我找到一个STM32L4R5ZIT6的关于CRC的例程,
代码如下 - #include "main.h"
- /** @addtogroup STM32L4xx_HAL_Examples
- /** @addtogroup CRC_Bytes_Stream_7bit_CRC
- /* Private typedef -----------------------------------------------------------*/
- /* Private define ------------------------------------------------------------*/
- #define BUFFER_SIZE_5 5 /* CRC7_DATA8_TEST5[] is 5-byte long */
- #define BUFFER_SIZE_17 17 /* CRC7_DATA8_TEST17[] is 17-byte long */
- #define BUFFER_SIZE_1 1 /* CRC7_DATA8_TEST1[] is 1-byte long */
- #define BUFFER_SIZE_2 2 /* CRC7_DATA8_TEST2[] is 2-byte long */
- /* User-defined polynomial */
- #define CRC_POLYNOMIAL_7B 0x65 /* X^7 + X^6 + X^5 + X^2 + 1,
- used in Train Communication Network, IEC 60870-5[17] */
- /* Private macro -------------------------------------------------------------*/
- /* Private variables ---------------------------------------------------------*/
- /* CRC handler declaration */
- CRC_HandleTypeDef CrcHandle;
- /* Used for storing CRC Value */
- __IO uint32_t uwCRCValue = 0;
- /* Bytes buffers that will consecutively yield CRCs */
- static const uint8_t CRC7_DATA8_TEST5[5] = {0x12,0x34,0xBA,0x71,0xAD};
- static const uint8_t CRC7_DATA8_TEST17[17] = {0x12,0x34,0xBA,0x71,0xAD,
- 0x11,0x56,0xDC,0x88,0x1B,
- 0xEE,0x4D,0x82, 0x93,0xA6,
- 0x7F,0xC3};
- static const uint8_t CRC7_DATA8_TEST1[1] = {0x19};
- static const uint8_t CRC7_DATA8_TEST2[2] = {0xAB,0xCD};
- /* Expected CRC Values */
- /* The 7 LSB bits are the 7-bit long CRC */
- uint32_t uwExpectedCRCValue_1 = 0x00000057; /* First byte stream CRC */
- uint32_t uwExpectedCRCValue_2 = 0x0000006E; /* Second byte stream CRC */
- uint32_t uwExpectedCRCValue_3 = 0x0000004B; /* Third byte stream CRC */
- uint32_t uwExpectedCRCValue_4 = 0x00000026; /* Fourth byte stream CRC */
- /* Private function prototypes -----------------------------------------------*/
- void SystemClock_Config(void);
- static void Error_Handler(void);
- /* Private functions ---------------------------------------------------------*/
- * [url=home.php?mod=space&uid=159083]@brief[/url] Main program
- * @param None
- * @retval None
- int main(void)
- /* STM32L4xx HAL library initialization:
- - Configure the Flash prefetch
- - Systick timer is configured by default as source of time base, but user
- can eventually implement his proper time base source (a general purpose
- timer for example or other time source), keeping in mind that Time base
- duration should be kept 1ms since PPP_TIMEOUT_VALUEs are defined and
- handled in milliseconds basis.
- - Set NVIC Group Priority to 4
- - Low Level Initialization
- HAL_Init();
- /* Configure the system clock to 120 MHz */
- SystemClock_Config();
- /* Configure LED1 and LED3 */
- BSP_LED_Init(LED1);
- BSP_LED_Init(LED3);
- /* CRC peripheral initialization */
- CrcHandle.Instance = CRC;
- /* The default polynomial is not used. The one to be used must be defined
- in CrcHandle.Init.GeneratingPolynomial */
- CrcHandle.Init.DefaultPolynomialUse = DEFAULT_POLYNOMIAL_DISABLE;
- /* Set the value of the generating polynomial.
- The one used in that example is the 7-bit long CRC generating
- polynomial X^7 + X^6 + X^5 + X^2 + 1 */
- CrcHandle.Init.GeneratingPolynomial = CRC_POLYNOMIAL_7B;
- /* The user-defined generating polynomial yields a 7-bit long CRC */
- CrcHandle.Init.CRCLength = CRC_POLYLENGTH_7B;
- /* The default init value is used */
- CrcHandle.Init.DefaultInitValueUse = DEFAULT_INIT_VALUE_ENABLE;
- /* The input data are not inverted */
- CrcHandle.Init.InputDataInversionMode = CRC_INPUTDATA_INVERSION_NONE;
- /* The output data are not inverted */
- CrcHandle.Init.OutputDataInversionMode = CRC_OUTPUTDATA_INVERSION_DISABLE;
- /* The input data are bytes (8-bit long data) */
- CrcHandle.InputDataFormat = CRC_INPUTDATA_FORMAT_BYTES;
- /* De-initialize the CRC peripheral */
- if (HAL_CRC_DeInit(&CrcHandle) != HAL_OK)
- /* Initialization Error */
- Error_Handler();
- /* Then, initialize the CRC handle */
- if (HAL_CRC_Init(&CrcHandle) != HAL_OK)
- Error_Handler();
- /* CRC computation of a first bytes stream */
- /* The 7-bit long CRC of a 5-byte buffer is computed. After peripheral initialization,
- the CRC calculator is initialized with the default value that is 0x7F for
- a 7-bit CRC.
- The computed CRC is stored in uint32_t uwCRCValue. The 7-bit long CRC is made of
- uwCRCValue 7 LSB bits. */
- uwCRCValue = HAL_CRC_Accumulate(&CrcHandle, (uint32_t *)&CRC7_DATA8_TEST5, BUFFER_SIZE_5);
- /* Compare the CRC value to the expected one */
- if (uwCRCValue != uwExpectedCRCValue_1)
- /* Wrong CRC value: Turn LED3 on */
- Error_Handler();
- /* CRC computation of a second bytes stream */
- /* The 7-bit long CRC of a 17-byte buffer is computed. The CRC calculator
- is not re-initialized, instead the previously computed CRC is used
- as initial value. */
- uwCRCValue = HAL_CRC_Accumulate(&CrcHandle, (uint32_t *)&CRC7_DATA8_TEST17, BUFFER_SIZE_17);
- if (uwCRCValue != uwExpectedCRCValue_2)
- Error_Handler();
- /* CRC computation of a single byte */
- /* The 7-bit long CRC of a 1-byte buffer is computed. The CRC calculator
- uwCRCValue = HAL_CRC_Accumulate(&CrcHandle, (uint32_t *)&CRC7_DATA8_TEST1, BUFFER_SIZE_1);
- if (uwCRCValue != uwExpectedCRCValue_3)
- Error_Handler();
- /* CRC computation of the last bytes stream */
- /* The 7-bit long CRC of a 2-byte buffer is computed. The CRC calculator
- is re-initialized with the default value that is 0x7F for a 7-bit CRC.
- This is done with a call to HAL_CRC_Calculate() instead of
- HAL_CRC_Accumulate(). */
- uwCRCValue = HAL_CRC_Calculate(&CrcHandle, (uint32_t *)&CRC7_DATA8_TEST2, BUFFER_SIZE_2);
- if (uwCRCValue != uwExpectedCRCValue_4)
- Error_Handler();
- else
- /* Right CRC value: Turn LED1 on */
- BSP_LED_On(LED1);
- /* Infinite loop */
- while (1)
多项式是0x65,没说初始值,有四组数据, 得到的CRC校验值分别为 uint32_t uwExpectedCRCValue_1 = 0x00000057; /* First byte stream CRC */ uint32_t uwExpectedCRCValue_2 = 0x0000006E; /* Second byte stream CRC */ uint32_t uwExpectedCRCValue_3 = 0x0000004B; /* Third byte stream CRC */ uint32_t uwExpectedCRCValue_4 = 0x00000026; /* Fourth byte stream CRC */ 我不知道这个校验码是怎么得来的?网上下了好多CRC计算器,算的值都不对。 请问高手,谁知道是怎么计算的?谢谢! |
