SPI(Serial Peripheral Interface)是一种同步的串行通信接口。在STM32中,SPI接口是一种常用的外设通信接口,可以用于与其他外设(如传感器、存储器、显示器等)进行通信。
在使用STM32的SPI接口进行通信之前,需要进行一些基本的配置设置。下面是一个使用STM32CubeMX(官方提供的图形化配置工具)进行SPI配置的案例。
#include "stm32f4xx_hal.h"
void SystemClock_Config(void);
void MX_GPIO_Init(void);
void MX_SPI2_Init(void);
int main(void)
HAL_Init();
SystemClock_Config();
MX_GPIO_Init();
MX_SPI2_Init();
while (1)
// 在这里进行SPI通信的操作
RCC_OscInitTypeDef RCC_OscInitStruct;
RCC_ClkInitTypeDef RCC_ClkInitStruct;
__HAL_RCC_PWR_CLK_ENABLE();
__HAL_PWR_VOLTAGESCALING_CONFIG(PWR_REGULATOR_VOLTAGE_SCALE1);
RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSI;
RCC_OscInitStruct.HSIState = RCC_HSI_ON;
RCC_OscInitStruct.HSICalibrationValue = 16;
RCC_OscInitStruct.PLL.PLLState = RCC_PLL_ON;
RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSI;
RCC_OscInitStruct.PLL.PLLM = 16;
RCC_OscInitStruct.PLL.PLLN = 336;
RCC_OscInitStruct.PLL.PLLP = RCC_PLLP_DIV4;
RCC_OscInitStruct.PLL.PLLQ = 7;
if (HAL_RCC_OscConfig(&RCC_OscInitStruct) != HAL_OK)
Error_Handler();
RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_HCLK | RCC_CLOCKTYPE_SYSCLK |
RCC_CLOCKTYPE_PCLK1 | RCC_CLOCKTYPE_PCLK2;
RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_PLLCLK;
RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1;
RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV2;
RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV1;
if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_2) != HAL_OK)
Error_Handler();
GPIO_InitTypeDef GPIO_InitStruct;
__HAL_RCC_GPIOA_CLK_ENABLE();
__HAL_RCC_GPIOB_CLK_ENABLE();
__HAL_RCC_GPIOC_CLK_ENABLE();
GPIO_InitStruct.Pin = GPIO_PIN_13;
GPIO_InitStruct.Mode = GPIO_MODE_OUTPUT_PP;
GPIO_InitStruct.Pull = GPIO_NOPULL;
GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_LOW;
HAL_GPIO_Init(GPIOC, &GPIO_InitStruct);
GPIO_InitStruct.Pin = GPIO_PIN_2 | GPIO_PIN_3;
GPIO_InitStruct.Mode = GPIO_MODE_AF_PP;
GPIO_InitStruct.Pull = GPIO_PULLDOWN;
GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_VERY_HIGH;
GPIO_InitStruct.Alternate = GPIO_AF5_SPI2;
HAL_GPIO_Init(GPIOB, &GPIO_InitStruct);
hspi2.Instance = SPI2;
hspi2.Init.Mode = SPI_MODE_MASTER;
hspi2.Init.Direction = SPI_DIRECTION_2LINES;
hspi2.Init.DataSize = SPI_DATASIZE_8BIT;
hspi2.Init.CLKPolarity = SPI_POLARITY_LOW;
hspi2.Init.CLKPhase = SPI_PHASE_1EDGE;
hspi2.Init.NSS = SPI_NSS_SOFT;
hspi2.Init.BaudRatePrescaler = SPI_BAUDRATEPRESCALER_2;
hspi2.Init.FirstBit = SPI_FIRSTBIT_MSB;
hspi2.Init.TIMode = SPI_TIMODE_DISABLE;
hspi2.Init.CRCCalculation = SPI_CRCCALCULATION_DISABLE;
hspi2.Init.CRCPolynomial = 10;
if (HAL_SPI_Init(&hspi2) != HAL_OK)
Error_Handler();
上面的代码是通过SPI2接口实现通信的配置代码。具体的配置包括时钟设置、GPIO初始化和SPI初始化等。
下面是一个使用STM32的SPI接口实现与一片OLED显示屏通信的案例。假设OLED显示屏的数据传输使用的是SPI接口。
#define OLED_RST_Pin GPIO_PIN_0
#define OLED_RST_GPIO_Port GPIOC
#define OLED_DC_Pin GPIO_PIN_1
#define OLED_DC_GPIO_Port GPIOC
#define OLED_CS_Pin GPIO_PIN_2
#define OLED_CS_GPIO_Port GPIOC
SPI_HandleTypeDef hspi2;
void OLED_Init(void);
void OLED_WriteCmd(uint8_t cmd);
void OLED_WriteData(uint8_t data);
int main(void)
HAL_Init();
MX_GPIO_Init();
MX_SPI2_Init();
OLED_Init();
while (1)
// 在这里进行SPI通信的操作
HAL_GPIO_WritePin(OLED_RST_GPIO_Port, OLED_RST_Pin, GPIO_PIN_RESET);
HAL_Delay(100);
HAL_GPIO_WritePin(OLED_RST_GPIO_Port, OLED_RST_Pin, GPIO_PIN_SET);
HAL_Delay(200);
OLED_WriteCmd(0xAE); // 显示关闭
OLED_WriteCmd(0xD5); // 设置时钟分频因子/振荡器频率
OLED_WriteCmd(0x80);
OLED_WriteCmd(0xA8); // 设置驱动路数
OLED_WriteCmd(0x3F);
OLED_WriteCmd(0xD3); // 设置显示偏移
OLED_WriteCmd(0x00);
OLED_WriteCmd(0x40); // 设置显示开始行
OLED_WriteCmd(0x8D); // 设置电荷泵
OLED_WriteCmd(0x14);
OLED_WriteCmd(0x20); // 设置内存地址模式
OLED_WriteCmd(0x00); // 水平地址模式
OLED_WriteCmd(0xA1); // 设置段重启
OLED_WriteCmd(0xC8); // 设置COM输出扫描方向
OLED_WriteCmd(0xDA); // 设置COM引脚配置
OLED_WriteCmd(0x12);
OLED_WriteCmd(0x81); // 设置对比度控制
OLED_WriteCmd(0xCF);
OLED_WriteCmd(0xD9); // 设置预充电周期
OLED_WriteCmd(0xF1);
OLED_WriteCmd(0xDB); // 设置VCOMH电压倍率
OLED_WriteCmd(0xA4); // 设置全局显示开启
OLED_WriteCmd(0xA6); // 设置显示方式
OLED_WriteCmd(0xAF); // 显示开启
HAL_GPIO_WritePin(OLED_DC_GPIO_Port, OLED_DC_Pin, GPIO_PIN_RESET);
HAL_GPIO_WritePin(OLED_CS_GPIO_Port, OLED_CS_Pin, GPIO_PIN_RESET);
HAL_SPI_Transmit(&hspi2, &cmd, sizeof(cmd), HAL_MAX_DELAY);
HAL_GPIO_WritePin(OLED_CS_GPIO_Port, OLED_CS_Pin, GPIO_PIN_SET);
HAL_GPIO_WritePin(OLED_DC_GPIO_Port, OLED_DC_Pin, GPIO_PIN_SET);
HAL_SPI_Transmit(&hspi2, &data, sizeof(data), HAL_MAX_DELAY);
Error_Handler();
Error_Handler();
原文链接:https://blog.csdn.net/2401_85258012/article/details/142112423
