TMS320F28335驱动OLED
 楼主| 比神乐 发表于 2024-6-28 17:51 | 显示全部楼层 |阅读模式
今天用TMS320F28335驱动了一下OLED代码:
mian.c:
  1. // TI File $Revision: /main/8 $
  2. // Checkin $Date: April 21, 2008   15:42:43 $
  3. //###########################################################################
  4. //
  5. // FILE:    Example_2833xGpioToggle.c
  6. //
  7. // TITLE:   DSP2833x Device GPIO toggle test program.
  8. //
  9. // ASSUMPTIONS:
  10. //
  11. //    This program requires the DSP2833x header files.
  12. //
  13. //    ALL OF THE I/O'S TOGGLE IN THIS PROGRAM.  MAKE SURE
  14. //    THIS WILL NOT DAMAGE YOUR HARDWARE BEFORE RUNNING THIS
  15. //    EXAMPLE.
  16. //
  17. //    Monitor desired pins on an oscilloscope.
  18. //
  19. //    As supplied, this project is configured for "boot to SARAM"
  20. //    operation.  The 2833x Boot Mode table is shown below.
  21. //    For information on configuring the boot mode of an eZdsp,
  22. //    please refer to the documentation included with the eZdsp,
  23. //
  24. //       $Boot_Table:
  25. //
  26. //         GPIO87   GPIO86     GPIO85   GPIO84
  27. //          XA15     XA14       XA13     XA12
  28. //           PU       PU         PU       PU
  29. //        ==========================================
  30. //            1        1          1        1    Jump to Flash
  31. //            1        1          1        0    SCI-A boot
  32. //            1        1          0        1    SPI-A boot
  33. //            1        1          0        0    I2C-A boot
  34. //            1        0          1        1    eCAN-A boot
  35. //            1        0          1        0    McBSP-A boot
  36. //            1        0          0        1    Jump to XINTF x16
  37. //            1        0          0        0    Jump to XINTF x32
  38. //            0        1          1        1    Jump to OTP
  39. //            0        1          1        0    Parallel GPIO I/O boot
  40. //            0        1          0        1    Parallel XINTF boot
  41. //            0        1          0        0    Jump to SARAM            <- "boot to SARAM"
  42. //            0        0          1        1    Branch to check boot mode
  43. //            0        0          1        0    Boot to flash, bypass ADC cal
  44. //            0        0          0        1    Boot to SARAM, bypass ADC cal
  45. //            0        0          0        0    Boot to SCI-A, bypass ADC cal
  46. //                                              Boot_Table_End$
  47. //
  48. // DESCRIPTION:
  49. //
  50. //     Three different examples are included. Select the example
  51. //     (data, set/clear or toggle) to execute before compiling using
  52. //     the #define statements found at the top of the code.
  53. //
  54. //
  55. //     Toggle all of the GPIO PORT pins
  56. //
  57. //    The pins can be observed using Oscilloscope.
  58. //
  59. //
  60. //###########################################################################
  61. // $TI Release: DSP2833x/DSP2823x Header Files V1.20 $
  62. // $Release Date: August 1, 2008 $
  63. //###########################################################################
  64. #include "DSP28x_Project.h"     // Device Headerfile and Examples Include File
  65. #include "oled.h"
  66. // Select the example to compile in.  Only one example should be set as 1
  67. // the rest should be set as 0.
  68. #define EXAMPLE1 1  // Use DATA registers to toggle I/O's
  69. #define EXAMPLE2 0  // Use SET/CLEAR registers to toggle I/O's
  70. #define EXAMPLE3 0  // Use TOGGLE registers to toggle I/O's
  71. #define u8 unsigned char
  72. #define u16 unsigned int
  73. // Prototype statements for functions found within this file.
  74. void delay_loop(void);
  75. void Gpio_select(void);
  76. void Gpio_example1(void);
  77. void Gpio_example2(void);
  78. void Gpio_example3(void);
  79. void main(void)
  80. {
  81. // Step 1. Initialize System Control:
  82. // PLL, WatchDog, enable Peripheral Clocks
  83. // This example function is found in the DSP2833x_SysCtrl.c file.
  84.    InitSysCtrl();
  85.
  86. // Step 2. Initalize GPIO:
  87. // This example function is found in the DSP2833x_Gpio.c file and
  88. // illustrates how to set the GPIO to it's default state.
  89. // InitGpio();  // Skipped for this example
  90. // For this example use the following configuration:
  91.    Gpio_select();
  92. // Step 3. Clear all interrupts and initialize PIE vector table:
  93. // Disable CPU interrupts
  94.    DINT;
  95. // Initialize PIE control registers to their default state.
  96. // The default state is all PIE interrupts disabled and flags
  97. // are cleared.
  98. // This function is found in the DSP2833x_PieCtrl.c file.
  99.    InitPieCtrl();
  100. // Disable CPU interrupts and clear all CPU interrupt flags:
  101.    IER = 0x0000;
  102.    IFR = 0x0000;
  103. // Initialize the PIE vector table with pointers to the shell Interrupt
  104. // Service Routines (ISR).
  105. // This will populate the entire table, even if the interrupt
  106. // is not used in this example.  This is useful for debug purposes.
  107. // The shell ISR routines are found in DSP2833x_DefaultIsr.c.
  108. // This function is found in DSP2833x_PieVect.c.
  109.    InitPieVectTable();
  110.
  111. // Step 4. Initialize all the Device Peripherals:
  112. // This function is found in DSP2833x_InitPeripherals.c
  113. // InitPeripherals(); // Not required for this example
  114.
  115. // Step 5. User specific code:
  116.         LCD_Init();
  117.         LCD_CLS();
  118.         LCD_P8x16Str(45,5,(u8*)"EASEAR");
  119.         LCD_P6x8Str(0,7,(u8*)"www.holteksupport.com");
  120.         Draw_BMP(0,0,100,3,(u8*)Dot);
  121.         while(1)
  122.         {
  123.         }
  124. }
  125. void delay_loop()
  126. {
  127.     long int      i;
  128.     for (i = 0; i < 50000000; i++) {}
  129. }
  130. void Gpio_example1(void)
  131. {
  132.    // Example 1:
  133.    // Toggle I/Os using DATA registers
  134.    for(;;)
  135.    {
  136.        GpioDataRegs.GPADAT.all    =0xAAAA;
  137.
  138.        delay_loop();
  139.        GpioDataRegs.GPADAT.all    =0x5555;
  140.
  141.        delay_loop();
  142.     }
  143. }
  144. void Gpio_example2(void)
  145. {
  146.    // Example 2:
  147.    // Toggle I/Os using SET/CLEAR registers
  148.    for(;;)
  149.    {
  150.
  151.        GpioDataRegs.GPASET.all    =0xAAAA;
  152.        GpioDataRegs.GPACLEAR.all  =0x5555;
  153.
  154.
  155.        delay_loop();
  156.        GpioDataRegs.GPACLEAR.all    =0xAAAA;
  157.        GpioDataRegs.GPASET.all      =0x5555;
  158.
  159.        delay_loop();
  160.
  161.     }
  162. }
  163. void Gpio_example3(void)
  164. {
  165.    // Example 2:
  166.    // Toggle I/Os using TOGGLE registers
  167.    // Set pins to a known state
  168.
  169.       GpioDataRegs.GPASET.all    =0xAAAA;
  170.       GpioDataRegs.GPACLEAR.all  =0x5555;
  171.
  172.    // Use TOGGLE registers to flip the state of
  173.    // the pins.
  174.    // Any bit set to a 1 will flip state (toggle)
  175.    // Any bit set to a 0 will not toggle.
  176.    for(;;)
  177.    {
  178.       GpioDataRegs.GPATOGGLE.all =0xFFFF;
  179.       delay_loop();
  180.     }
  181. }
  182. void Gpio_select(void)
  183. {
  184.
  185.     EALLOW;
  186.         GpioCtrlRegs.GPAMUX1.all = 0x00000000;  // All GPIO
  187.         GpioCtrlRegs.GPAMUX2.all = 0x00000000;  // All GPIO
  188.         GpioCtrlRegs.GPAMUX1.all = 0x00000000;  // All GPIO
  189.     GpioCtrlRegs.GPADIR.all = 0xFFFF;   // All outputs
  190.         GpioCtrlRegs.GPBMUX1.all = 0x00000000;  // All GPIO
  191.         GpioCtrlRegs.GPBMUX2.all = 0x00000000;  // All GPIO
  192.         GpioCtrlRegs.GPBMUX1.all = 0x00000000;  // All GPIO
  193.     GpioCtrlRegs.GPBDIR.all = 0xFFFF;   // All outputs
  194.     EDIS;
  195.
  196. }
  197. //===========================================================================
  198. // No more.
  199. //===========================================================================
oled.h
  1. #ifndef _OLED_H
  2. #define _OLED_H
  3. extern unsigned char const Dot[];
  4. extern const unsigned char F6x8[][6];
  5. extern const unsigned char F8X16[];
  6. void LCD_Init(void);
  7. void LCD_CLS(void);
  8. void LCD_P6x8Str(unsigned char x,unsigned char  y,unsigned char  ch[]);
  9. void LCD_P8x16Str(unsigned char  x,unsigned char  y,unsigned char  ch[]);
  10. void LCD_Fill(unsigned char  dat);
  11. void Draw_BMP(unsigned char  x0,unsigned char  y0,unsigned char  x1,unsigned char  y1,unsigned char bmp[]);
  12. #endif
oled.c
  1. #include "DSP28x_Project.h"
  2. #include "OLED.h"
  3. #define LCD_SCL_0  GpioDataRegs.GPACLEAR.bit.GPIO0=1 //_pc5
  4. #define LCD_SCL_1  GpioDataRegs.GPASET.bit.GPIO0=1 //_pc5
  5. #define LCD_SDA_0  GpioDataRegs.GPACLEAR.bit.GPIO1=1
  6. #define LCD_SDA_1  GpioDataRegs.GPASET.bit.GPIO1=1
  7. #define LCD_RST_0  GpioDataRegs.GPACLEAR.bit.GPIO2=1  //  _pc3
  8. #define LCD_RST_1  GpioDataRegs.GPASET.bit.GPIO2=1  //  _pc3
  9. #define LCD_DC_0   GpioDataRegs.GPACLEAR.bit.GPIO3=1
  10. #define LCD_DC_1   GpioDataRegs.GPASET.bit.GPIO3=1
  11. #define XLevelL                0x00
  12. #define XLevelH                0x10
  13. #define XLevel                ((XLevelH&0x0F)*16+XLevelL)
  14. #define Max_Column        128
  15. #define Max_Row                64
  16. #define        Brightness        0xCF
  17. #define X_WIDTH 128
  18. #define Y_WIDTH 64
  19. unsigned char const Dot[]={   //图片--100x36
  20. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x80,0x80,0x80,
  21. 0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,
  22. 0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,
  23. 0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,
  24. 0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,
  25. 0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,
  26. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xC0,0xF0,0xF8,0xFC,0xFE,0xFF,
  27. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  28. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x7F,0x3F,0x9F,0x9F,0xDF,0xCF,0xEF,0xEF,
  29. 0xE7,0xE7,0xF7,0xF7,0xF7,0xF7,0xF7,0xF3,0xF3,0xFB,0xFB,0xFB,0xFB,0xF9,0xF9,0xFD,
  30. 0xFD,0xFD,0xFD,0xFD,0xFD,0xFD,0xFD,0xFD,0xFD,0xFD,0xFD,0xFD,0xFD,0xFD,0xFD,0xFD,
  31. 0xFD,0xFD,0xFD,0xFD,0xFD,0xFD,0xFD,0xFC,0xFC,0xFC,0xFE,0xFE,0xFE,0xFE,0xFE,0xFE,
  32. 0xFC,0xFC,0xF8,0xF0,0xE0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xFF,0xFF,
  33. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  34. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x7F,0x3F,0x0F,0x07,0x03,0xF8,0xFA,0xFB,0xBB,0xBB,
  35. 0x9B,0xBB,0xBB,0x3B,0x03,0x03,0x03,0x83,0xE3,0x73,0xFB,0xF3,0x83,0x03,0x03,0xC3,
  36. 0xE3,0xF3,0xF3,0xFB,0xBB,0x73,0x73,0x33,0x03,0xFB,0xFB,0xFB,0xBB,0x9B,0xBB,0xBB,
  37. 0xBB,0x03,0x03,0x03,0x83,0xE3,0x73,0x7B,0xFB,0x83,0x03,0x03,0xFB,0xFB,0x3B,0x3B,
  38. 0x7B,0xF3,0xF7,0xEF,0x1F,0xFF,0xFF,0xFF,0xFF,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  39. 0x00,0x00,0x00,0x03,0x07,0x0F,0x1F,0x3F,0x3F,0x3F,0x7F,0x7F,0x7F,0x7F,0x7F,0x7F,
  40. 0x7F,0x7F,0x3F,0x3F,0x1F,0x1F,0x0F,0x07,0x03,0x00,0x00,0x00,0x00,0x00,0x00,0x1F,
  41. 0x7F,0x7F,0x73,0x73,0x73,0x73,0x73,0x21,0x30,0x7E,0x3F,0x1F,0x0F,0x0C,0x0F,0x3F,
  42. 0x7F,0x78,0x38,0x01,0x7B,0x73,0x73,0x73,0x7B,0x3F,0x3F,0x1F,0x00,0x7F,0x7F,0x73,
  43. 0x73,0x73,0x73,0x73,0x73,0x30,0x7C,0x3F,0x1F,0x0F,0x0C,0x0F,0x3F,0x7F,0x78,0x00,
  44. 0x7F,0x7F,0x0F,0x0F,0x1F,0x3F,0x3F,0x7B,0x30,0x01,0x7F,0xFF,0xFF,0x00,0x00,0x00,
  45. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  46. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  47. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  48. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  49. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  50. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  51. 0x00,0x00,0x00,0x00};
  52. //======================================
  53. const unsigned char F6x8[][6] =
  54. {
  55.     { 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 },   // sp
  56.     { 0x00, 0x00, 0x00, 0x2f, 0x00, 0x00 },   // !
  57.     { 0x00, 0x00, 0x07, 0x00, 0x07, 0x00 },   // "
  58.     { 0x00, 0x14, 0x7f, 0x14, 0x7f, 0x14 },   // #
  59.     { 0x00, 0x24, 0x2a, 0x7f, 0x2a, 0x12 },   // $
  60.     { 0x00, 0x62, 0x64, 0x08, 0x13, 0x23 },   // %
  61.     { 0x00, 0x36, 0x49, 0x55, 0x22, 0x50 },   // &
  62.     { 0x00, 0x00, 0x05, 0x03, 0x00, 0x00 },   // '
  63.     { 0x00, 0x00, 0x1c, 0x22, 0x41, 0x00 },   // (
  64.     { 0x00, 0x00, 0x41, 0x22, 0x1c, 0x00 },   // )
  65.     { 0x00, 0x14, 0x08, 0x3E, 0x08, 0x14 },   // *
  66.     { 0x00, 0x08, 0x08, 0x3E, 0x08, 0x08 },   // +
  67.     { 0x00, 0x00, 0x00, 0xA0, 0x60, 0x00 },   // ,
  68.     { 0x00, 0x08, 0x08, 0x08, 0x08, 0x08 },   // -
  69.     { 0x00, 0x00, 0x60, 0x60, 0x00, 0x00 },   // .
  70.     { 0x00, 0x20, 0x10, 0x08, 0x04, 0x02 },   // /
  71.     { 0x00, 0x3E, 0x51, 0x49, 0x45, 0x3E },   // 0
  72.     { 0x00, 0x00, 0x42, 0x7F, 0x40, 0x00 },   // 1
  73.     { 0x00, 0x42, 0x61, 0x51, 0x49, 0x46 },   // 2
  74.     { 0x00, 0x21, 0x41, 0x45, 0x4B, 0x31 },   // 3
  75.     { 0x00, 0x18, 0x14, 0x12, 0x7F, 0x10 },   // 4
  76.     { 0x00, 0x27, 0x45, 0x45, 0x45, 0x39 },   // 5
  77.     { 0x00, 0x3C, 0x4A, 0x49, 0x49, 0x30 },   // 6
  78.     { 0x00, 0x01, 0x71, 0x09, 0x05, 0x03 },   // 7
  79.     { 0x00, 0x36, 0x49, 0x49, 0x49, 0x36 },   // 8
  80.     { 0x00, 0x06, 0x49, 0x49, 0x29, 0x1E },   // 9
  81.     { 0x00, 0x00, 0x36, 0x36, 0x00, 0x00 },   // :
  82.     { 0x00, 0x00, 0x56, 0x36, 0x00, 0x00 },   // ;
  83.     { 0x00, 0x08, 0x14, 0x22, 0x41, 0x00 },   // <
  84.     { 0x00, 0x14, 0x14, 0x14, 0x14, 0x14 },   // =
  85.     { 0x00, 0x00, 0x41, 0x22, 0x14, 0x08 },   // >
  86.     { 0x00, 0x02, 0x01, 0x51, 0x09, 0x06 },   // ?
  87.     { 0x00, 0x32, 0x49, 0x59, 0x51, 0x3E },   // @
  88.     { 0x00, 0x7C, 0x12, 0x11, 0x12, 0x7C },   // A
  89.     { 0x00, 0x7F, 0x49, 0x49, 0x49, 0x36 },   // B
  90.     { 0x00, 0x3E, 0x41, 0x41, 0x41, 0x22 },   // C
  91.     { 0x00, 0x7F, 0x41, 0x41, 0x22, 0x1C },   // D
  92.     { 0x00, 0x7F, 0x49, 0x49, 0x49, 0x41 },   // E
  93.     { 0x00, 0x7F, 0x09, 0x09, 0x09, 0x01 },   // F
  94.     { 0x00, 0x3E, 0x41, 0x49, 0x49, 0x7A },   // G
  95.     { 0x00, 0x7F, 0x08, 0x08, 0x08, 0x7F },   // H
  96.     { 0x00, 0x00, 0x41, 0x7F, 0x41, 0x00 },   // I
  97.     { 0x00, 0x20, 0x40, 0x41, 0x3F, 0x01 },   // J
  98.     { 0x00, 0x7F, 0x08, 0x14, 0x22, 0x41 },   // K
  99.     { 0x00, 0x7F, 0x40, 0x40, 0x40, 0x40 },   // L
  100.     { 0x00, 0x7F, 0x02, 0x0C, 0x02, 0x7F },   // M
  101.     { 0x00, 0x7F, 0x04, 0x08, 0x10, 0x7F },   // N
  102.     { 0x00, 0x3E, 0x41, 0x41, 0x41, 0x3E },   // O
  103.     { 0x00, 0x7F, 0x09, 0x09, 0x09, 0x06 },   // P
  104.     { 0x00, 0x3E, 0x41, 0x51, 0x21, 0x5E },   // Q
  105.     { 0x00, 0x7F, 0x09, 0x19, 0x29, 0x46 },   // R
  106.     { 0x00, 0x46, 0x49, 0x49, 0x49, 0x31 },   // S
  107.     { 0x00, 0x01, 0x01, 0x7F, 0x01, 0x01 },   // T
  108.     { 0x00, 0x3F, 0x40, 0x40, 0x40, 0x3F },   // U
  109.     { 0x00, 0x1F, 0x20, 0x40, 0x20, 0x1F },   // V
  110.     { 0x00, 0x3F, 0x40, 0x38, 0x40, 0x3F },   // W
  111.     { 0x00, 0x63, 0x14, 0x08, 0x14, 0x63 },   // X
  112.     { 0x00, 0x07, 0x08, 0x70, 0x08, 0x07 },   // Y
  113.     { 0x00, 0x61, 0x51, 0x49, 0x45, 0x43 },   // Z
  114.     { 0x00, 0x00, 0x7F, 0x41, 0x41, 0x00 },   // [
  115.     { 0x00, 0x55, 0x2A, 0x55, 0x2A, 0x55 },   // 55
  116.     { 0x00, 0x00, 0x41, 0x41, 0x7F, 0x00 },   // ]
  117.     { 0x00, 0x04, 0x02, 0x01, 0x02, 0x04 },   // ^
  118.     { 0x00, 0x40, 0x40, 0x40, 0x40, 0x40 },   // _
  119.     { 0x00, 0x00, 0x01, 0x02, 0x04, 0x00 },   // '
  120.     { 0x00, 0x20, 0x54, 0x54, 0x54, 0x78 },   // a
  121.     { 0x00, 0x7F, 0x48, 0x44, 0x44, 0x38 },   // b
  122.     { 0x00, 0x38, 0x44, 0x44, 0x44, 0x20 },   // c
  123.     { 0x00, 0x38, 0x44, 0x44, 0x48, 0x7F },   // d
  124.     { 0x00, 0x38, 0x54, 0x54, 0x54, 0x18 },   // e
  125.     { 0x00, 0x08, 0x7E, 0x09, 0x01, 0x02 },   // f
  126.     { 0x00, 0x18, 0xA4, 0xA4, 0xA4, 0x7C },   // g
  127.     { 0x00, 0x7F, 0x08, 0x04, 0x04, 0x78 },   // h
  128.     { 0x00, 0x00, 0x44, 0x7D, 0x40, 0x00 },   // i
  129.     { 0x00, 0x40, 0x80, 0x84, 0x7D, 0x00 },   // j
  130.     { 0x00, 0x7F, 0x10, 0x28, 0x44, 0x00 },   // k
  131.     { 0x00, 0x00, 0x41, 0x7F, 0x40, 0x00 },   // l
  132.     { 0x00, 0x7C, 0x04, 0x18, 0x04, 0x78 },   // m
  133.     { 0x00, 0x7C, 0x08, 0x04, 0x04, 0x78 },   // n
  134.     { 0x00, 0x38, 0x44, 0x44, 0x44, 0x38 },   // o
  135.     { 0x00, 0xFC, 0x24, 0x24, 0x24, 0x18 },   // p
  136.     { 0x00, 0x18, 0x24, 0x24, 0x18, 0xFC },   // q
  137.     { 0x00, 0x7C, 0x08, 0x04, 0x04, 0x08 },   // r
  138.     { 0x00, 0x48, 0x54, 0x54, 0x54, 0x20 },   // s
  139.     { 0x00, 0x04, 0x3F, 0x44, 0x40, 0x20 },   // t
  140.     { 0x00, 0x3C, 0x40, 0x40, 0x20, 0x7C },   // u
  141.     { 0x00, 0x1C, 0x20, 0x40, 0x20, 0x1C },   // v
  142.     { 0x00, 0x3C, 0x40, 0x30, 0x40, 0x3C },   // w
  143.     { 0x00, 0x44, 0x28, 0x10, 0x28, 0x44 },   // x
  144.     { 0x00, 0x1C, 0xA0, 0xA0, 0xA0, 0x7C },   // y
  145.     { 0x00, 0x44, 0x64, 0x54, 0x4C, 0x44 },   // z
  146.     { 0x14, 0x14, 0x14, 0x14, 0x14, 0x14 }    // horiz lines
  147. };
  148. const unsigned char F8X16[]=
  149. {
  150.   0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,// 0
  151.   0x00,0x00,0x00,0xF8,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x33,0x30,0x00,0x00,0x00,//!1
  152.   0x00,0x10,0x0C,0x06,0x10,0x0C,0x06,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,//"2
  153.   0x40,0xC0,0x78,0x40,0xC0,0x78,0x40,0x00,0x04,0x3F,0x04,0x04,0x3F,0x04,0x04,0x00,//#3
  154.   0x00,0x70,0x88,0xFC,0x08,0x30,0x00,0x00,0x00,0x18,0x20,0xFF,0x21,0x1E,0x00,0x00,//$4
  155.   0xF0,0x08,0xF0,0x00,0xE0,0x18,0x00,0x00,0x00,0x21,0x1C,0x03,0x1E,0x21,0x1E,0x00,//%5
  156.   0x00,0xF0,0x08,0x88,0x70,0x00,0x00,0x00,0x1E,0x21,0x23,0x24,0x19,0x27,0x21,0x10,//&6
  157.   0x10,0x16,0x0E,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,//'7
  158.   0x00,0x00,0x00,0xE0,0x18,0x04,0x02,0x00,0x00,0x00,0x00,0x07,0x18,0x20,0x40,0x00,//(8
  159.   0x00,0x02,0x04,0x18,0xE0,0x00,0x00,0x00,0x00,0x40,0x20,0x18,0x07,0x00,0x00,0x00,//)9
  160.   0x40,0x40,0x80,0xF0,0x80,0x40,0x40,0x00,0x02,0x02,0x01,0x0F,0x01,0x02,0x02,0x00,//*10
  161.   0x00,0x00,0x00,0xF0,0x00,0x00,0x00,0x00,0x01,0x01,0x01,0x1F,0x01,0x01,0x01,0x00,//+11
  162.   0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x80,0xB0,0x70,0x00,0x00,0x00,0x00,0x00,//,12
  163.   0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x01,0x01,0x01,0x01,0x01,0x01,//-13
  164.   0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x30,0x30,0x00,0x00,0x00,0x00,0x00,//.14
  165.   0x00,0x00,0x00,0x00,0x80,0x60,0x18,0x04,0x00,0x60,0x18,0x06,0x01,0x00,0x00,0x00,///15
  166.   0x00,0xE0,0x10,0x08,0x08,0x10,0xE0,0x00,0x00,0x0F,0x10,0x20,0x20,0x10,0x0F,0x00,//016
  167.   0x00,0x10,0x10,0xF8,0x00,0x00,0x00,0x00,0x00,0x20,0x20,0x3F,0x20,0x20,0x00,0x00,//117
  168.   0x00,0x70,0x08,0x08,0x08,0x88,0x70,0x00,0x00,0x30,0x28,0x24,0x22,0x21,0x30,0x00,//218
  169.   0x00,0x30,0x08,0x88,0x88,0x48,0x30,0x00,0x00,0x18,0x20,0x20,0x20,0x11,0x0E,0x00,//319
  170.   0x00,0x00,0xC0,0x20,0x10,0xF8,0x00,0x00,0x00,0x07,0x04,0x24,0x24,0x3F,0x24,0x00,//420
  171.   0x00,0xF8,0x08,0x88,0x88,0x08,0x08,0x00,0x00,0x19,0x21,0x20,0x20,0x11,0x0E,0x00,//521
  172.   0x00,0xE0,0x10,0x88,0x88,0x18,0x00,0x00,0x00,0x0F,0x11,0x20,0x20,0x11,0x0E,0x00,//622
  173.   0x00,0x38,0x08,0x08,0xC8,0x38,0x08,0x00,0x00,0x00,0x00,0x3F,0x00,0x00,0x00,0x00,//723
  174.   0x00,0x70,0x88,0x08,0x08,0x88,0x70,0x00,0x00,0x1C,0x22,0x21,0x21,0x22,0x1C,0x00,//824
  175.   0x00,0xE0,0x10,0x08,0x08,0x10,0xE0,0x00,0x00,0x00,0x31,0x22,0x22,0x11,0x0F,0x00,//925
  176.   0x00,0x00,0x00,0xC0,0xC0,0x00,0x00,0x00,0x00,0x00,0x00,0x30,0x30,0x00,0x00,0x00,//:26
  177.   0x00,0x00,0x00,0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x80,0x60,0x00,0x00,0x00,0x00,//;27
  178.   0x00,0x00,0x80,0x40,0x20,0x10,0x08,0x00,0x00,0x01,0x02,0x04,0x08,0x10,0x20,0x00,//<28
  179.   0x40,0x40,0x40,0x40,0x40,0x40,0x40,0x00,0x04,0x04,0x04,0x04,0x04,0x04,0x04,0x00,//=29
  180.   0x00,0x08,0x10,0x20,0x40,0x80,0x00,0x00,0x00,0x20,0x10,0x08,0x04,0x02,0x01,0x00,//>30
  181.   0x00,0x70,0x48,0x08,0x08,0x08,0xF0,0x00,0x00,0x00,0x00,0x30,0x36,0x01,0x00,0x00,//?31
  182.   0xC0,0x30,0xC8,0x28,0xE8,0x10,0xE0,0x00,0x07,0x18,0x27,0x24,0x23,0x14,0x0B,0x00,//@32
  183.   0x00,0x00,0xC0,0x38,0xE0,0x00,0x00,0x00,0x20,0x3C,0x23,0x02,0x02,0x27,0x38,0x20,//A33
  184.   0x08,0xF8,0x88,0x88,0x88,0x70,0x00,0x00,0x20,0x3F,0x20,0x20,0x20,0x11,0x0E,0x00,//B34
  185.   0xC0,0x30,0x08,0x08,0x08,0x08,0x38,0x00,0x07,0x18,0x20,0x20,0x20,0x10,0x08,0x00,//C35
  186.   0x08,0xF8,0x08,0x08,0x08,0x10,0xE0,0x00,0x20,0x3F,0x20,0x20,0x20,0x10,0x0F,0x00,//D36
  187.   0x08,0xF8,0x88,0x88,0xE8,0x08,0x10,0x00,0x20,0x3F,0x20,0x20,0x23,0x20,0x18,0x00,//E37
  188.   0x08,0xF8,0x88,0x88,0xE8,0x08,0x10,0x00,0x20,0x3F,0x20,0x00,0x03,0x00,0x00,0x00,//F38
  189.   0xC0,0x30,0x08,0x08,0x08,0x38,0x00,0x00,0x07,0x18,0x20,0x20,0x22,0x1E,0x02,0x00,//G39
  190.   0x08,0xF8,0x08,0x00,0x00,0x08,0xF8,0x08,0x20,0x3F,0x21,0x01,0x01,0x21,0x3F,0x20,//H40
  191.   0x00,0x08,0x08,0xF8,0x08,0x08,0x00,0x00,0x00,0x20,0x20,0x3F,0x20,0x20,0x00,0x00,//I41
  192.   0x00,0x00,0x08,0x08,0xF8,0x08,0x08,0x00,0xC0,0x80,0x80,0x80,0x7F,0x00,0x00,0x00,//J42
  193.   0x08,0xF8,0x88,0xC0,0x28,0x18,0x08,0x00,0x20,0x3F,0x20,0x01,0x26,0x38,0x20,0x00,//K43
  194.   0x08,0xF8,0x08,0x00,0x00,0x00,0x00,0x00,0x20,0x3F,0x20,0x20,0x20,0x20,0x30,0x00,//L44
  195.   0x08,0xF8,0xF8,0x00,0xF8,0xF8,0x08,0x00,0x20,0x3F,0x00,0x3F,0x00,0x3F,0x20,0x00,//M45
  196.   0x08,0xF8,0x30,0xC0,0x00,0x08,0xF8,0x08,0x20,0x3F,0x20,0x00,0x07,0x18,0x3F,0x00,//N46
  197.   0xE0,0x10,0x08,0x08,0x08,0x10,0xE0,0x00,0x0F,0x10,0x20,0x20,0x20,0x10,0x0F,0x00,//O47
  198.   0x08,0xF8,0x08,0x08,0x08,0x08,0xF0,0x00,0x20,0x3F,0x21,0x01,0x01,0x01,0x00,0x00,//P48
  199.   0xE0,0x10,0x08,0x08,0x08,0x10,0xE0,0x00,0x0F,0x18,0x24,0x24,0x38,0x50,0x4F,0x00,//Q49
  200.   0x08,0xF8,0x88,0x88,0x88,0x88,0x70,0x00,0x20,0x3F,0x20,0x00,0x03,0x0C,0x30,0x20,//R50
  201.   0x00,0x70,0x88,0x08,0x08,0x08,0x38,0x00,0x00,0x38,0x20,0x21,0x21,0x22,0x1C,0x00,//S51
  202.   0x18,0x08,0x08,0xF8,0x08,0x08,0x18,0x00,0x00,0x00,0x20,0x3F,0x20,0x00,0x00,0x00,//T52
  203.   0x08,0xF8,0x08,0x00,0x00,0x08,0xF8,0x08,0x00,0x1F,0x20,0x20,0x20,0x20,0x1F,0x00,//U53
  204.   0x08,0x78,0x88,0x00,0x00,0xC8,0x38,0x08,0x00,0x00,0x07,0x38,0x0E,0x01,0x00,0x00,//V54
  205.   0xF8,0x08,0x00,0xF8,0x00,0x08,0xF8,0x00,0x03,0x3C,0x07,0x00,0x07,0x3C,0x03,0x00,//W55
  206.   0x08,0x18,0x68,0x80,0x80,0x68,0x18,0x08,0x20,0x30,0x2C,0x03,0x03,0x2C,0x30,0x20,//X56
  207.   0x08,0x38,0xC8,0x00,0xC8,0x38,0x08,0x00,0x00,0x00,0x20,0x3F,0x20,0x00,0x00,0x00,//Y57
  208.   0x10,0x08,0x08,0x08,0xC8,0x38,0x08,0x00,0x20,0x38,0x26,0x21,0x20,0x20,0x18,0x00,//Z58
  209.   0x00,0x00,0x00,0xFE,0x02,0x02,0x02,0x00,0x00,0x00,0x00,0x7F,0x40,0x40,0x40,0x00,//[59
  210.   0x00,0x0C,0x30,0xC0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x06,0x38,0xC0,0x00,//\60
  211.   0x00,0x02,0x02,0x02,0xFE,0x00,0x00,0x00,0x00,0x40,0x40,0x40,0x7F,0x00,0x00,0x00,//]61
  212.   0x00,0x00,0x04,0x02,0x02,0x02,0x04,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,//^62
  213.   0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,//_63
  214.   0x00,0x02,0x02,0x04,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,//`64
  215.   0x00,0x00,0x80,0x80,0x80,0x80,0x00,0x00,0x00,0x19,0x24,0x22,0x22,0x22,0x3F,0x20,//a65
  216.   0x08,0xF8,0x00,0x80,0x80,0x00,0x00,0x00,0x00,0x3F,0x11,0x20,0x20,0x11,0x0E,0x00,//b66
  217.   0x00,0x00,0x00,0x80,0x80,0x80,0x00,0x00,0x00,0x0E,0x11,0x20,0x20,0x20,0x11,0x00,//c67
  218.   0x00,0x00,0x00,0x80,0x80,0x88,0xF8,0x00,0x00,0x0E,0x11,0x20,0x20,0x10,0x3F,0x20,//d68
  219.   0x00,0x00,0x80,0x80,0x80,0x80,0x00,0x00,0x00,0x1F,0x22,0x22,0x22,0x22,0x13,0x00,//e69
  220.   0x00,0x80,0x80,0xF0,0x88,0x88,0x88,0x18,0x00,0x20,0x20,0x3F,0x20,0x20,0x00,0x00,//f70
  221.   0x00,0x00,0x80,0x80,0x80,0x80,0x80,0x00,0x00,0x6B,0x94,0x94,0x94,0x93,0x60,0x00,//g71
  222.   0x08,0xF8,0x00,0x80,0x80,0x80,0x00,0x00,0x20,0x3F,0x21,0x00,0x00,0x20,0x3F,0x20,//h72
  223.   0x00,0x80,0x98,0x98,0x00,0x00,0x00,0x00,0x00,0x20,0x20,0x3F,0x20,0x20,0x00,0x00,//i73
  224.   0x00,0x00,0x00,0x80,0x98,0x98,0x00,0x00,0x00,0xC0,0x80,0x80,0x80,0x7F,0x00,0x00,//j74
  225.   0x08,0xF8,0x00,0x00,0x80,0x80,0x80,0x00,0x20,0x3F,0x24,0x02,0x2D,0x30,0x20,0x00,//k75
  226.   0x00,0x08,0x08,0xF8,0x00,0x00,0x00,0x00,0x00,0x20,0x20,0x3F,0x20,0x20,0x00,0x00,//l76
  227.   0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x00,0x20,0x3F,0x20,0x00,0x3F,0x20,0x00,0x3F,//m77
  228.   0x80,0x80,0x00,0x80,0x80,0x80,0x00,0x00,0x20,0x3F,0x21,0x00,0x00,0x20,0x3F,0x20,//n78
  229.   0x00,0x00,0x80,0x80,0x80,0x80,0x00,0x00,0x00,0x1F,0x20,0x20,0x20,0x20,0x1F,0x00,//o79
  230.   0x80,0x80,0x00,0x80,0x80,0x00,0x00,0x00,0x80,0xFF,0xA1,0x20,0x20,0x11,0x0E,0x00,//p80
  231.   0x00,0x00,0x00,0x80,0x80,0x80,0x80,0x00,0x00,0x0E,0x11,0x20,0x20,0xA0,0xFF,0x80,//q81
  232.   0x80,0x80,0x80,0x00,0x80,0x80,0x80,0x00,0x20,0x20,0x3F,0x21,0x20,0x00,0x01,0x00,//r82
  233.   0x00,0x00,0x80,0x80,0x80,0x80,0x80,0x00,0x00,0x33,0x24,0x24,0x24,0x24,0x19,0x00,//s83
  234.   0x00,0x80,0x80,0xE0,0x80,0x80,0x00,0x00,0x00,0x00,0x00,0x1F,0x20,0x20,0x00,0x00,//t84
  235.   0x80,0x80,0x00,0x00,0x00,0x80,0x80,0x00,0x00,0x1F,0x20,0x20,0x20,0x10,0x3F,0x20,//u85
  236.   0x80,0x80,0x80,0x00,0x00,0x80,0x80,0x80,0x00,0x01,0x0E,0x30,0x08,0x06,0x01,0x00,//v86
  237.   0x80,0x80,0x00,0x80,0x00,0x80,0x80,0x80,0x0F,0x30,0x0C,0x03,0x0C,0x30,0x0F,0x00,//w87
  238.   0x00,0x80,0x80,0x00,0x80,0x80,0x80,0x00,0x00,0x20,0x31,0x2E,0x0E,0x31,0x20,0x00,//x88
  239.   0x80,0x80,0x80,0x00,0x00,0x80,0x80,0x80,0x80,0x81,0x8E,0x70,0x18,0x06,0x01,0x00,//y89
  240.   0x00,0x80,0x80,0x80,0x80,0x80,0x80,0x00,0x00,0x21,0x30,0x2C,0x22,0x21,0x30,0x00,//z90
  241.   0x00,0x00,0x00,0x00,0x80,0x7C,0x02,0x02,0x00,0x00,0x00,0x00,0x00,0x3F,0x40,0x40,//{91
  242.   0x00,0x00,0x00,0x00,0xFF,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xFF,0x00,0x00,0x00,//|92
  243.   0x00,0x02,0x02,0x7C,0x80,0x00,0x00,0x00,0x00,0x40,0x40,0x3F,0x00,0x00,0x00,0x00,//}93
  244.   0x00,0x06,0x01,0x01,0x02,0x02,0x04,0x04,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,//~94
  245. };
  246. void LCD_WrDat(unsigned char dat)
  247. {
  248.         unsigned char i=8;
  249.         //LCD_CS=0;;
  250.         LCD_DC_1;;
  251.   LCD_SCL_0;;
  252.   //;;
  253.   while(i--)
  254.   {
  255.     if(dat&0x80){LCD_SDA_1;}
  256.     else{LCD_SDA_0;}
  257.     LCD_SCL_1;
  258.     ;;;
  259.                 //;;
  260.     LCD_SCL_0;;
  261.     dat<<=1;
  262.   }
  263.         //LCD_CS=1;
  264. }
  265. void LCD_WrCmd(unsigned char cmd)
  266. {
  267.         unsigned char i=8;
  268.
  269.         //LCD_CS=0;;
  270.         LCD_DC_0;;
  271.   LCD_SCL_0;;
  272.   //;;
  273.   while(i--)
  274.   {
  275.     if(cmd&0x80){LCD_SDA_1;}
  276.     else{LCD_SDA_0;;}
  277.     LCD_SCL_1;;
  278.     ;;;
  279.                 //;;
  280.     LCD_SCL_0;;
  281.     cmd<<=1;;
  282.   }
  283.         //LCD_CS=1;
  284. }
  285. void LCD_Set_Pos(unsigned char x, unsigned char y)
  286. {
  287.   LCD_WrCmd(0xb0+y);
  288.   LCD_WrCmd(((x&0xf0)>>4)|0x10);
  289.   LCD_WrCmd((x&0x0f)|0x00);
  290. }
  291. void LCD_Fill(unsigned char bmp_dat)
  292. {
  293.         unsigned char y,x;
  294.
  295.         for(y=0;y<8;y++)
  296.         {
  297.                 LCD_WrCmd(0xb0+y);
  298.                 LCD_WrCmd(0x01);
  299.                 LCD_WrCmd(0x10);
  300.                 for(x=0;x<X_WIDTH;x++)
  301.                         LCD_WrDat(bmp_dat);
  302.         }
  303. }
  304. void LCD_CLS(void)
  305. {
  306.         unsigned char y,x;
  307.         for(y=0;y<8;y++)
  308.         {
  309.                 LCD_WrCmd(0xb0+y);
  310.                 LCD_WrCmd(0x01);
  311.                 LCD_WrCmd(0x10);
  312.                 for(x=0;x<X_WIDTH;x++)
  313.                         LCD_WrDat(0);
  314.         }
  315. }
  316. void LCD_DLY_ms(unsigned int ms)
  317. {
  318.         unsigned int i;
  319.         while(ms--)
  320.         {
  321.                 //GCC_DELAY(2000);//编译器自带延时指定个周期,在主频8Mhz下,一个指令周期为0.5us
  322.                 //GCC_CLRWDT();
  323.                 for(i=0;i<60000;i++);
  324.         }
  325. }
  326. void LCD_Init(void)
  327. {
  328.
  329.         LCD_SCL_1;
  330.         //LCD_CS=1;        //预制SLK和SS为高电平
  331.         LCD_RST_0;
  332.         LCD_DLY_ms(50);
  333.         LCD_RST_1;
  334.
  335.         //从上电到下面开始初始化要有足够的时间,即等待RC复位完毕
  336.
  337.   LCD_WrCmd(0xae);//--turn off oled panel
  338.   LCD_WrCmd(0x00);//---set low column address
  339.   LCD_WrCmd(0x10);//---set high column address
  340.   LCD_WrCmd(0x40);//--set start line address  Set Mapping RAM Display Start Line (0x00~0x3F)
  341.   LCD_WrCmd(0x81);//--set contrast control register
  342.   LCD_WrCmd(0xcf); // Set SEG Output Current Brightness
  343.   LCD_WrCmd(0xa1);//--Set SEG/Column Mapping     0xa0左右反置 0xa1正常
  344.   LCD_WrCmd(0xc8);//Set COM/Row Scan Direction   0xc0上下反置 0xc8正常
  345.   LCD_WrCmd(0xa6);//--set normal display
  346.   LCD_WrCmd(0xa8);//--set multiplex ratio(1 to 64)
  347.   LCD_WrCmd(0x3f);//--1/64 duty
  348.   LCD_WrCmd(0xd3);//-set display offset        Shift Mapping RAM Counter (0x00~0x3F)
  349.   LCD_WrCmd(0x00);//-not offset
  350.   LCD_WrCmd(0xd5);//--set display clock divide ratio/oscillator frequency
  351.   LCD_WrCmd(0x80);//--set divide ratio, Set Clock as 100 Frames/Sec
  352.   LCD_WrCmd(0xd9);//--set pre-charge period
  353.   LCD_WrCmd(0xf1);//Set Pre-Charge as 15 Clocks & Discharge as 1 Clock
  354.   LCD_WrCmd(0xda);//--set com pins hardware configuration
  355.   LCD_WrCmd(0x12);
  356.   LCD_WrCmd(0xdb);//--set vcomh
  357.   LCD_WrCmd(0x40);//Set VCOM Deselect Level
  358.   LCD_WrCmd(0x20);//-Set Page Addressing Mode (0x00/0x01/0x02)
  359.   LCD_WrCmd(0x02);//
  360.   LCD_WrCmd(0x8d);//--set Charge Pump enable/disable
  361.   LCD_WrCmd(0x14);//--set(0x10) disable
  362.   LCD_WrCmd(0xa4);// Disable Entire Display On (0xa4/0xa5)
  363.   LCD_WrCmd(0xa6);// Disable Inverse Display On (0xa6/a7)
  364.   LCD_WrCmd(0xaf);//--turn on oled panel
  365.   LCD_Fill(0x00);  //初始清屏
  366.   LCD_Set_Pos(0,0);
  367. }
  368. //==============================================================
  369. //函数名: void LCD_PutPixel(byte x,byte y)
  370. //功能描述:绘制一个点(x,y)
  371. //参数:真实坐标值(x,y),x的范围0~127,y的范围0~64
  372. //返回:无
  373. //==============================================================
  374. void LCD_PutPixel(unsigned char  x,unsigned char  y)
  375. {
  376.         unsigned char  data1;  //data1当前点的数据
  377.
  378.   LCD_Set_Pos(x,y);
  379.         data1 = 0x01<<(y%8);
  380.         LCD_WrCmd(0xb0+(y>>3));
  381.         LCD_WrCmd(((x&0xf0)>>4)|0x10);
  382.         LCD_WrCmd((x&0x0f)|0x00);
  383.         LCD_WrDat(data1);
  384. }
  385. //==============================================================
  386. //函数名: void LCD_Rectangle(byte x1,byte y1,
  387. //                   byte x2,byte y2,byte color,byte gif)
  388. //功能描述:绘制一个实心矩形
  389. //参数:左上角坐标(x1,y1),右下角坐标(x2,y2)
  390. //      其中x1、x2的范围0~127,y1,y2的范围0~63,即真实坐标值
  391. //返回:无
  392. //==============================================================
  393. void LCD_Rectangle(unsigned char  x1,unsigned char  y1,unsigned char  x2,unsigned char  y2,unsigned char  gif)
  394. {
  395.         unsigned char  n;
  396.
  397.         LCD_Set_Pos(x1,y1>>3);
  398.         for(n=x1;n<=x2;n++)
  399.         {
  400.                 LCD_WrDat(0x01<<(y1%8));
  401.                 if(gif == 1)         LCD_DLY_ms(50);
  402.         }
  403.         LCD_Set_Pos(x1,y2>>3);
  404.   for(n=x1;n<=x2;n++)
  405.         {
  406.                 LCD_WrDat(0x01<<(y2%8));
  407.                 if(gif == 1)         LCD_DLY_ms(5);
  408.         }
  409.
  410. }
  411. //==============================================================
  412. //函数名:LCD_P6x8Str(unsigned char x,unsigned char y,unsigned char *p)
  413. //功能描述:写入一组标准ASCII字符串
  414. //参数:显示的位置(x,y),y为页范围0~7,要显示的字符串
  415. //返回:无
  416. //==============================================================
  417. void LCD_P6x8Str(unsigned char x,unsigned char y,unsigned char ch[])
  418. {
  419.   unsigned char c=0,i=0,j=0;
  420.   while (ch[j]!='\0')
  421.   {
  422.     c =ch[j]-32;
  423.     if(x>126){x=0;y++;}
  424.     LCD_Set_Pos(x,y);
  425.           for(i=0;i<6;i++)
  426.             LCD_WrDat(F6x8[c][i]);
  427.           x+=6;
  428.           j++;
  429.   }
  430. }
  431. void LCD_P8x16Str(unsigned char x,unsigned char y,unsigned char ch[])
  432. {
  433.   unsigned char c=0,i=0,j=0;
  434.
  435.   while (ch[j]!='\0')
  436.   {
  437.     c =ch[j]-32;
  438.     if(x>120){x=0;y++;}
  439.     LCD_Set_Pos(x,y);
  440.           for(i=0;i<8;i++)
  441.             LCD_WrDat(F8X16[c*16+i]);
  442.           LCD_Set_Pos(x,y+1);
  443.           for(i=0;i<8;i++)
  444.             LCD_WrDat(F8X16[c*16+i+8]);
  445.           x+=8;
  446.           j++;
  447.   }
  448. }
  449. //==============================================================
  450. //函数名: void Draw_BMP(byte x,byte y)
  451. //功能描述:显示BMP图片128×64
  452. //参数:起始点坐标(x,y),x的范围0~127,y为页的范围0~7
  453. //返回:无
  454. //==============================================================
  455. void Draw_BMP(unsigned char  x0,unsigned char  y0,unsigned char  x1,unsigned char  y1,unsigned char bmp[])
  456. {
  457.   unsigned int  ii=0;
  458.   unsigned char  x,y;
  459.
  460.           if(y1%8==0) y=y1/8;
  461.           else y=y1/8+1;
  462.         for(y=y0;y<=y1;y++)
  463.         {
  464.                 LCD_Set_Pos(x0,y);
  465.             for(x=x0;x<x1;x++)
  466.             {
  467.                     LCD_WrDat(bmp[ii++]);
  468.             }
  469.         }
  470. }
运行效果图:
xyz549040622 发表于 2024-6-29 08:10 | 显示全部楼层
其实最主要的还是时序,只要时序对了,oled的驱动还是很轻松的。话说,市面上的液晶驱动芯片也就那么几种,熟悉了也是很简单的。
