求助 28335与仿真器连接不上
 楼主| sunchengyao 发表于 2012-6-6 22:41 | 显示全部楼层 |阅读模式
跪求各位帮忙,很急。28335与XDS510pp连接不上,出现如下错误,求各位帮忙解答
Error connecting to the target:
Error 0x80000200/-1041
Fatal Error during: OCS,
Device driver: Problem with the Emulation Controller.
It is recommended to RESET EMULATOR.  This will disconnect each
target from the emulator.  The targets should then be power cycled
or hard reset followed by an emureset and reconnect to each target.
I/O Port = 378
Board Name: F28335 PP Emulator
Cpu Name: cpu_0
Abort:                Close Code Composer Studio.
Retry:                Try to connect to the target again.
Cancel:                Remain disconnected from the target
Diagnostic:        Run diagnostic utility.
lzh4774 发表于 2012-6-13 11:53 | 显示全部楼层
有些小公司的仿真器是有问题,建议正版
lslrf 发表于 2012-6-14 16:35 | 显示全部楼层
这与正不正版没有关系。只不过并口仿真器的确太老了
