PMS150G,PA.0中断
 楼主| 34af9uc 发表于 2024-4-20 22:30 | 显示全部楼层 |阅读模式
/****************PMS150G,PA.0中断******************/
/****************ID:共同学习stm8*******************/
/****************20240420**************************/
#include        "extern.h"
bit                led                :pa.3;
void        FPPA0 (void)
.ADJUST_IC        SYSCLK=IHRC/4                //        SYSCLK=IHRC/4
$                inten                pa.0;                //开pa.0中断
intrq                                =0;                        //清intrq
engint;                                                        //启用全局中断
//disgint;                                                //停用全局中断
$                led                out,low;
$                pa.0        in,ph;
//$                integs        pa0_f;
integs=0b0000_0010;
while (1)
$                led                out,high;
void        Interrupt (void)
pushaf;                //入栈
if(Intrq.pa0)                //边沿进中断
if(pa==0)
$                led                out,low;
.delay 1000000;
Intrq.pa0                =0;
popaf;                //出栈
319
