USART 和 DMA 硬件初始化配置
#define LUMMOD_UART USART3
#define LUMMOD_UART_GPIO GPIOC
#define LUMMOD_UART_CLK RCC_APB1Periph_USART3
#define LUMMOD_UART_GPIO_CLK RCC_APB2Periph_GPIOC
#define LUMMOD_UART_RxPin GPIO_Pin_11
#define LUMMOD_UART_TxPin GPIO_Pin_10
#define LUMMOD_UART_IRQn USART3_IRQn
#define LUMMOD_UART_DR_Base (USART3_BASE + 0x4) //0x40013804
#define LUMMOD_UART_Tx_DMA_Channel DMA1_Channel2
#define LUMMOD_UART_Tx_DMA_FLAG DMA1_FLAG_GL2//DMA1_FLAG_TC2 | DMA1_FLAG_TE2
#define LUMMOD_UART_Tx_DMA_IRQ DMA1_Channel2_IRQn
#define LUMMOD_UART_Rx_DMA_Channel DMA1_Channel3
#define LUMMOD_UART_Rx_DMA_FLAG DMA1_FLAG_GL3//DMA1_FLAG_TC3 | DMA1_FLAG_TE3
#define LUMMOD_UART_Rx_DMA_IRQ DMA1_Channel3_IRQn
void Uart_Init(void)
NVIC_InitTypeDef NVIC_InitStructure;
USART_InitTypeDef USART_InitStructure;
/* System Clocks Configuration */
/* Enable GPIO clock */
RCC_APB2PeriphClockCmd(LUMMOD_UART_GPIO_CLK , ENABLE ); // 开启串口所在IO端口的时钟
/* Enable USART Clock */
RCC_APB1PeriphClockCmd(LUMMOD_UART_CLK, ENABLE); // 开始串口时钟
/* Configure the NVIC Preemption Priority Bits */
NVIC_PriorityGroupConfig(NVIC_PriorityGroup_3);
/* Enable the DMA Interrupt */
NVIC_InitStructure.NVIC_IRQChannel = LUMMOD_UART_Tx_DMA_IRQ; // 发送DMA通道的中断配置
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 2; // 优先级设置
NVIC_InitStructure.NVIC_IRQChannelSubPriority = 1;
NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
NVIC_Init(&NVIC_InitStructure);
/* Enable the USART Interrupt */
NVIC_InitStructure.NVIC_IRQChannel = LUMMOD_UART_IRQn; // 串口中断配置
NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;
GPIO_PinRemapConfig(GPIO_PartialRemap_USART3, ENABLE); // 我这里没有用默认IO口,所以进行了重新映射,这个可以根据自己的硬件情况配置选择
/* Configure USART3 Rx as input floating */
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU; // 串口接收IO口的设置
GPIO_InitStructure.GPIO_Pin = LUMMOD_UART_RxPin;
GPIO_Init(LUMMOD_UART_GPIO, &GPIO_InitStructure);
/* Configure USART3 Tx as alternate function push-pull */
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; // 串口发送IO口的设置
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; // 这里设置成复用形式的推挽输出
GPIO_InitStructure.GPIO_Pin = LUMMOD_UART_TxPin;
DMA_Uart_Init(); // 串口 DMA 配置
USART_InitStructure.USART_WordLength = USART_WordLength_8b; // 串口格式配置
USART_InitStructure.USART_StopBits = USART_StopBits_1;
USART_InitStructure.USART_Parity = USART_Parity_No;
USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;
USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;
/* Configure USART3 */
USART_InitStructure.USART_BaudRate = 115200; // 波特率设置
USART_Init(LUMMOD_UART, &USART_InitStructure);
/* Enable USART3 Receive and Transmit interrupts */
USART_ITConfig(LUMMOD_UART, USART_IT_IDLE, ENABLE); // 开启 串口空闲IDEL 中断
/* Enable the USART3 */
USART_Cmd(LUMMOD_UART, ENABLE); // 开启串口
/* Enable USARTy DMA TX request */
USART_DMACmd(LUMMOD_UART, USART_DMAReq_Tx, ENABLE); // 开启串口DMA发送
USART_DMACmd(LUMMOD_UART, USART_DMAReq_Rx, ENABLE); // 开启串口DMA接收
void DMA_Uart_Init(void)
DMA_InitTypeDef DMA_InitStructure;
/* DMA clock enable */
RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA1, ENABLE); // 开启DMA1时钟
/*--- LUMMOD_UART_Tx_DMA_Channel DMA Config ---*/
DMA_Cmd(LUMMOD_UART_Tx_DMA_Channel, DISABLE); // 关DMA通道
DMA_DeInit(LUMMOD_UART_Tx_DMA_Channel); // 恢复缺省值
DMA_InitStructure.DMA_PeripheralBaseAddr = (uint32_t)(&LUMMOD_UART->DR);// 设置串口发送数据寄存器
DMA_InitStructure.DMA_MemoryBaseAddr = (uint32_t)LumMod_Tx_Buf; // 设置发送缓冲区首地址
DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralDST; // 设置外设位目标,内存缓冲区 -> 外设寄存器
DMA_InitStructure.DMA_BufferSize = LUMMOD_TX_BSIZE; // 需要发送的字节数,这里其实可以设置为0,因为在实际要发送的时候,会重新设置次值
DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable; // 外设地址不做增加调整,调整不调整是DMA自动实现的
DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable; // 内存缓冲区地址增加调整
DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_Byte; // 外设数据宽度8位,1个字节
DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_Byte; // 内存数据宽度8位,1个字节
DMA_InitStructure.DMA_Mode = DMA_Mode_Normal; // 单次传输模式
DMA_InitStructure.DMA_Priority = DMA_Priority_VeryHigh; // 优先级设置
DMA_InitStructure.DMA_M2M = DMA_M2M_Disable; // 关闭内存到内存的DMA模式
DMA_Init(LUMMOD_UART_Tx_DMA_Channel, &DMA_InitStructure); // 写入配置
DMA_ClearFlag(LUMMOD_UART_Tx_DMA_FLAG); // 清除DMA所有标志
DMA_Cmd(LUMMOD_UART_Tx_DMA_Channel, DISABLE); // 关闭DMA
DMA_ITConfig(LUMMOD_UART_Tx_DMA_Channel, DMA_IT_TC, ENABLE); // 开启发送DMA通道中断
/*--- LUMMOD_UART_Rx_DMA_Channel DMA Config ---*/
DMA_Cmd(LUMMOD_UART_Rx_DMA_Channel, DISABLE); // 关DMA通道
DMA_DeInit(LUMMOD_UART_Rx_DMA_Channel); // 恢复缺省值
DMA_InitStructure.DMA_PeripheralBaseAddr = (uint32_t)(&LUMMOD_UART->DR);// 设置串口接收数据寄存器
DMA_InitStructure.DMA_MemoryBaseAddr = (uint32_t)LumMod_Rx_Buf; // 设置接收缓冲区首地址
DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralSRC; // 设置外设为数据源,外设寄存器 -> 内存缓冲区
DMA_InitStructure.DMA_BufferSize = LUMMOD_RX_BSIZE; // 需要最大可能接收到的字节数
DMA_Init(LUMMOD_UART_Rx_DMA_Channel, &DMA_InitStructure); // 写入配置
DMA_ClearFlag(LUMMOD_UART_Rx_DMA_FLAG); // 清除DMA所有标志
DMA_Cmd(LUMMOD_UART_Rx_DMA_Channel, ENABLE); // 开启接收DMA通道,等待接收数据
void BSP_Init(void)
Uart_Init();
