LM3S9B92 EPI_HB16_MODE_ADMUX应用
 楼主| anji85 发表于 2012-5-26 14:47 | 显示全部楼层 |阅读模式
LM3S9B92的EPI功能外接一个16位并行的铁电SRAM,  配置好后不知道数据该如何存储和读取;配置如下:
           void init(void)
   SysCtlPeripheralEnable(SYSCTL_PERIPH_EPI0); //使能EPI模块
    SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOC);
     SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOE);
   SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOF);
   SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOG);
   SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOH);
   SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOJ);
//================== 配置GPIO为EPI=================
    GPIOPinConfigure(GPIO_PH3_EPI0S0);
    GPIOPinConfigure(GPIO_PH2_EPI0S1);
    GPIOPinConfigure(GPIO_PC4_EPI0S2);
    GPIOPinConfigure(GPIO_PC5_EPI0S3);
    GPIOPinConfigure(GPIO_PC6_EPI0S4);
    GPIOPinConfigure(GPIO_PC7_EPI0S5);
    GPIOPinConfigure(GPIO_PH0_EPI0S6);
    GPIOPinConfigure(GPIO_PH1_EPI0S7);
    GPIOPinConfigure(GPIO_PE0_EPI0S8);
    GPIOPinConfigure(GPIO_PE1_EPI0S9);
    GPIOPinConfigure(GPIO_PH4_EPI0S10);
    GPIOPinConfigure(GPIO_PH5_EPI0S11);
    GPIOPinConfigure(GPIO_PF4_EPI0S12);
    GPIOPinConfigure(GPIO_PG0_EPI0S13);
    GPIOPinConfigure(GPIO_PG1_EPI0S14);
    GPIOPinConfigure(GPIO_PF5_EPI0S15);
    GPIOPinConfigure(GPIO_PJ0_EPI0S16);
    GPIOPinConfigure(GPIO_PJ1_EPI0S17);
   GPIOPinConfigure(GPIO_PH7_EPI0S27);
    GPIOPinConfigure(GPIO_PJ4_EPI0S28);
    GPIOPinConfigure(GPIO_PJ5_EPI0S29);
    GPIOPinConfigure(GPIO_PJ6_EPI0S30);
GPIOPinTypeEPI(GPIO_PORTC_BASE, EPI_PORTC_PINS);
    GPIOPinTypeEPI(GPIO_PORTE_BASE, EPI_PORTE_PINS);
    GPIOPinTypeEPI(GPIO_PORTF_BASE, EPI_PORTF_PINS);
    GPIOPinTypeEPI(GPIO_PORTG_BASE, EPI_PORTG_PINS);
    GPIOPinTypeEPI(GPIO_PORTH_BASE, EPI_PORTH_PINS);
    GPIOPinTypeEPI(GPIO_PORTJ_BASE, EPI_PORTJ_PINS);
//================== EPI配置 ===================
EPIDividerSet(EPI0_BASE, 100); //波特率等于系统时钟/2
EPIModeSet(EPI0_BASE, EPI_MODE_HB16); // SRAM使用HB16模式
EPIConfigHB16Set(EPI0_BASE,
                EPI_HB16_MODE_ADMUX | //使用ADMUX子模式,地址/数据总线复用子模式
                EPI_HB16_WRWAIT_3   | //无写等待态
                EPI_HB16_RDWAIT_3   | //无读等待态
                EPI_HB16_WORD_ACCESS | //使用字访问模式
                EPI_HB16_CSCFG_ALE //使用ALE配置,EPI0S30用ALE
              ,0); //无使用FIFO,无需设置
EPIAddressMapSet(EPI0_BASE,
                 EPI_ADDR_RAM_SIZE_16MB | //设置片外SRAM空间为16MB
                 EPI_ADDR_RAM_BASE_6); //设置自外SRAM的映射空间基地址为0x60000000
  while(HWREG(EPI0_BASE + EPI_O_STAT) &  EPI_STAT_INITSEQ)
EPIO27用做片选;ALE=EPIO30 ;
balabalaa 发表于 2012-5-26 15:00 | 显示全部楼层
lcq07 发表于 2012-6-15 09:16 | 显示全部楼层
直接以0x60000000为起始地址short类型开始读就ok了
lzh4774 发表于 2012-6-15 11:00 | 显示全部楼层
