复制官方的例程“UART_Transmit_and_Receive”到自己的工程目录下,并且修改为my_uart_test
点击添加新的工程,选择工程所在的目录
等待一段时间,让MTB构建好工程
修改代码,让MCU接收到字符串 "Hello, CYW920829." 后会返回 "Hi, my friend!"
- #include "cyhal.h"
- #include "cybsp.h"
- #include "cy_retarget_io.h"
- #include <string.h>
- * Function Name: handle_error
- * Summary:
- * User defined error handling function.
- * Parameters:
- * void
- * Return:
- * void
- void handle_error(void)
- /* Disable all interrupts. */
- __disable_irq();
- CY_ASSERT(0);
- * Function Name: main
- * Summary:
- * This is the main function.
- * Reads one byte from the serial terminal and echoes back the read byte.
- * Parameters:
- * void
- * Return:
- * int
- int main(void)
- cy_rslt_t result;
- #if defined(CY_DEVICE_SECURE)
- cyhal_wdt_t wdt_obj;
- /* Clear watchdog timer so that it doesn't trigger a reset */
- result = cyhal_wdt_init(&wdt_obj, cyhal_wdt_get_max_timeout_ms());
- CY_ASSERT(CY_RSLT_SUCCESS == result);
- cyhal_wdt_free(&wdt_obj);
- #endif
- uint8_t read_data; /* Variable to store the received character
- * through terminal */
- uint8_t str_buff[50] = {0};
- char * cmp_str = "Hello, CYW920829.";
- char * my_ack = "Hi, my friend!";
- uint8_t index = 0;
- uint8_t start_recv = 1;
- /* Initialize the device and board peripherals */
- result = cybsp_init();
- if (result != CY_RSLT_SUCCESS)
- handle_error();
- /* Initialize retarget-io to use the debug UART port */
- result = cy_retarget_io_init_fc(CYBSP_DEBUG_UART_TX,
- CYBSP_DEBUG_UART_RX,
- CYBSP_DEBUG_UART_CTS,
- CYBSP_DEBUG_UART_RTS,
- CY_RETARGET_IO_BAUDRATE);
- handle_error();
- /* \x1b[2J\x1b[;H - ANSI ESC sequence for clear screen */
- printf("\x1b[2J\x1b[;H");
- printf("***********************************************************\r\n");
- printf("HAL: UART Transmit and Receive\r\n");
- printf("***********************************************************\r\n\n");
- printf(">> Start typing to see the echo on the screen \r\n\n");
- __enable_irq();
- for (;;)
- if (CY_RSLT_SUCCESS == cyhal_uart_getc(&cy_retarget_io_uart_obj,
- &read_data, 0))
- if (read_data == cmp_str[0])
- index = 0;
- start_recv = 0;
- memset(str_buff, 0, sizeof(str_buff));
- if (start_recv == 0)
- str_buff[index++] = read_data;
- if (index == strlen(cmp_str))
- start_recv = 1;
- if(0 == strcmp((char *)str_buff, cmp_str))
- for (uint8_t i=0; i < (strlen(my_ack) - 1); ++i)
- cyhal_uart_putc(&cy_retarget_io_uart_obj, my_ack[i]);
- printf("\r\n");
- else
- printf("request err\r\n");
- else
- handle_error();
测试效果如下:
