- * [url=home.php?mod=space&uid=288409]@file[/url] retarget.c
- * [url=home.php?mod=space&uid=895143]@version[/url] V3.00
- * $Revision: 4 $
- * $Date: 15/11/04 9:35a $
- * [url=home.php?mod=space&uid=247401]@brief[/url] Debug Port and Semihost Setting Source File
- * @note
- * SPDX-License-Identifier: Apache-2.0
- * Copyright (C) 2011 Nuvoton Technology Corp. All rights reserved.
- #include <stdio.h>
- #include "M058S.h"
- #if defined ( __CC_ARM )
- #if (__ARMCC_VERSION < 400000)
- #else
- /* Insist on keeping widthprec, to avoid X propagation by benign code in C-lib */
- #pragma import _printf_widthprec
- #endif
- #endif
- /* Global variables */
- #if !(defined(__ICCARM__) && (__VER__ >= 6010000))
- struct __FILE
- int handle; /* Add whatever you need here */
- #endif
- FILE __stdout;
- FILE __stdin;
- enum { r0, r1, r2, r3, r12, lr, pc, psr};
- * @brief Helper function to dump register while hard fault occurred
- * @param[in] stack pointer points to the dumped registers in SRAM
- * [url=home.php?mod=space&uid=266161]@return[/url] None
- * [url=home.php?mod=space&uid=1543424]@Details[/url] This function is implement to print r0, r1, r2, r3, r12, lr, pc, psr
- static void stackDump(uint32_t stack[])
- printf("r0 = 0x%x\n", stack[r0]);
- printf("r1 = 0x%x\n", stack[r1]);
- printf("r2 = 0x%x\n", stack[r2]);
- printf("r3 = 0x%x\n", stack[r3]);
- printf("r12 = 0x%x\n", stack[r12]);
- printf("lr = 0x%x\n", stack[lr]);
- printf("pc = 0x%x\n", stack[pc]);
- printf("psr = 0x%x\n", stack[psr]);
- * @brief Hard fault handler
- * @return None
- * @details Replace while(1) at the end of this function with chip reset if WDT is not enabled for end product
- void Hard_Fault_Handler(uint32_t stack[])
- printf("In Hard Fault Handler\n");
- stackDump(stack);
- // Replace while(1) with chip reset if WDT is not enabled for end product
- while(1);
- //SYS->IPRSTC1 = SYS_IPRSTC1_CHIP_RST_Msk;
- /* Routine to write a char */
- #if defined(DEBUG_ENABLE_SEMIHOST)
- /* The static buffer is used to speed up the semihost */
- static char g_buf[16];
- static char g_buf_len = 0;
- /* Make sure won't goes here only because --gnu is defined , so
- add !__CC_ARM and !__ICCARM__ checking */
- # if defined ( __GNUC__ ) && !(__CC_ARM) && !(__ICCARM__)
- # elif defined(__ICCARM__)
- void SH_End(void)
- asm("MOVS R0,#1 \n" //; Set return value to 1
- "BX lr \n" //; Return
- void SH_ICE(void)
- asm("CMP R2,#0 \n"
- "BEQ SH_End \n"
- "STR R0,[R2] \n" //; Save the return value to *pn32Out_R0
- * @brief The function to process semihosted command
- * @param[in] n32In_R0 : semihost register 0
- * @param[in] n32In_R1 : semihost register 1
- * @param[out] pn32Out_R0: semihost register 0
- * @retval 0: No ICE debug
- * @retval 1: ICE debug
- int32_t SH_DoCommand(int32_t n32In_R0, int32_t n32In_R1, int32_t *pn32Out_R0)
- asm("BKPT 0xAB \n" //; This instruction will cause ICE trap or system HardFault
- "B SH_ICE \n"
- "SH_HardFault: \n" //; Captured by HardFault
- "MOVS R0,#0 \n" //; Set return value to 0
- return 1; //; Return 1 when it is trap by ICE
- * @brief Get LR value and branch to Hard_Fault_Handler function
- * @param None
- * @return None
- * @details This function is use to get LR value and branch to Hard_Fault_Handler function.
- void Get_LR_and_Branch(void)
- asm("MOV R1, LR \n" //; LR current value
- "B Hard_Fault_Handler \n"
- * @brief Get MSP value and branch to Get_LR_and_Branch function
- * @param None
- * @return None
- * @details This function is use to get stack pointer value and branch to Get_LR_and_Branch function.
- void Stack_Use_MSP(void)
- asm("MRS R0, MSP \n" //; read MSP
- "B Get_LR_and_Branch \n"
- * @brief Get stack pointer value and branch to Get_LR_and_Branch function
- * @param None
- * @return None
- void HardFault_Handler_Ret(void)
- asm("MOVS r0, #4 \n"
- "MOV r1, LR \n"
- "TST r0, r1 \n" //; check LR bit 2
- "BEQ Stack_Use_MSP \n" //; stack use MSP
- "MRS R0, PSP \n" //; stack use PSP, read PSP
- * @brief This function is implemented to support semihost
- * @param None
- * @returns None
- * @details This function is implement to support semihost message print.
- void SP_Read_Ready(void)
- asm("LDR R1, [R0, #24] \n" //; Get previous PC
- "LDRH R3, [R1] \n" //; Get instruction
- "LDR R2, [pc, #8] \n" //; The special BKPT instruction
- "CMP R3, R2 \n" //; Test if the instruction at previous PC is BKPT
- "BNE HardFault_Handler_Ret \n" //; Not BKPT
- "ADDS R1, #4 \n" //; Skip BKPT and next line
- "STR R1, [R0, #24] \n" //; Save previous PC
- "DCD 0xBEAB \n" //; BKPT instruction code
- "B HardFault_Handler_Ret \n"
- * @param None
- * @return None
- void SP_is_PSP(void)
- asm(
- * @brief This HardFault handler is implemented to support semihost
- * @param None
- * @returns None
- void HardFault_Handler (void)
- asm("MOV R0, lr \n"
- "LSLS R0, #29 \n" //; Check bit 2
- "BMI SP_is_PSP \n" //; previous stack is PSP
- "MRS R0, MSP \n" //; previous stack is MSP, read MSP
- "B SP_Read_Ready \n"
- while(1);
- # else
- * @param None
- * @returns None
- __asm int32_t HardFault_Handler(void)
- IMPORT Hard_Fault_Handler
- MOV R0, LR
- LSLS R0, #29 //; Check bit 2
- BMI SP_is_PSP //; previous stack is PSP
- MRS R0, MSP //; previous stack is MSP, read MSP
- B SP_Read_Ready
- SP_is_PSP
- MRS R0, PSP //; Read PSP
- SP_Read_Ready
- LDR R1, [R0, #24] //; Get previous PC
- LDRH R3, [R1] //; Get instruction
- LDR R2, =0xBEAB //; The special BKPT instruction
- CMP R3, R2 //; Test if the instruction at previous PC is BKPT
- BNE HardFault_Handler_Ret //; Not BKPT
- ADDS R1, #4 //; Skip BKPT and next line
- STR R1, [R0, #24] //; Save previous PC
- BX LR //; Return
- HardFault_Handler_Ret
- /* TODO: Implement your own hard fault handler here. */
- MOVS r0, #4
- MOV r1, LR
- TST r0, r1 //; check LR bit 2
- BEQ Stack_Use_MSP //; stack use MSP
- MRS R0, PSP ;stack use PSP //; stack use PSP, read PSP
- B Get_LR_and_Branch
- Stack_Use_MSP
- MRS R0, MSP ; stack use MSP //; read MSP
- Get_LR_and_Branch
- MOV R1, LR ; LR current value //; LR current value
- LDR R2,=__cpp(Hard_Fault_Handler) //; branch to Hard_Fault_Handler
- BX R2
- B .
- ALIGN
- __asm int32_t SH_DoCommand(int32_t n32In_R0, int32_t n32In_R1, int32_t *pn32Out_R0)
- BKPT 0xAB //; Wait ICE or HardFault
- //; ICE will step over BKPT directly
- //; HardFault will step BKPT and the next line
- B SH_ICE
- SH_HardFault //; Captured by HardFault
- MOVS R0, #0 //; Set return value to 0
- BX lr //; Return
- SH_ICE //; Captured by ICE
- //; Save return value
- CMP R2, #0
- BEQ SH_End
- STR R0, [R2] //; Save the return value to *pn32Out_R0
- SH_End
- MOVS R0, #1 //; Set return value to 1
- BX lr //; Return
- #endif
- #else // Non-semihost
- * @brief This HardFault handler is implemented to show r0, r1, r2, r3, r12, lr, pc, psr
- * @param None
- * @returns None
- * @details This function is implement to print r0, r1, r2, r3, r12, lr, pc, psr.
- void HardFault_Handler(void)
- "MOV r1, LR \n"
- "TST r0, r1 \n" /*; check LR bit 2 */
- "BEQ 1f \n" /*; stack use MSP */
- "MRS R0, PSP \n" /*; stack use PSP, read PSP */
- "MOV R1, LR \n" /*; LR current value */
- "1: \n"
- "MRS R0, MSP \n" /*; LR current value */
- ::[Hard_Fault_Handler] "r" (Hard_Fault_Handler) // input
- while(1);
- * @param None
- * @returns None
- "MOV r1, LR \n"
- while(1);
- # else
- * @param None
- * @return None
- * @details The function extracts the location of stack frame and passes it to Hard_Fault_Handler function as a pointer
- MOVS r0, #4
- MOV r1, LR
- MRS R0, PSP //; stack use PSP, read PSP
- Stack_Use_MSP
- MRS R0, MSP //; read MSP
- Get_LR_and_Branch
- MOV R1, LR //; LR current value
- BX R2
- #endif
- #endif
- * @brief Routine to send a char
- * @param[in] ch A character data writes to debug port
- * @returns Send value from UART debug port
- * @details Send a target char to UART debug port .
- #ifndef NONBLOCK_PRINTF
- void SendChar_ToUART(int ch)
- while(DEBUG_PORT->FSR & UART_FSR_TX_FULL_Msk);
- if(ch == '\n')
- DEBUG_PORT->DATA = '\r';
- DEBUG_PORT->DATA = ch;
- #else
- /* Non-block implement of send char */
- #define BUF_SIZE 512
- static uint8_t u8Buf[BUF_SIZE] = {0};
- static int32_t i32Head = 0;
- static int32_t i32Tail = 0;
- int32_t i32Tmp;
- /* Only flush the data in buffer to UART when ch == 0 */
- if(ch)
- // Push char
- if(ch == '\n')
- i32Tmp = i32Head + 1;
- if(i32Tmp > BUF_SIZE) i32Tmp = 0;
- if(i32Tmp != i32Tail)
- u8Buf[i32Head] = '\r';
- i32Head = i32Tmp;
- u8Buf[i32Head] = ch;
- i32Head = i32Tmp;
- else
- if(i32Tail == i32Head)
- return;
- // pop char
- do
- i32Tmp = i32Tail + 1;
- if((DEBUG_PORT->FSR & UART_FSR_TX_FULL_Msk) == 0)
- DEBUG_PORT->DATA = u8Buf[i32Tail];
- i32Tail = i32Tmp;
- else
- break; // FIFO full
- while(i32Tail != i32Head);
- #endif
- * @returns Send value from UART debug port or semihost
- * @details Send a target char to UART debug port or semihost.
- void SendChar(int ch)
- g_buf[g_buf_len++] = ch;
- g_buf[g_buf_len] = '\0';
- if(g_buf_len + 1 >= sizeof(g_buf) || ch == '\n' || ch == '\0')
- /* Send the char */
- if(SH_DoCommand(0x04, (int)g_buf, NULL) != 0)
- g_buf_len = 0;
- return;
- else
- g_buf_len = 0;
- #else
- SendChar_ToUART(ch);
- #endif
- * @brief Routine to get a char
- * @param None
- * @returns Get value from UART debug port or semihost
- * @details Wait UART debug port or semihost to input a char.
- char GetChar(void)
- #ifdef DEBUG_ENABLE_SEMIHOST
- # if defined (__CC_ARM)
- int nRet;
- while(SH_DoCommand(0x101, 0, &nRet) != 0)
- if(nRet != 0)
- SH_DoCommand(0x07, 0, &nRet);
- return (char)nRet;
- # else
- int nRet;
- while(SH_DoCommand(0x7, 0, &nRet) != 0)
- if(nRet != 0)
- # endif
- return (0);
- #else
- while(1)
- if((DEBUG_PORT->FSR & UART_FSR_RX_EMPTY_Msk) == 0)
- return (DEBUG_PORT->DATA);
- #endif
- * @brief Check any char input from UART
- * @param None
- * @retval 1: No any char input
- * @retval 0: Have some char input
- * @details Check UART RSR RX EMPTY or not to determine if any char input from UART
- int kbhit(void)
- return !((DEBUG_PORT->FSR & UART_FSR_RX_EMPTY_Msk) == 0);
- * @brief Check if debug message finished
- * @param None
- * @retval 1: Message is finished
- * @retval 0: Message is transmitting.
- * @details Check if message finished (FIFO empty of debug port)
- int IsDebugFifoEmpty(void)
- return ((DEBUG_PORT->FSR & UART_FSR_TE_FLAG_Msk) != 0);
- * @brief C library retargetting
- * @param[in] ch Write a character data
- * @returns None
- void _ttywrch(int ch)
- SendChar(ch);
- return;
- * @brief Write character to stream
- * @param[in] ch Character to be written. The character is passed as its int promotion.
- * @param[in] stream Pointer to a FILE object that identifies the stream where the character is to be written.
- * @returns If there are no errors, the same character that has been written is returned.
- * If an error occurs, EOF is returned and the error indicator is set (see ferror).
- * @details Writes a character to the stream and advances the position indicator.\n
- * The character is written at the current position of the stream as indicated \n
- * by the internal position indicator, which is then advanced one character.
- * [url=home.php?mod=space&uid=536309]@NOTE[/url] The above descriptions are copied from http://www.cplusplus.com/reference/clibrary/cstdio/fputc/.
- int fputc(int ch, FILE *stream)
- SendChar(ch);
- return ch;
- #if defined ( __GNUC__ )
- #if !defined (OS_USE_SEMIHOSTING)
- int _write (int fd, char *ptr, int len)
- int i = len;
- while(i--)
- if(*ptr == '\n')
- DEBUG_PORT->DATA = *ptr++;
- return len;
- int _read (int fd, char *ptr, int len)
- while((DEBUG_PORT->FSR & UART_FSR_RX_EMPTY_Msk) != 0);
- *ptr = DEBUG_PORT->DATA;
- return 1;
- #endif
- #else
- * @brief Get character from UART debug port or semihosting input
- * @param[in] stream Pointer to a FILE object that identifies the stream on which the operation is to be performed.
- * @returns The character read from UART debug port or semihosting
- * @details For get message from debug port or semihosting.
- int fgetc(FILE *stream)
- return (GetChar());
- * @brief Check error indicator
- * @param[in] stream Pointer to a FILE object that identifies the stream.
- * @returns If the error indicator associated with the stream was set, the function returns a nonzero value.
- * Otherwise, it returns a zero value.
- * @details Checks if the error indicator associated with stream is set, returning a value different
- * from zero if it is. This indicator is generally set by a previous operation on the stream that failed.
- * @note The above descriptions are copied from http://www.cplusplus.com/reference/clibrary/cstdio/ferror/.
- // int ferror(FILE *stream)
- // return EOF;
- #endif
- # ifdef __ICCARM__
- void __exit(int return_code)
- /* Check if link with ICE */
- if(SH_DoCommand(0x18, 0x20026, NULL) == 0)
- /* Make sure all message is print out */
- while(IsDebugFifoEmpty() == 0);
- label:
- goto label; /* endless loop */
- # else
- void _sys_exit(int return_code)
- label:
- # endif
- #endif
文件是新唐M058S单片机库函数中的一个重要文件,主要用于调试端口和半主机(Semihosting)的设置。以下是对该文件的详细解释,帮助你理解其功能和作用。
1. 文件概述
文件名: retarget.c
版本: V3.00
功能: 该文件主要用于配置调试端口和半主机功能,使得开发者可以通过调试端口或半主机进行调试信息的输入输出。
2. 主要功能模块
2.1 全局变量
FILE __stdout 和 FILE __stdin: 这两个全局变量用于标准输入输出的重定向。在嵌入式系统中,通常需要将标准输入输出重定向到调试端口或半主机。
2.2 寄存器转储函数
stackDump(uint32_t stack[]): 该函数用于在发生硬错误(Hard Fault)时,打印出寄存器的值(如 r0, r1, r2, r3, r12, lr, pc, psr),帮助开发者定位错误。
2.3 硬错误处理函数
Hard_Fault_Handler(uint32_t stack[]): 当发生硬错误时,该函数会被调用。它会调用 stackDump 函数打印寄存器值,并进入一个死循环(while(1)),等待开发者处理。
2.4 半主机支持
半主机(Semihosting): 半主机是一种调试技术,允许嵌入式系统通过调试器与主机进行通信,例如打印调试信息到主机的控制台。
SH_DoCommand(int32_t n32In_R0, int32_t n32In_R1, int32_t *pn32Out_R0): 该函数用于处理半主机命令。通过 BKPT 指令触发调试器或硬错误,从而实现与主机的通信。
HardFault_Handler(void): 该函数是硬错误处理程序,支持半主机功能。它会根据堆栈指针(MSP或PSP)的不同,调用相应的处理函数。
2.5 调试端口输出函数
SendChar_ToUART(int ch): 该函数用于将字符发送到调试端口(通常是UART)。如果启用了非阻塞模式(NONBLOCK_PRINTF),则使用缓冲区来存储字符,以避免阻塞。
SendChar(int ch): 该函数根据是否启用了半主机功能,选择将字符发送到调试端口或通过半主机发送。
2.6 调试端口输入函数
GetChar(void): 该函数用于从调试端口或半主机获取一个字符。
kbhit(void): 该函数用于检查是否有字符输入。
IsDebugFifoEmpty(void): 该函数用于检查调试端口的FIFO是否为空。
2.7 C库重定向
_ttywrch(int ch): 该函数用于将字符写入调试端口。
fputc(int ch, FILE *stream): 该函数是C库的标准输出函数 fputc 的重定向实现,将字符发送到调试端口。
fgetc(FILE *stream): 该函数是C库的标准输入函数 fgetc 的重定向实现,从调试端口获取字符。
2.8 其他函数
_write(int fd, char *ptr, int len) 和 _read(int fd, char *ptr, int len): 这些函数是GNU工具链中的系统调用,用于实现标准输入输出的重定向。
__exit(int return_code) 和 _sys_exit(int return_code): 这些函数用于在程序退出时,确保所有调试信息都已输出。
3. 关键点
调试端口: 该文件通过UART或其他调试端口实现调试信息的输入输出。
半主机: 通过半主机功能,开发者可以在调试器中查看调试信息,而不需要实际的硬件调试端口。
硬错误处理: 当系统发生硬错误时,该文件提供了寄存器转储功能,帮助开发者定位错误。
4. 使用场景
调试信息输出: 在开发过程中,开发者可以通过 printf 函数将调试信息输出到调试端口或半主机。
错误处理: 当系统发生硬错误时,可以通过该文件提供的函数查看寄存器状态,帮助定位问题。
输入输出重定向: 在嵌入式系统中,标准输入输出通常需要重定向到调试端口或半主机,该文件提供了相应的实现。
