[AVR单片机] HT1621显示
 楼主| 比神乐 发表于 2024-5-16 08:51 | 显示全部楼层 |阅读模式
代码
  1. #include <iom128v.h>
  2. #include <macros.h>
  3. #define uchar unsigned char
  4. #define uint unsigned int
  5. #define DA_1  PORTD |= BIT(6)//RS置1
  6. #define DA_0  PORTD &= ~BIT(6)//RS置0
  7. #define WR_1  PORTD |= BIT(2)//RS置1
  8. #define WR_0  PORTD &= ~BIT(2)//RS置0
  9. #define CS_1  PORTD |= BIT(4)//RS置1
  10. #define CS_0  PORTD &= ~BIT(4)//RS置0
  11. #define Smg_a 0x80
  12. #define Smg_b 0x40
  13. #define Smg_c 0x20
  14. #define Smg_d 0x01
  15. #define Smg_e 0x02
  16. #define Smg_f 0x08
  17. #define Smg_g 0x04
  18. #define Smg_dp 0x10
  19. #define Bmp0Map Smg_a | Smg_b | Smg_c | Smg_d | Smg_e | Smg_f
  20. #define Bmp1Map Smg_b | Smg_c
  21. #define Bmp2Map Smg_a | Smg_b | Smg_d | Smg_e | Smg_g
  22. #define Bmp3Map Smg_a | Smg_b | Smg_c | Smg_d | Smg_g
  23. #define Bmp4Map Smg_b | Smg_c | Smg_f | Smg_g
  24. #define Bmp5Map Smg_a | Smg_c | Smg_d | Smg_f | Smg_g
  25. #define Bmp6Map Smg_a | Smg_c | Smg_d | Smg_e | Smg_f | Smg_g
  26. #define Bmp8Map Smg_a | Smg_b | Smg_c | Smg_d | Smg_e | Smg_f | Smg_g
  27. #define Bmp9Map Smg_a | Smg_b | Smg_c | Smg_d | Smg_f | Smg_g
  28. #define Bmp7Map Smg_a | Smg_b | Smg_c
  29. #define BmpAMap Smg_a | Smg_b | Smg_c | Smg_e | Smg_f | Smg_g
  30. #define BmpBMap Smg_c | Smg_d | Smg_e | Smg_f | Smg_g
  31. #define BmpCMap Smg_a | Smg_d | Smg_e | Smg_f
  32. #define BmpDMap Smg_b | Smg_c | Smg_d | Smg_e | Smg_g
  33. #define BmpEMap Smg_a | Smg_d | Smg_e | Smg_f | Smg_g
  34. #define BmpFMap Smg_a | Smg_e | Smg_f | Smg_g
  35. const unsigned char SegCode[] = {Bmp0Map,Bmp1Map,Bmp2Map,Bmp3Map,Bmp4Map,Bmp5Map,Bmp6Map,Bmp7Map,Bmp8Map,Bmp9Map,BmpAMap,BmpBMap,BmpCMap,BmpDMap,BmpEMap,BmpFMap};
  36. unsigned char DpyNum[6] = {Smg_g,Smg_g,Smg_g,Smg_g,Smg_g,Smg_g}; //?????
  37. unsigned int i;
  38. void COMMAND_HT1621(unsigned char comm)
  39. {
  40. //unsigned char i;
  41. CS_0;
  42. WR_0;
  43. for(i=0;i<3;i++)//???
  44. {
  45. if((0x04<<i)&0x04)
  46.                                                    DA_1; //100
  47. else
  48.                                     DA_0;
  49. WR_0;
  50. WR_1;
  51. }
  52. for(i=0;i<9;i++)//?????
  53. {
  54.     if((comm<<i)&0x80) DA_1; //100
  55.     else DA_0;
  56.     WR_0;
  57.     WR_1;
  58. }
  59. CS_1;
  60. }
  61. void HT1621_Display(void)
  62. {
  63. //unsigned char i;
  64. CS_0;//??CS
  65. WR_0;
  66. for(i=0;i<3;i++) //???
  67. {
  68.     if((0x05<<i)&0x04) DA_1;
  69.     else DA_0;
  70.     WR_0;
  71.     WR_1;
  72. }
  73. for(i=0;i<6;i++) //???
  74. {
  75.     if((20<<i)&0x20) DA_1;//20?? SEG??
  76.     else DA_0;
  77.     WR_0;
  78.     WR_1;
  79. }
  80. for(i=0;i<8;i++) //???
  81. {
  82.     if((DpyNum[5]<<i)&0x80)
  83.                                                    DA_1;
  84.     else DA_0;
  85.     WR_0;
  86.     WR_1;
  87. }
  88. for(i=0;i<8;i++) //???
  89. {
  90. if((DpyNum[4]<<i)&0x80)DA_1;
  91. else DA_0;
  92. WR_0;
  93. WR_1;
  94. }
  95. for(i=0;i<8;i++) //???
  96. {
  97. if((DpyNum[3]<<i)&0x80) DA_1;
  98. else DA_0;
  99. WR_0;
  100. WR_1;
  101. }
  102. for(i=0;i<8;i++) //???
  103. {
  104. if((DpyNum[2]<<i)&0x80)DA_1;
  105. else DA_0;
  106. WR_0;
  107. WR_1;
  108. }
  109. for(i=0;i<8;i++) //???
  110. {
  111. if((DpyNum[1]<<i)&0x80)DA_1;
  112. else DA_0;
  113. WR_0;
  114. WR_1;
  115. }
  116. for(i=0;i<8;i++) //???
  117. {
  118. if((DpyNum[0]<<i)&0x80) DA_1;
  119. else DA_0;
  120. WR_0;
  121. WR_1;
  122. }
  123. CS_1;//??CS
  124. }
  125. void LCD_Init(void)
  126. {
  127. COMMAND_HT1621(0x01);//SYS EN
  128. COMMAND_HT1621(0x03);//LCD ON
  129. COMMAND_HT1621(0x29);//4 COM牋1/3 BIAS
  130. HT1621_Display(); //clear screen
  131. }
  132. void main(void)
  133. {
  134. DDRD=0xff;
  135. LCD_Init();
  136. DpyNum[0] = Smg_a|Smg_d|Smg_g;//"?"
  137. DpyNum[1] = SegCode[2];
  138. DpyNum[2] = SegCode[4];
  139. DpyNum[3] = SegCode[6];
  140. DpyNum[4] = SegCode[8];
  141. DpyNum[5] = SegCode[0];
  142. HT1621_Display();
  143. while(1)
  144. {
  145.
  146. }
  147. }
效果图
xionghaoyun 发表于 2024-5-21 17:44 | 显示全部楼层
兄弟 中间注释是? 文字编码格式不对
13603089129 发表于 2024-5-23 16:06 | 显示全部楼层
专注替代HT162X系列段码屏驱动显示芯片
Cjy_JDxy 发表于 2024-9-20 17:26 | 显示全部楼层
兄弟 中间注释是? 文字编码格式不对
应该是
昨天 发表于 2024-9-23 09:43 | 显示全部楼层
这个搞 的很规范哦??。
