[STM32F4] 用Embedded Wizard Studio Free V9.20打开v14版本的f429代码出现如下错误,没找到原因
 楼主| 地瓜patch 发表于 2025-3-15 22:26 | 显示全部楼层 |阅读模式
[15.3.2025 22:14:31] Welcome : Embedded Wizard Studio Free 9.20 (build 3202)
This is a free edition limited to project complexity.
Copyright © TARA Systems GmbH
Written by Paul Banach and Manfred Schweyer
[15.3.2025 22:14:31] Information : Loading project 'AnalogWatches.ewp' ...
[15.3.2025 22:14:31] Warning C:\Users\Administrator\Documents\STM32F429-Discovery\Examples\240x320\AnalogWatches\AnalogWatches.ewp (1:1) : Missing $version directive. Embedded Wizard expects that each project and unit file start with the $version directive followed by the version number of the used Chora syntax. If the $version directive is missed, Embedded Wizard assumes that the Chora syntax version is 1.0.
[15.3.2025 22:14:31] Fatal error C:\Users\Administrator\Documents\STM32F429-Discovery\Examples\240x320\AnalogWatches\AnalogWatches.ewp (1:1) : Unexpected keyword 'ï' found in the project file. Only 'profile', 'language', 'style', 'unit' or 'note' can be used here.
不确定是版本原因还是代码存在问题?请教
 楼主| 地瓜patch 发表于 2025-3-19 22:14 | 显示全部楼层
求软件Embedded Wizard Studio Free V12.0或更新版本
个人签名:出一块TI-PLABS-AMP-EVM
1821
