仿真时候出现的问题
 楼主| kangzj 发表于 2012-6-8 22:13 | 显示全部楼层 |阅读模式
Error connecting to the target:
Error 0x80000200/-1047
Fatal Error during: OCS,
PTI_ERR_EMU_CLOSE Error Occured at 0x00000000
I/O Port = 240
Board Name: F2812 XDS510 Emulator_1
Cpu Name: CPU_1
Abort:  Close Code Composer Studio.
Retry:  Try to connect to the target again.
Cancel:  Remain disconnected from the target
Diagnostic: Run diagnostic utility.
chuxh 发表于 2012-6-8 22:13 | 显示全部楼层
是语法问题吗?
llljh 发表于 2012-6-8 22:16 | 显示全部楼层
先复位一下仿真器debug-->reset  emulator,再连接一下看看,
若还不行就断电重新连接几次
司徒老鹰 发表于 2012-6-8 22:17 | 显示全部楼层
先复位仿真器,然后断电几次试试。
 楼主| kangzj 发表于 2012-6-8 22:19 | 显示全部楼层
嗯,我试试
先结贴了
