暂时放弃了,整不了,怎么编译就是不- /*************HLK-W801-KIT-V1.1********************/
- /*************1.3寸OLED IIC************************/
- /*************ID:共同学习stm8**********************/
- /*************跨平台,一切都是运算*******************/
- /*******.******20240421*****************************/
- //0X0000 GPIO 数据寄存器 GPIO_DATA RW 读写 GPIO 当前数据 0X180B
- #define GPIOA_DATA (*(volatile unsigned int*)(0x40011200+0x0000))
- //0X0004 GPIO 数据使能寄存器 GPIO_DATA_EN RW 配置 GPIO_DATA 的使能位 0XFFFF
- #define GPIOA_DATA_EN (*(volatile unsigned int*)(0x40011200+0X0004))
- //0X0008 GPIO 方向控制寄存器 GPIO_DIR RW 配置 GPIO 方向 0X0000
- #define GPIOA_DIR (*(volatile unsigned int*)(0x40011200+0X0008))
- //0X000C GPIO 上拉控制寄存器 GPIO_PULL_EN RW 配置 GPIO 上拉 0XFFFF
- #define GPIOA_PULL_EN (*(volatile unsigned int*)(0x40011200+0X000c))
- //0X001C GPIO 下拉控制寄存器 GPIO_DN_ENA RW 配置 GPIO 下拉 0X0000
- #define GPIOA_DN_ENA (*(volatile unsigned int*)(0x40011200+0X001c))
- #define GPIOB_DATA (*(volatile unsigned int*)(0x40011400+0x0000))
- #define GPIOB_DATA_EN (*(volatile unsigned int*)(0x40011400+0X0004))
- #define GPIOB_DIR (*(volatile unsigned int*)(0x40011400+0X0008))
- #define GPIOB_PULL_EN (*(volatile unsigned int*)(0x40011400+0X000c))
- #define GPIOB_DN_ENA (*(volatile unsigned int*)(0x40011400+0X001c))
- // _______________________
- // | 1.3' OLED IIC |
- // | GND|VCC|SCL|SDA |
- // | 128*64 |
- // |_______________________|
- //数据sda-----PA1
- //时钟scl-----PA2
- //sda¯¯\__X=7=X===X===X===X===X===X===X=0=X¯\_/X__/¯¯
- //scl¯¯¯¯\_/¯\_/¯\_/¯\_/¯\_/¯\_/¯\_/¯\_/¯\_/¯¯\_/¯¯¯¯
- //_____s____1___2___3___4___5___6___7___8__ack____p__
- void iic_chushihua(); //iic初始化;
- void iic_qishi(); //iic起始信号;
- void iic_yingda(); //iic应答信号;
- void iic_tingzhi(); //iic停止信号;
- void iic_xie_byte(unsigned char iic_i1); //iic写一个字节;
- void yanshi_1ms(); //延时1ms;
- void yanshi_1s(); //延时1秒;
- void yanshi(unsigned char y1); //延时
- //#include <stdio.h>
- //#include "wm_hal.h"
- int main(void)
- GPIOA_DATA_EN |=(1<<3);
- GPIOA_DIR |=1<<3;
- #define led_l GPIOA_DATA &=~(1<<3)
- #define led_h GPIOA_DATA |=(1<<3)
- GPIOB_DATA_EN |=(1<<5);
- GPIOB_DIR |=(1<<5);
- #define led_1_l GPIOB_DATA &=~(1<<5)
- #define led_1_h GPIOB_DATA |=(1<<5)
- GPIOB_DATA_EN |=(1<<25);
- GPIOB_DIR |=(1<<25);
- #define led_2_l GPIOB_DATA &=~(1<<25)
- #define led_2_h GPIOB_DATA |=(1<<25)
- led_1_h;
- led_2_h;
- //while(1){};
- iic_chushihua(); //iic初始化;
- iic_qishi();
- iic_xie_byte(0x78);
- iic_tingzhi();
- led_1_l;
- //led_2_h;
- while (1)
- led_l;
- led_1_l;
- led_2_l;
- yanshi_1s();
- //yanshi(10);
- led_h;
- led_1_h;
- led_2_h;
- yanshi_1s();
- //yanshi(10);
- return 0;
- void yanshi_1ms() //延时1ms;
- volatile unsigned int x1=7500;
- //while(x1 --){ __NOP(); __NOP(); __NOP(); __NOP(); __NOP();}
- while(x1 --){};
- void yanshi_1s() //延时1秒;
- volatile unsigned char z1,z2,z3;
- z1 =100; //循环次数;
- do
- do
- z2 =100;
- do{z3 =100;} while(z3--); //细调;
- while(z2--); //粗调;
- while(z1--);
- void yanshi(unsigned char y1) //延时
- while(y1--)
- __NOP(); __NOP(); __NOP(); __NOP(); __NOP();__NOP(); __NOP(); __NOP(); __NOP(); __NOP();
- void iic_chushihua() //iic初始化;
- //数据sda-----PA1
- //时钟scl-----PA2
- //#define xian_sda_l GPIOA_DIR |=(1<<1); __NOP(); __NOP(); GPIOA_DATA &=~(1<<1) /*sda输出,低;*/
- //#define xian_sda_h GPIOA_DIR |=(1<<1); __NOP(); __NOP(); GPIOA_DATA |=(1<<1) /*sda输出,高;*/
- //#define xian_sda_shuru GPIOA_DIR &=~(1<<1); __NOP(); __NOP(); /*sda输入,高;*/
- //#define xian_sda_shuju GPIOA_DATA &=(1<<1) /*sda,io状态;*/
- //#define xian_scl_l GPIOA_DIR |=(1<<2); __NOP(); __NOP(); GPIOA_DATA &=~(1<<2) /*scl输出,低;*/
- //#define xian_scl_h GPIOA_DIR |=(1<<2); __NOP(); __NOP(); GPIOA_DATA |=(1<<2) /*scl输出,高;*/
- //#define xian_scl_shuru GPIOA_DIR &=~(1<<2); __NOP(); __NOP(); /*输入,高;*/
- //#define xian_scl_shuju GPIOA_DATA &=(1<<2) /*scl,io状态;*/
- //#define sda_l GPIOA_DIR |=(1<<1); __NOP(); __NOP(); GPIOA_DATA &=~(1<<1) /*sda输出,低;*/
- //#define sda_h GPIOA_DIR &=~(1<<1); __NOP(); __NOP() /*sda输入,高;*/
- //#define sda_data GPIOA_DATA &(1<<1)
- //#define scl_l GPIOA_DIR |=(1<<2); __NOP(); __NOP(); GPIOA_DATA &=~(1<<2) /*scl输出,低;*/
- //#define scl_h GPIOA_DIR &=~(1<<2); __NOP(); __NOP(); /*输入,高;*/
- //#define scl_data GPIOA_DATA &(1<<2)
- #define sda_l GPIOA_DIR |=(1<<1); GPIOA_DATA &=~(1<<1) /*sda输出,低;*/
- #define sda_h GPIOA_DIR &=~(1<<1); /*sda输入,高;*/
- #define sda_data GPIOA_DATA &(1<<1)
- #define scl_l GPIOA_DIR |=(1<<2); GPIOA_DATA &=~(1<<2) /*scl输出,低;*/
- #define scl_h GPIOA_DIR &=~(1<<2); /*输入,高;*/
- #define scl_data GPIOA_DATA &(1<<2)
- GPIOA_DATA_EN |=1<<1; //sda数据使能;
- GPIOA_DATA_EN |=1<<2; //scl时钟使能;
- GPIOA_PULL_EN |=1<<1; //sda数据上拉电阻;
- GPIOA_PULL_EN |=1<<2; //scl时钟上拉电阻;
- yanshi(100);
- void iic_qishi() //iic起始信号;
- //sda¯¯\__
- //scl¯¯¯¯¯
- sda_h;
- scl_h
- yanshi(10);
- sda_l;
- yanshi(10);
- void iic_xie_byte(unsigned char iic_i1) //iic写一个字节;
- //sda¯¯\__X=7=X===X===X===X===X===X===X=0=/¯\_/X__/¯¯
- scl_l; yanshi(10); if(iic_i1 &(1<<7)){sda_h;} else{sda_l;} yanshi(10);scl_h; yanshi(10);
- scl_l; yanshi(10); if(iic_i1 &(1<<6)){sda_h;} else{sda_l;} yanshi(10);scl_h; yanshi(10);
- scl_l; yanshi(10); if(iic_i1 &(1<<5)){sda_h;} else{sda_l;} yanshi(10);scl_h; yanshi(10);
- scl_l; yanshi(10); if(iic_i1 &(1<<4)){sda_h;} else{sda_l;} yanshi(10);scl_h; yanshi(10);
- scl_l; yanshi(10); if(iic_i1 &(1<<3)){sda_h;} else{sda_l;} yanshi(10);scl_h; yanshi(10);
- scl_l; yanshi(10); if(iic_i1 &(1<<2)){sda_h;} else{sda_l;} yanshi(10);scl_h; yanshi(10);
- scl_l; yanshi(10); if(iic_i1 &(1<<1)){sda_h;} else{sda_l;} yanshi(10);scl_h; yanshi(10);
- scl_l; yanshi(10); if(iic_i1 &(1<<0)){sda_h;} else{sda_l;} yanshi(10);scl_h; yanshi(10);
- void iic_yingda() //iic应答信号;
- //sda/¯\____/
- //scl_/¯¯¯¯\_
- scl_l;
- yanshi(10);
- sda_h;
- yanshi(10);
- scl_h;
- yanshi(10);
- if(~(sda_data))
- led_1_h;
- //while(1); //卡死
- scl_l;
- yanshi(10);
- void iic_tingzhi() //iic停止信号;
- //sdaX\__/¯
- //scl\_/¯¯¯
- scl_l;
- yanshi(10);
- sda_l;
- yanshi(10);
- scl_h;
- yanshi(10);
- sda_h;
- yanshi(10);
按想的走,让灯亮就是不亮,想让他卡在那就是不动,也不知道进没进函数
