privkey.py
 楼主| laojun001 发表于 2025-3-6 13:53 | 显示全部楼层 |阅读模式
PY, TI, ic, TE, IO, PUBLIC
from cryptography.hazmat.primitives.asymmetric import rsa, padding
from cryptography.hazmat.primitives import serialization, hashes
from cryptography.hazmat.primitives.asymmetric import utils
from cryptography.hazmat.backends import default_backend
# 生成一个RSA私钥
private_key = rsa.generate_private_key(
    public_exponent=65537,
    key_size=2048,
    backend=default_backend()
# 打印私钥的PEM格式(一种常见的私钥格式)
pem = private_key.private_bytes(
    encoding=serialization.Encoding.PEM,
    format=serialization.PrivateFormat.PKCS8,
    encryption_algorithm=serialization.NoEncryption()
).decode('utf-8')
print("Private Key (PEM):")
print(pem)
# 使用私钥进行签名
message = b"This is a secret message"
signature = private_key.sign(
    message,
    padding.PSS(
        mgf=padding.MGF1(hashes.SHA256()),
        salt_length=padding.PSS.MAX_LENGTH
    hashes.SHA256()
# 打印签名
print("\nSignature:")
print(signature.hex())
# 假设你已经有了对应的公钥,你可以使用公钥来验证签名
public_key = private_key.public_key()
pem_public = public_key.public_bytes(
    format=serialization.PublicFormat.SubjectPublicKeyInfo
).decode('utf-8')
print("\nPublic Key (PEM):")
print(pem_public)
# 验证签名
try:
    public_key.verify(
        signature,
        message,
        padding.PSS(
        hashes.SHA256()
    print("\nSignature verification succeeded.")
except Exception as e:
    print(f"\nSignature verification failed: {e}")
