- * This is the main program.
- * Copyright (C)2015 D.N. Amerasinghe
- * This program is free software: you can redistribute it and/or modify
- * it under the terms of the GNU General Public License as published by
- * the Free Software Foundation, either version 3 of the License, or
- * (at your option) any later version.
- * This program is distributed in the hope that it will be useful,
- * but WITHOUT ANY WARRANTY; without even the implied warranty of
- * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
- * GNU General Public License for more details.
- * You should have received a copy of the GNU General Public License
- * along with this program. If not, see <http://www.gnu.org/licenses/>.
- #include <xc.h>
- #include <stdio.h>
- #include <stdlib.h>
- #include "uart.h"
- #include "i2c.h"
- #include "si4703.h"
- #include "hd44780i2c.h"
- #define _XTAL_FREQ 20000000 // 20MHz Clock
- #pragma config BOREN = ON, CPD = OFF, FOSC = HS, WDTE = OFF, CP = OFF, LVP = OFF, PWRTE = ON
- uint16_t rssi = 0;
- uint8_t scale = 0;
- //uint8_t buff[16] = {0};
- eeprom uint16_t last_channel;
- void init()
- //Disabling the A2D converter
- ADCON0bits.ADON = 0;
- //PORTC = 0x00;
- TRISD = 0x00;
- PORTD = 0x00;
- TRISBbits.TRISB0 = 1;
- TRISBbits.TRISB1 = 1;
- TRISBbits.TRISB2 = 0;
- PORTBbits.RB2 = 0;
- //Enabling Timer 1 interrupt
- T1CONbits.TMR1ON = 1;
- T1CONbits.T1CKPS0 = 1; //
- T1CONbits.T1CKPS1 = 1;
- PIE1bits.TMR1IE = 1;
- INTCONbits.PEIE = 1;
- INTCONbits.GIE = 1;
- void interrupt isr()
- if(PIR1bits.TMR1IF){
- scale++;
- //Send data in 15s interval
- //if( scale == 20 ){
- //scale = 0;
- //uint16_t rssi = si4703_getrssi();
- //printf("RSSI = %d\r\n", rssi);
- // if(rssi & 0x0100){
- // //printf("Stereo\r\n");
- // PORTBbits.RB2 = 1;
- // }else{
- // //printf("Mono\r\n");
- // PORTBbits.RB2 = 0;
- //last_channel = si4703_getchannel();
- if( scale == 70 ){
- hd44780_lightoff();
- //PIE1bits.TMR1IE = 0;
- //PIR1bits.TMR1IF = 0;
- scale = 0;
- //hd44780_puts_at(buff, 0);
- // Re-enabling interrupt
- PIR1bits.TMR1IF = 0;
- uint8_t debounce(uint8_t port, uint8_t pin)
- uint8_t count = 0;
- while( !(port & (1 << pin)) && count < 5 ){
- //PORTBbits.RB2 = 0;
- __delay_ms(10);
- count++;
- if(count == 5){
- return 1;
- }else{
- return 0;
- int main(int argc, char** argv)
- uint8_t btn_pressed = 1;
- uint8_t buff[16] = {0};
- uint16_t channel = 0;
- uint8_t whole = 0, frac = 0;
- init();
- uart_init();
- si4703_init();
- hd44780_init();
- //hd44780_putchar_at('X', 8);
- //sprintf(buff, "%s\n", "TEST");
- //hd44780_puts("TEST STRING\n");
- //hd44780_puts("TEST STRING");
- //hd44780_puts(buff);
- hd44780_lighton();
- si4703_tune( last_channel + 875 );
- while(1){
- rssi = si4703_getrssi();
- //if( scale == 1 ){
- sprintf(buff, "%d", rssi & 0x00FF);
- hd44780_puts_at(buff, 14);
- //si4703_get_rds(buff);
- //sprintf(buff, "%s", buff);
- //hd44780_newline();
- //scale = 0;
- if(rssi & 0x0100){
- //printf("Stereo\r\n");
- PORTBbits.RB2 = 1;
- }else{
- //printf("Mono\r\n");
- // }else{
- if(debounce(PORTB, 1)){
- btn_pressed = 1;
- //btn1_pressed = 1;
- //TMR1 = 0;
- scale = 0;
- si4703_seek(0);
- //continue;
- //__delay_ms(200);
- //while( debounce(PORTB, RB1) );
- if(debounce(PORTB, 0)){
- //printf("RB0 pressed\r\n");
- btn_pressed = 1;
- //TMR1 = 0;
- scale = 0;
- si4703_seek(1);
- if(!btn_pressed)
- continue;
- channel = si4703_getchannel();
- float chn = ((channel * 0.1) + 87.5);
- whole = chn;
- float f1 = chn - whole;
- frac = (uint8_t)(f1 * 10);
- //whole = ((channel * 0.1) + 875)/10;
- //F = S x C + L
- //sprintf(buff, "%f", ((channel * 0.1) + 875)/10);
- sprintf(buff, "%d.%dMhz ", whole, frac);
- //hd44780_clear();
- hd44780_puts_at(buff, 4);
- last_channel = si4703_getchannel();
- btn_pressed = 0;
- return (EXIT_SUCCESS);
