UCOS移植到MSP430过程与心得体会《1》
 楼主| day888 发表于 2012-6-10 20:57 | 显示全部楼层 |阅读模式
以下是OS_CFG.H头文件内容包括UCOS_II操作系统的九大主要核心.用信号量或消息量及其他的任何量时将相应的允许位设置为1 ,删除与其他根据应用来定.
/* ---------------------- MISCELLANEOUS ----------------------- */
#define OS_ARG_CHK_EN
/* Enable (1) or Disable (0) argument checking
#define OS_CPU_HOOKS_EN
/* uC/OS-II hooks are found in the processor port files
#define OS_DEBUG_EN
/* Enable(1) debug variables
#define OS_EVENT_NAME_SIZE
/* Determine the size of the name of a Sem, Mutex, Mbox or Q
#define OS_LOWEST_PRIO
/* Defines the lowest priority that can be assigned ...
/* ... MUST NEVER be higher than 63!
#define OS_MAX_EVENTS
/* Max. number of event control blocks in your application
#define OS_MAX_FLAGS
/* Max. number of Event Flag Groups
in your application
#define OS_MAX_MEM_PART
/* Max. number of memory partitions
#define OS_MAX_QS
/* Max. number of queue control blocks in your application
#define OS_MAX_TASKS
/* Max. number of tasks in your application, MUST be >= 2
#define OS_SCHED_LOCK_EN
Include code for OSSchedLock() and OSSchedUnlock()
#define OS_TASK_IDLE_STK_SIZE
80
/* Idle task stack size (# of OS_STK wide entries)
#define OS_TASK_STAT_EN
/* Enable (1) or Disable(0) the statistics task
#define OS_TASK_STAT_STK_SIZE
80
/* Statistics task stack size (# of OS_STK wide entries)
#define OS_TASK_STAT_STK_CHK_EN
/* Check task stacks from statistic task
#define OS_TICK_STEP_EN
/* Enable tick stepping feature for uC/OS-View
#define OS_TICKS_PER_SEC
64
/* Set the number of ticks in one second
/* ----------------------- EVENT FLAGS ------------------------ */
#define OS_FLAG_EN
/* Enable (1) or Disable (0) code generation for EVENT FLAGS
#define OS_FLAG_WAIT_CLR_EN
/* Include code for Wait on Clear EVENT FLAGS
#define OS_FLAG_ACCEPT_EN
Include code for OSFlagAccept()
#define OS_FLAG_DEL_EN
Include code for OSFlagDel()
#define OS_FLAG_NAME_SIZE
Determine the size of the name of an event flag group
#define OS_FLAG_QUERY_EN
Include code for OSFlagQuery()
/* -------------------- MESSAGE MAILBOXES --------------------- */
#define OS_MBOX_EN
/* Enable (1) or Disable (0) code generation for MAILBOXES
#define OS_MBOX_ACCEPT_EN
Include code for OSMboxAccept()
#define OS_MBOX_DEL_EN
Include code for OSMboxDel()
#define OS_MBOX_POST_EN
Include code for OSMboxPost()
#define OS_MBOX_POST_OPT_EN
Include code for OSMboxPostOpt()
#define OS_MBOX_QUERY_EN
Include code for OSMboxQuery()
/* --------------------- MEMORY MANAGEMENT -------------------- */
#define OS_MEM_EN
/* Enable (1) or Disable (0) code generation for MEMORY MANAGER */
#define OS_MEM_QUERY_EN
Include code for OSMemQuery()
#define OS_MEM_NAME_SIZE
Determine the size of a memory partition name
/* ---------------- MUTUAL EXCLUSION SEMAPHORES --------------- */
#define OS_MUTEX_EN
/* Enable (1) or Disable (0) code generation for MUTEX
#define OS_MUTEX_ACCEPT_EN
Include code for OSMutexAccept()
#define OS_MUTEX_DEL_EN
Include code for OSMutexDel()
#define OS_MUTEX_QUERY_EN
Include code for OSMutexQuery()
/* ---------------------- MESSAGE QUEUES ---------------------- */
#define OS_Q_EN
/* Enable (1) or Disable (0) code generation for QUEUES
#define OS_Q_ACCEPT_EN
Include code for OSQAccept()
#define OS_Q_DEL_EN
Include code for OSQDel()
#define OS_Q_FLUSH_EN
Include code for OSQFlush()
#define OS_Q_POST_EN
Include code for OSQPost()
#define OS_Q_POST_FRONT_EN
Include code for OSQPostFront()
#define OS_Q_POST_OPT_EN
Include code for OSQPostOpt()
#define OS_Q_QUERY_EN
Include code for OSQQuery()
/* ------------------------ SEMAPHORES ------------------------ */
#define OS_SEM_EN
/* Enable (1) or Disable (0) code generation for SEMAPHORES
#define OS_SEM_ACCEPT_EN
Include code for OSSemAccept()
#define OS_SEM_DEL_EN
Include code for OSSemDel()
#define OS_SEM_QUERY_EN
Include code for OSSemQuery()
/* --------------------- TASK MANAGEMENT ---------------------- */
#define OS_TASK_CHANGE_PRIO_EN
Include code for OSTaskChangePrio()
#define OS_TASK_CREATE_EN
Include code for OSTaskCreate()
#define OS_TASK_CREATE_EXT_EN
Include code for OSTaskCreateExt()
#define OS_TASK_DEL_EN
Include code for OSTaskDel()
#define OS_TASK_NAME_SIZE
Determine the size of a task name
#define OS_TASK_PROFILE_EN
Include variables in OS_TCB for profiling
#define OS_TASK_QUERY_EN
Include code for OSTaskQuery()
#define OS_TASK_SUSPEND_EN
Include code for OSTaskSuspend() and OSTaskResume()
#define OS_TASK_SW_HOOK_EN
Include code for OSTaskSwHook()
/* --------------------- TIME MANAGEMENT ---------------------- */
#define OS_TIME_DLY_HMSM_EN
Include code for OSTimeDlyHMSM()
#define OS_TIME_DLY_RESUME_EN
Include code for OSTimeDlyResume()
#define OS_TIME_GET_SET_EN
Include code for OSTimeGet() and OSTimeSet()
#define OS_TIME_TICK_HOOK_EN
Include code for OSTimeTickHook()
typedef INT16U
OS_FLAGS;
/* Date type for event flag bits (8, 16 or 32 bits)
