- /* Initialize the retarget-io to use the debug UART port */
- result = cy_retarget_io_init(CYBSP_DEBUG_UART_TX, CYBSP_DEBUG_UART_RX,
- CY_RETARGET_IO_BAUDRATE);
- handle_error(result);
- /* \x1b[2J\x1b[;H - ANSI ESC sequence for clear screen */
- printf("\x1b[2J\x1b[;H");
- printf("****************** "
- "HAL: PWM square wave "
- "****************** \r\n\n");
用户灯1设置成PWM模式,2HZ 50%占空比:
- result = cyhal_pwm_init(&pwm_led_control, CYBSP_USER_LED, NULL);
设置PWM频率、占空比:
- result = cyhal_pwm_set_duty_cycle(&pwm_led_control, PWM_DUTY_CYCLE,
- PWM_FREQUENCY);
开始输出PWM:
- result = cyhal_pwm_start(&pwm_led_control);
点击烧写:
烧写完看到用户灯1闪亮:
加上自己的想法,一上电用户灯1闪3秒:- char CYCLE_VAULE=99;
- char updown_flag=1;
- char timenums=0;
- for (;;)
- /* Set the PWM output frequency and duty cycle */
- result = cyhal_pwm_set_duty_cycle(&pwm_led_control, CYCLE_VAULE,
- 100000);
- check_status("API cyhal_pwm_set_duty_cycle failed with error code", result);
- /* Start the PWM */
- check_status("API cyhal_pwm_start failed with error code", result);
- if(updown_flag==0)
- CYCLE_VAULE++;
- if(CYCLE_VAULE>=100)
- updown_flag=1;
- else
- CYCLE_VAULE--;
- if(CYCLE_VAULE==0)
- updown_flag=0;
- timenums++;
- if(timenums>=3)
- break;
- cyhal_system_delay_ms(20);
- /* Put the CPU into sleep mode to save power */
- // cyhal_syspm_sleep();
- cyhal_pwm_free(&pwm_led_control);
用户灯1效果:
RGB三种IO的PWM初始化:
- /* Initialize the PWM */
- result = cyhal_pwm_init(&pwm_led_rgbred_control, CYBSP_LED_RGB_RED, NULL);
- check_status("API cyhal_pwm_init rgbred failed with error code", result);
- result = cyhal_pwm_init(&pwm_led_rgbgreen_control, CYBSP_LED_RGB_GREEN, NULL);
- check_status("API cyhal_pwm_init rgbgreen failed with error code", result);
- result = cyhal_pwm_init(&pwm_led_rgbblue_control, CYBSP_LED_RGB_BLUE, NULL);
- check_status("API cyhal_pwm_init rgbblue failed with error code", result);
依次点亮八种颜色,红色、橙色、黄色、绿色、青色、蓝色、紫色、白色,每种颜色点亮1秒:
- for(;;)
- //红色
- RGB_Light(PWM_FREQUENCY_RGBRED_red,PWM_DUTY_CYCLE_RGBRED_red,\
- PWM_FREQUENCY_RGBGREEN_red,PWM_DUTY_CYCLE_RGBGREEN_red,\
- PWM_FREQUENCY_RGBBLUE_red,PWM_DUTY_CYCLE_RGBBLUE_red
- cyhal_system_delay_ms(1000);
- //橙色
- RGB_Light(PWM_FREQUENCY_RGBRED_Orange,PWM_DUTY_CYCLE_RGBRED_Orange,\
- PWM_FREQUENCY_RGBGREEN_Orange,PWM_DUTY_CYCLE_RGBGREEN_Orange,\
- PWM_FREQUENCY_RGBBLUE_Orange,PWM_DUTY_CYCLE_RGBBLUE_Orange
- //黄色
- RGB_Light(PWM_FREQUENCY_RGBRED_Yellow,PWM_DUTY_CYCLE_RGBRED_Yellow,\
- PWM_FREQUENCY_RGBGREEN_Yellow,PWM_DUTY_CYCLE_RGBGREEN_Yellow,\
- PWM_FREQUENCY_RGBBLUE_Yellow,PWM_DUTY_CYCLE_RGBBLUE_Yellow
- //绿色
- RGB_Light(PWM_FREQUENCY_RGBRED_Green,PWM_DUTY_CYCLE_RGBRED_Green,\
- PWM_FREQUENCY_RGBGREEN_Green,PWM_DUTY_CYCLE_RGBGREEN_Green,\
- PWM_FREQUENCY_RGBBLUE_Green,PWM_DUTY_CYCLE_RGBBLUE_Green
- //青色
- RGB_Light(PWM_FREQUENCY_RGBRED_Cyan,PWM_DUTY_CYCLE_RGBRED_Cyan,\
- PWM_FREQUENCY_RGBGREEN_Cyan,PWM_DUTY_CYCLE_RGBGREEN_Cyan,\
- PWM_FREQUENCY_RGBBLUE_Cyan,PWM_DUTY_CYCLE_RGBBLUE_Cyan
- //蓝色
- RGB_Light(PWM_FREQUENCY_RGBRED_Blue,PWM_DUTY_CYCLE_RGBRED_Blue,\
- PWM_FREQUENCY_RGBGREEN_Blue,PWM_DUTY_CYCLE_RGBGREEN_Blue,\
- PWM_FREQUENCY_RGBBLUE_Blue,PWM_DUTY_CYCLE_RGBBLUE_Blue
- //紫色
- RGB_Light(PWM_FREQUENCY_RGBRED_Purple,PWM_DUTY_CYCLE_RGBRED_Purple,\
- PWM_FREQUENCY_RGBGREEN_Purple,PWM_DUTY_CYCLE_RGBGREEN_Purple,\
- PWM_FREQUENCY_RGBBLUE_Purple,PWM_DUTY_CYCLE_RGBBLUE_Purple
- //白色
- RGB_Light(PWM_FREQUENCY_RGBRED_white,PWM_DUTY_CYCLE_RGBRED_White,\
- PWM_FREQUENCY_RGBGREEN_white,PWM_DUTY_CYCLE_RGBGREEN_White,\
- PWM_FREQUENCY_RGBBLUE_white,PWM_DUTY_CYCLE_RGBBLUE_white
RGB效果:
