•Built-in Arm® Cortex ® -M7 core | | •12-bit A/D converter |
Single- and double-precision FPUs | | Minimum conversion time 0.5μs (2.0Msps) |
•Clock frequency: 160 MHz | | 3 units, 32 channels |
•Internal memory | | •Variable Gain Amplifier (VGA) |
Instruction Flash ROM: 512 KB | | 5 units |
Flash ROM for data: 64 KB | | •Comparator: 5 units |
Instruction RAM: 64 KB | | Window/2 level/1 levell switchable |
RAM for data: 64 KB | | •Functional Safety |
•DMA controller: 2 units / 16 channels | | ROM/RAM ECC function |
•Timer | | Memory data protection function |
General-purpose 16-bit timer: 20 channels | | Register access protect function |
PWM for power control: 12 units / 24 channels | | Clock monitor function |
(including high-resolution output [208 ps] 9 units/18 channels) | | Window type WDT function |
Matrix converter control PWM: 1 unit / 18 channels | | CRC operation function |
•Communication | | A/D converter Diagnostic function |
Synchronous/IIC: 1 channel | | Supply voltage detection function |
Synchronous/UART: 2 channels | | Power-on reset function |
Synchronous/UART/LIN: 1 channel | | •Power supply voltage: 5V single power supply |
Synchronous/UART/SPI: 3 channels | | •Operating temperature: Tc= -40 to 110°C |
Synchronous/UART/data share: 1 channel | | |
SM-Bus: 1 channel | | |
CAN-FD: 2 channels | | |
