读模式
# PMU
PMU - 电源管理单元,负责系统各模块供电及电池充放电管理。
## 模块配置
regulator 相关配置项:
Drivers Options --->
    soc related device drivers --->
        REGULATOR Devices --->
            [*] enable regulator driver
            [*] regulator test
power 相关配置项:
        POWER Devices --->
            [*] enable power driver
                [*] use axp2585
                [*] regulator test
## 源码结构介绍
lichee/rtos-hal/hal/source/power/
├── axp2585.c
├── axp2585.h
├── axp.c
├── axp_twi.c
├── ffs.h
├── Kconfig
├── Makefile
├── sun20iw2p1
│ └── core.c
└── type.h
lichee/rtos-hal/hal/source/regulator/
├── Kconfig
├── Makefile
└── sun20iw2p1
  └── core.c
## 模块接口说明
头文件:
```c
#include <sunxi_hal_power.h>
#include <sunxi_hal_regulator.h>
### regulator 相关结构体
```c
struct regulator_ops{
        int (*enable) (struct regulator_dev *);
        int (*disable) (struct regulator_dev *);
        int (*set_voltage) (struct regulator_dev *, int target_uV);
        int (*get_voltage) (struct regulator_dev *, int *vol_uV);
        int (*set_en) (struct regulator_dev *, unsigned int flags);
        int (*set_voltage_ext) (struct regulator_dev *, int target_uV, unsigned int status);
        int (*get_voltage_ext) (struct regulator_dev *, int *vol_uV,  unsigned int status);
struct regulator_dev{
        unsigned int flag;
        struct regulator_ops *ops;
        void *private;
### power 相关结构体
```c
struct power_dev{
        unsigned int flag;
        struct bat_power_ops *bat_ops;
        struct usb_power_ops *usb_ops;
        struct power_supply  *config;
        hal_sem_t irq_schd;
### regulator 获取电路接口
函数原型
```c
int hal_regulator_get(unsigned int request_flag, struct regulator_dev *rdev)
参数:
- rdev: 指定regulator的结构体
- request_flag: 指定regulator的电路参数
返回值:
- 成功:0
- 失败:‑1
### regulator 电路使能接口
函数原型
```c
int hal_regulator_set_able(struct regulator_dev *rdev, unsigned int flags)
参数:
- flags: 电路开关状态
返回值:
- 成功:0
- 失败:‑1
### regulator 获取电压接口
函数原型
```c
int hal_regulator_get_voltage_ext(struct regulator_dev *rdev, int *vol_uV, unsigned int status)
参数:
- vol_uV: 获取的电压信息
- status: 运行/休眠时的电压
返回值:
- 成功:0
- 失败:‑1
### regulator 调节电压接口
函数原型
```c
int hal_regulator_set_voltage_ext(struct regulator_dev *rdev, int target_uV, unsigned int status)
参数:
- target_uV: 指定调压信息
- status: 运行/休眠时的电压
返回值:
- 成功:0
- 失败:‑1
### power 初始化
函数原型
```c
int hal_power_init(void);
参数:
- 无
返回值:
- 成功:0
- 失败:‑1
### 获取当前 power 驱动
函数原型
```c
int hal_power_get(struct power_dev *rdev);
参数:
- rdev:初始化前的 power_dev 结构体
返回值:
- 0
### 获取电池电量信息
函数原型
```c
int hal_power_get_bat_cap(struct power_dev *rdev);
参数:
- rdev:初始化后power_dev 结构体
返回值:
- 电池电量,[0‑100]
- 失败:‑1
### 获取库仑计信息
函数原型
```c
int hal_power_get_coulumb_counter(struct power_dev *rdev);
参数:
返回值:
- 成功:返回电流大小,单位mA
- 失败:‑1
### 查看电池当前状态
函数原型
```c
int hal_power_get_bat_present(struct power_dev *rdev);
参数:
返回值:
- 成功:电池有效返回1,否则返回0
- 失败:‑1
### 查看电池是否连接
函数原型
```c
int hal_power_get_bat_online(struct power_dev *rdev);
参数:
返回值:
- 成功:电池存在返回1,否则返回0
- 失败:‑1
### 获取电池充电状态
函数原型
```c
int hal_power_get_bat_status(struct power_dev *rdev);
参数:
返回值:
- 成功:返回电池的多种状态,[0] 未知状态;[1] 充电状态;[3] 连接单不充电;[4] 充满电。
- 失败:‑1
### 获取电池当前的健康状态
函数原型
```c
int hal_power_get_bat_health(struct power_dev *rdev);
参数:
返回值:
- 成功:返回1,电池健康
- 失败:‑1
### 获取电池电压
函数原型
```c
int hal_power_get_vbat(struct power_dev *rdev);
参数:
返回值:
- 成功:返回当前电压,单位mV
- 失败:‑1
### 获取充电电流
函数原型
```c
int hal_power_get_ibat(struct power_dev *rdev);
参数:
返回值:
- 成功:返回当前充电电流,单位mA
- 失败:‑1
### 获取放电电流
函数原型
```c
int hal_power_get_disibat(struct power_dev *rdev);
参数:
返回值:
- 成功:返回当前放电电流,单位mA
- 失败:‑1
### 获取 AXP IC 温度
函数原型
```c
int hal_power_get_temp(struct power_dev *rdev);
参数:
返回值:
- 成功:当前AXP IC 温度,单位为温度数值*10
- 失败:‑1
### 获取电池温度
函数原型
```c
int hal_power_get_temp_ambient(struct power_dev *rdev)
参数:
- 成功:当前电池温度,单位为温度数值*10
返回值:
- 失败:‑1
### 设置充电电流
函数原型
```c
int hal_power_set_chg_cur(struct power_dev *rdev, int cur)
参数:
- cur:充电电流大小,单位mA
返回值:
- 成功:0
- 失败:‑1
### 设置充电截止电压
函数原型
```c
int hal_power_set_chg_vol(struct power_dev *rdev, int vol)
参数:
- vol:充电截止电压,单位mV
返回值:
- 成功:0
- 失败:‑1
### 设置电池开关
函数原型
```c
int hal_power_set_batfet(struct power_dev *rdev, int onoff)
参数:
- onoff:电池开关,0 关闭电池与电路连接,1 打开连接
返回值:
- 成功:0
- 失败:‑1
### 获取当前USB 状态
函数原型
```c
int hal_power_get_usb_status(struct power_dev *rdev)
参数:
返回值:
- 成功:[1]USB 连接,有VBUS;[0] 无USB 连接,无VBUS
- 失败:‑1
### 获取USB 口输入限流值
函数原型
```c
int hal_power_get_usb_ihold(struct power_dev *rdev)
参数:
返回值:
- 成功:USB 口限流的电流值,单位mA
- 失败:‑1
### 获取USB 口输入限压值
函数原型
```c
int hal_power_get_usb_vhold(struct power_dev *rdev)
参数:
返回值:
- 成功:USB 口限压电流值,单位mV
- 失败:‑1
### 设置USB 口输入限流值
函数原型
```c
int hal_power_set_usb_ihold(struct power_dev *rdev, int cur)
参数:
- cur:USB 口限流的电流值,单位mA,范围[0‑3100]
返回值:
- 成功:0
- 失败:‑1
### 设置USB 口输入限压值
函数原型
```c
int hal_power_set_usb_vhold(struct power_dev *rdev, int vol)
参数:
- vol:USB 口输入限压值,单位mV,范围[3880mV~5080mV]
返回值:
- 成功:0
- 失败:‑1
## 模块使用范例
### regulator 模块使用范例
```c
#include <stdio.h>
#include <stdint.h>
#include <stdlib.h>
#include <string.h>
#include <stddef.h>
#include <unistd.h>
#include <sunxi_hal_common.h>
#include <hal_cmd.h>
#include <hal_log.h>
#define SOC_PRCM_BASE                       (0x40050000)
#define SOC_PRCM_DCDC_CTRL0       (SOC_PRCM_BASE+0x0004)
#define SOC_PRCM_DCDC_CTRL1       (SOC_PRCM_BASE+0x0008)
#define SOC_PRCM_DCDC_LDO_MODE    (SOC_PRCM_BASE+0x000c)
#define SOC_PRCM_RTC_LDO_CTRL     (SOC_PRCM_BASE+0x0020)
#define SOC_PRCM_EXT_LDO_CTRL     (SOC_PRCM_BASE+0x0024)
#define SOC_PRCM_TOP_LDO_CTRL     (SOC_PRCM_BASE+0x0028)
#define SOC_PRCM_AON_LDO_CTRL     (SOC_PRCM_BASE+0x0040)
#define SOC_PRCM_APP_LDO_CTRL     (SOC_PRCM_BASE+0x0044)
#define SOC_PRCM_DSP_LDO_CTRL     (SOC_PRCM_BASE+0x004c)
//test : rpccli arm hal_regulator_set_current_able
static int hal_regulator_regs_check(void)
        printf("[regulator] %x:%x\n", SOC_PRCM_DCDC_CTRL0, readl(SOC_PRCM_DCDC_CTRL0));
        printf("[regulator] %x:%x\n", SOC_PRCM_DCDC_CTRL1, readl(SOC_PRCM_DCDC_CTRL1));
        printf("[regulator] %x:%x\n", SOC_PRCM_DCDC_LDO_MODE, readl(SOC_PRCM_DCDC_LDO_MODE));
        printf("[regulator] %x:%x\n", SOC_PRCM_RTC_LDO_CTRL, readl(SOC_PRCM_RTC_LDO_CTRL));
        printf("[regulator] %x:%x\n", SOC_PRCM_EXT_LDO_CTRL, readl(SOC_PRCM_EXT_LDO_CTRL));
        printf("[regulator] %x:%x\n", SOC_PRCM_TOP_LDO_CTRL, readl(SOC_PRCM_TOP_LDO_CTRL));
        printf("[regulator] %x:%x\n", SOC_PRCM_AON_LDO_CTRL, readl(SOC_PRCM_AON_LDO_CTRL));
        printf("[regulator] %x:%x\n", SOC_PRCM_APP_LDO_CTRL, readl(SOC_PRCM_APP_LDO_CTRL));
        printf("[regulator] %x:%x\n", SOC_PRCM_DSP_LDO_CTRL, readl(SOC_PRCM_DSP_LDO_CTRL));
        return 0;
static int cmd_set_able(int argc, const char **argv)
        int ret;
        int id = SOC_ID_MAX;
        unsigned int flag = 0;
        struct regulator_dev regulator;
        if (argv[1])
                id = (int)*argv[1] - 48;
        if (argv[2])
                flag = (int)*argv[2] - 48;
        printf("[regulator] set regulator_en[%d]:%x, flage:%d\n", id, REGULATOR_GET(SOC_REGULATOR, id), flag);
        hal_regulator_get(REGULATOR_GET(SOC_REGULATOR, id), &regulator);
        printf("[regulator] set_able regulator_en\n");
        hal_regulator_set_able(&regulator, flag);
        printf("[regulator] set_regulator[%d]able_status:%d\n", id, flag);
        hal_regulator_regs_check();
        return 0;
FINSH_FUNCTION_EXPORT_CMD(cmd_set_able, hal_regulator_set_current_able, regulator hal APIs tests)
static int cmd_get_voltage_ext(int argc, const char **argv)
        int ret;
        if (argv[1])
        if (argv[2])
        printf("[regulator] get regulator:%x\n", REGULATOR_GET(SOC_REGULATOR, id));
        printf("[regulator] cat check_dedc_status\n");
        hal_regulator_get_voltage_ext(&regulator, &ret, flag);
        printf("[regulator] get_regulator[%d]status[%d]voltage:%d\n", id, flag, ret);
        return 0;
FINSH_FUNCTION_EXPORT_CMD(cmd_get_voltage_ext, hal_regulator_get_voltage, regulator hal APIs tests)
static int cmd_set_voltage_ext(int argc, const char **argv)
        int ret[4] = {0};
        int ret1;
        if (argv[1])
        if (argv[2])
        if (argv[3])
                ret[0] = ((int)*argv[3] - 48) * 1000;
        if (argv[4])
                ret[1] = ((int)*argv[4] - 48) * 100;
        if (argv[5])
                ret[2] = ((int)*argv[5] - 48) * 10;
        if (argv[6])
                ret[3] = ((int)*argv[6] - 48) * 1;
        ret1 = (ret[0] + ret[1] + ret[2] + ret[3]) * 1000;
        printf("[regulator] set regulator:%x\n", REGULATOR_GET(SOC_REGULATOR, id));
        printf("[regulator] set_regulator[%d]status[%d]voltage:%d\n", id, flag, ret1);
        hal_regulator_set_voltage_ext(&regulator, ret1, flag);
        printf("[regulator] finishe-set_regulator[%d]status[%d]voltage:%d\n", id, flag, ret1);
        return 0;
FINSH_FUNCTION_EXPORT_CMD(cmd_set_voltage_ext, hal_regulator_set_voltage, regulator hal APIs tests)
### power 模块使用范例
```c
#include <stdio.h>
#include <stdint.h>
#include <stdlib.h>
#include <string.h>
static int cmd_test_power_get_bat(int argc, const char **argv)
        int ret;
        struct power_dev rdev;
        printf("[power] get power\n");
        hal_power_get(&rdev);
        printf("[power] get bat cap\n");
        ret = hal_power_get_bat_cap(&rdev);
        printf("[power] bat cap:%d\n", ret);
        printf("[power] get_coulumb_counter\n");
        ret = hal_power_get_coulumb_counter(&rdev);
        printf("[power] coulumb_counter:%d\n", ret);
        printf("[power] get bat_present\n");
        pr_err("pmu_bat_unused:%d\n", rdev.config->pmu_bat_unused);
        pr_err("pmu_version:%d\n", rdev.config->pmu_version);
        ret = hal_power_get_bat_present(&rdev);
        printf("[power] bat_present:%d\n", ret);
        printf("[power] get online\n");
        ret = hal_power_get_bat_online(&rdev);
        printf("[power] bat online:%d\n", ret);
        printf("[power] get status\n");
        ret = hal_power_get_bat_status(&rdev);
        printf("[power] bat status:%d\n", ret);
        printf("[power] get bat health\n");
        ret = hal_power_get_bat_health(&rdev);
        printf("[power] bat health:%d\n", ret);
        printf("[power] get vbat\n");
        ret = hal_power_get_vbat(&rdev);
        printf("[power] bat vbat:%d\n", ret);
        printf("[power] get ibat\n");
        ret = hal_power_get_ibat(&rdev);
        printf("[power] bat ibat:%d\n", ret);
        printf("[power] get disibat\n");
        ret = hal_power_get_disibat(&rdev);
        printf("[power] bat disibat:%d\n", ret);
        printf("[power] get temp\n");
        ret = hal_power_get_temp(&rdev);
        printf("[power] bat temp:%d\n", ret);
        printf("[power] bat get test finish\n");
        return 0;
FINSH_FUNCTION_EXPORT_CMD(cmd_test_power_get_bat, test_power_get_bat, power hal APIs tests)
static int cmd_test_power_set_bat(int argc, const char **argv)
        int ret;
    int cur = strtol(argv[1], NULL, 0);
    int vol = strtol(argv[2], NULL, 0);
        printf("[power] set bat power:cur:%d vol:%d\n", cur, vol);
        printf("[power] set bat cur:%d\n", cur);
        ret = hal_power_set_chg_cur(&rdev, cur);
        printf("[power] chg_cur:%d\n", ret);
        printf("[power] set bat vol:%d\n", vol);
        ret = hal_power_set_chg_vol(&rdev, vol);
        printf("[power] _chg_vol:%d\n", ret);
        printf("[power] bat set test finish\n");
        return 0;
FINSH_FUNCTION_EXPORT_CMD(cmd_test_power_set_bat, test_power_set_bat, power hal APIs tests)
static int cmd_test_power_get_usb(int argc, const char **argv)
        int ret;
        printf("[power] get usb_status\n");
        ret = hal_power_get_usb_status(&rdev);
        printf("[power] usb_status:%d\n", ret);
        printf("[power] usb_ihold\n");
        ret = hal_power_get_usb_ihold(&rdev);
        printf("[power] usb_ihold:%d\n", ret);
        printf("[power] get usb_vhold\n");
        ret = hal_power_get_usb_vhold(&rdev);
        printf("[power] usb_vhold:%d\n", ret);
        printf("[power] get cc_status\n");
        ret = hal_power_get_cc_status(&rdev);
        printf("[power] cc_status:%d\n", ret);
        printf("[power] usb get test finish\n");
        return 0;
FINSH_FUNCTION_EXPORT_CMD(cmd_test_power_get_usb, test_power_get_usb, power hal APIs tests)
static int cmd_test_power_set_usb(int argc, const char **argv)
        int ret;
        printf("[power] set usb power:cur:%d vol:%d\n", cur, vol);
        printf("[power] set usb_ihold:%d\n", cur);
        ret = hal_power_set_usb_ihold(&rdev, cur);
        printf("[power] set usb_vhold:%d\n", vol);
        ret = hal_power_set_usb_vhold(&rdev, vol);
        printf("[power] usb set test finish\n");
        return 0;
FINSH_FUNCTION_EXPORT_CMD(cmd_test_power_set_usb, test_power_set_usb, power hal APIs tests)
