[技术讨论] MT6701:Low-Speed Magnetic Angle Encoder IC
 楼主| 锅锅赚大钱 发表于 2025-3-5 10:25 | 显示全部楼层 |阅读模式
MagnTek's low-speed magnetic angle encoder IC integrates high-precision AMR sensing elements with a dedicated decoding processing chip, achieving angle detection accuracy within ±1°. With a minimum package size of 3mm x 3mm, it meets the size requirements of most applications. Meanwhile, the non-contact magnetic sensing control offers high reliability, with a maximum operating temperature range of -40 to 125°C. It features traditional ABZ/UVW incremental outputs, as well as analog output and multiple output interfaces such as IC, SPL, and PWM.
Recommended Applications: Pan-tilt systems, servos, robotic joint control, stepper motor control, and more.
 楼主| 锅锅赚大钱 发表于 2025-3-5 10:26 | 显示全部楼层
I have,please,1355594925
