GD32E230作为IIC从机时接收数据会卡顿是什么原因
 楼主| Henry-hu 发表于 2024-8-29 13:42 | 显示全部楼层 |阅读模式
在配置完成IIC从机模式后,主机向从机发送9位数据,在从机收到数据后主函数的代码会跑不到,不知道在什么地方造成了阻塞,接收完毕会产生多次的STPDEF中断吗,但是IIC从机模式的故障应该也不会影响到主函数的运行才对,有没有懂的大佬帮忙分析一下谢谢,代码如下#include "gd32e230.h"
#define MSG_RECV_BYTE_SUM 9
#define MSG_SEND_BYTE_SUM 6
#define I2C0_OWN_ADDRESS7 0x44
void iic_msg_gpio_config_init(void)
    /* enable GPIOB clock */
    rcu_periph_clock_enable(RCU_GPIOB);
    /* enable I2C0 clock */
    rcu_periph_clock_enable(RCU_I2C0);
    /* connect PB6 to I2C0_SCL */
    gpio_af_set(GPIOB, GPIO_AF_1, GPIO_PIN_6);
    /* connect PB7 to I2C0_SDA */
    gpio_af_set(GPIOB, GPIO_AF_1, GPIO_PIN_7);
    /* configure GPIO pins of I2C0 */
    gpio_mode_set(GPIOB, GPIO_MODE_AF, GPIO_PUPD_PULLUP, GPIO_PIN_6);
    gpio_output_options_set(GPIOB, GPIO_OTYPE_OD, GPIO_OSPEED_50MHZ, GPIO_PIN_6);
    gpio_mode_set(GPIOB, GPIO_MODE_AF, GPIO_PUPD_PULLUP, GPIO_PIN_7);
    gpio_output_options_set(GPIOB, GPIO_OTYPE_OD, GPIO_OSPEED_50MHZ, GPIO_PIN_7);
    /* I2C clock configure */
    i2c_clock_config(I2C0, 400000, I2C_DTCY_2);
    /* I2C address configure */
    i2c_mode_addr_config(I2C0, I2C_I2CMODE_ENABLE, I2C_ADDFORMAT_7BITS, I2C0_OWN_ADDRESS7);
    /* enable I2C0 */
    i2c_enable(I2C0);
    /* enable acknowledge */
    i2c_ack_config(I2C0, I2C_ACK_ENABLE);
    nvic_irq_enable(I2C0_EV_IRQn, 23);
    nvic_irq_enable(I2C0_ER_IRQn, 32);
    /* enable the I2C0 interrupt */
    i2c_interrupt_enable(I2C0, I2C_INT_ERR);
    i2c_interrupt_enable(I2C0, I2C_INT_EV);
    i2c_interrupt_enable(I2C0, I2C_INT_BUF);
void i2c0_event_irq_handler(void)
    if (i2c_interrupt_flag_get(I2C0, I2C_INT_FLAG_ADDSEND))
        // 0:接收端
        // 1:发送端
        tI2cSlave.uFlag.Bits.DirState = i2c_flag_get(I2C0, I2C_FLAG_TR);
        if (tI2cSlave.uFlag.Bits.DirState == RESET)
            msg_iic_recv_buf_count = 0;
            for (uint8_t i = 0; i < MSG_RECV_BYTE_SUM; i++)
                i2c_rxbuffer1[i = 0;
        else
            /* clear I2C_TDATA register */
            i2c_flag_clear(I2C0, I2C_FLAG_TBE);
            slave_msg_send.soft_versions = 0x00;
            i2c_txbuffer[0 = slave_msg_send.soft_versions;
            i2c_txbuffer[1 = slave_msg_send.KEY_state;
            slave_msg_send.reserved_1 = 0x00;
            slave_msg_send.reserved_2 = 0x00;
            slave_msg_send.reserved_3 = 0x00;
            i2c_txbuffer[2 = slave_msg_send.reserved_1;
            i2c_txbuffer[3 = slave_msg_send.reserved_2;
            i2c_txbuffer[4 = slave_msg_send.reserved_3;
            slave_msg_send.check_sum = 0;
            uint32_t cheak = 0;
            cheak += i2c_txbuffer[0];
            cheak += i2c_txbuffer[1];
            cheak += i2c_txbuffer[2];
            cheak += i2c_txbuffer[3];
            cheak += i2c_txbuffer[4];
            cheak = ~cheak;
            cheak = cheak + 1;
            i2c_txbuffer[5 = cheak;
            slave_msg_send.check_sum = cheak;
            msg_iic_send_buf_count = 0;
        /* clear the ADDSEND bit */
        i2c_interrupt_flag_clear(I2C0, I2C_INT_FLAG_ADDSEND);
    else if (i2c_interrupt_flag_get(I2C0, I2C_INT_FLAG_RBNE)) // && dma_flag_get(DMA_RX_CH, DMA_FLAG_FTF)
        if (msg_iic_recv_buf_count < MSG_RECV_BYTE_SUM)
            i2c_rxbuffer1[msg_iic_recv_buf_count = i2c_data_receive(I2C0);
            if (msg_iic_recv_buf_count == (MSG_RECV_BYTE_SUM - 1))
                UpdateReceiveProc();
            ++msg_iic_recv_buf_count;
        else
    else if ((i2c_interrupt_flag_get(I2C0, I2C_INT_FLAG_TBE))) // && dma_flag_get(DMA_TX_CH, DMA_FLAG_FTF)
        /* send a data byte */
        if (msg_iic_send_buf_count < MSG_SEND_BYTE_SUM)
            /* if reception data register is not empty, I2C0 will read a data from I2C_RDATA */
            i2c_data_transmit(I2C0, i2c_txbuffer[msg_iic_send_buf_count]);
            msg_iic_send_buf_count++;
        else
            i2c_data_transmit(I2C0, 0xff);
    else if (i2c_interrupt_flag_get(I2C0, I2C_INT_FLAG_STPDET))
        /* clear STPDET interrupt flag */
        i2c_interrupt_flag_clear(I2C0, I2C_INT_FLAG_STPDET);
            tI2cSlave.uFlag.Bits.RecSuccess = SUCCESS;
            msg_iic_recv_buf_count = 0x00;
        else
            tI2cSlave.uFlag.Bits.SendSuccess = SUCCESS;
            tI2cSlave.SendSize = 0x00; // 避免没有接收到命令重新发数据
            msg_iic_send_buf_count = 0x00;
        i2c_enable(I2C0);
    else if (i2c_interrupt_flag_get(I2C0, I2C_INT_FLAG_AERR))
        i2c_interrupt_flag_clear(I2C0, I2C_INT_FLAG_AERR);
void i2c0_error_irq_handler(void)
    /* no acknowledge received */
    /* SMBus alert */
    if (i2c_interrupt_flag_get(I2C0, I2C_INT_FLAG_SMBALT))
        i2c_interrupt_flag_clear(I2C0, I2C_INT_FLAG_SMBALT);
    /* bus timeout in SMBus mode */
    if (i2c_interrupt_flag_get(I2C0, I2C_INT_FLAG_SMBTO))
        i2c_interrupt_flag_clear(I2C0, I2C_INT_FLAG_SMBTO);
    /* over-run or under-run when SCL stretch is disabled */
    if (i2c_interrupt_flag_get(I2C0, I2C_INT_FLAG_OUERR))
        i2c_interrupt_flag_clear(I2C0, I2C_INT_FLAG_OUERR);
    /* arbitration lost */
    if (i2c_interrupt_flag_get(I2C0, I2C_INT_FLAG_LOSTARB))
        i2c_interrupt_flag_clear(I2C0, I2C_INT_FLAG_LOSTARB);
    /* bus error */
    if (i2c_interrupt_flag_get(I2C0, I2C_INT_FLAG_BERR))
        i2c_interrupt_flag_clear(I2C0, I2C_INT_FLAG_BERR);
    /* CRC value doesn't match */
    if (i2c_interrupt_flag_get(I2C0, I2C_INT_FLAG_PECERR))
        i2c_interrupt_flag_clear(I2C0, I2C_INT_FLAG_PECERR);
    /* disable the I2C0 interrupt */
    i2c_interrupt_disable(I2C0, I2C_INT_ERR);
    i2c_interrupt_disable(I2C0, I2C_INT_BUF);
    i2c_interrupt_disable(I2C0, I2C_INT_EV);
void I2C0_EV_IRQHandler(void)
    i2c0_event_irq_handler();
void I2C0_ER_IRQHandler(void)
    i2c0_error_irq_handler();
cr315 发表于 2024-9-25 17:24 | 显示全部楼层
IIC的SCL和SDA引脚可能未正确配置为开漏输出模式,或者未接上拉电阻。
elephant00 发表于 2024-9-25 17:26 | 显示全部楼层
优化中断处理函数
两只袜子 发表于 2024-9-25 19:00 | 显示全部楼层
IIC总线上的连接可能存在松动、短路或断路等问题
powerantone 发表于 2024-9-25 19:00 | 显示全部楼层
程序中的逻辑错误可能导致IIC从机在接收数据时进入不正常的状态或死循环。
laocuo1142 发表于 2024-9-25 21:00 | 显示全部楼层
使用的IIC驱动或库函数可能存在bug或不足之处,导致接收数据时出现卡顿。
flycamelaaa 发表于 2024-9-25 22:00 | 显示全部楼层
检查并更新IIC驱动或库函数到最新版本,或者考虑使用其他可靠的IIC库函数。
stormwind123 发表于 2024-9-25 22:00 | 显示全部楼层
检查电源供应的稳定性,确保电源能够满足IIC从机的需求。
王派oo 发表于 2024-9-30 13:27 来自手机 | 显示全部楼层
接收完毕会产生多次的STPDEF中断
发货后已经wi 发表于 2024-9-30 23:38 来自手机 | 显示全部楼层
