改进后,节点和代码框架。
 楼主| keer_zu 发表于 2025-6-18 12:54 | 显示全部楼层 |阅读模式
基于修正后的架构,我们需要实现以下ROS 2节点及其代码框架:
节点规划及代码框架
1. 视觉处理节点 (vision_processor_node)
python
#!/usr/bin/env python3
import rclpy
from rclpy.node import Node
from sensor_msgs.msg import Image
from vision_msgs.msg import Detection2DArray
from cv_bridge import CvBridge
import cv2
class VisionProcessor(Node):
    def __init__(self):
        super().__init__('vision_processor')
        # ROS 2接口
        self.image_sub = self.create_subscription(
            Image, '/camera/image', self.image_callback, 10)
        self.detection_pub = self.create_publisher(
            Detection2DArray, '/object/detections', 10)
        # OpenCV工具
        self.bridge = CvBridge()
        self.detector = self.init_detector()  # 初始化OpenCV检测器
    def init_detector(self):
        """初始化视觉检测模型"""
        # 实际实现使用OpenCV DNN或自定义模型
        return None
    def image_callback(self, msg):
        """处理图像并发布检测结果"""
        try:
            cv_image = self.bridge.imgmsg_to_cv2(msg, 'bgr8')
            detections = self.process_image(cv_image)
            # 转换为ROS消息
            detection_msg = self.create_detection_msg(detections)
            self.detection_pub.publish(detection_msg)
        except Exception as e:
            self.get_logger().error(f'Image processing error: {str(e)}')
    def process_image(self, cv_image):
        """使用OpenCV处理图像并返回检测结果"""
        # 实际实现包含目标检测算法
        return []
    def create_detection_msg(self, detections):
        """将检测结果转换为ROS消息"""
        # 实际实现填充Detection2DArray
        return Detection2DArray()
if __name__ == '__main__':
    rclpy.init()
    node = VisionProcessor()
    rclpy.spin(node)
    rclpy.shutdown()
2. 任务规划节点 (task_planner_node)
python
import rclpy
from task_msgs.msg import TaskSequence
from control_msgs.msg import SystemStatus
from std_msgs.msg import String
class TaskPlanner(Node):
    def __init__(self):
        super().__init__('task_planner')
        # ROS 2接口
        self.detection_sub = self.create_subscription(
            Detection2DArray, '/object/detections', self.detection_callback, 10)
        self.status_sub = self.create_subscription(
            SystemStatus, '/system/status', self.status_callback, 10)
        self.task_pub = self.create_publisher(
            TaskSequence, '/task/sequence', 10)
        self.ui_sub = self.create_subscription(
            String, '/ui/params', self.ui_callback, 10)
        # 任务状态机
        self.current_task = None
        self.task_queue = []
    def detection_callback(self, msg):
        """根据视觉检测结果生成任务"""
        if not self.task_queue:
            self.generate_tasks(msg)
    def generate_tasks(self, detections):
        """基于检测结果生成任务序列"""
        # 实际实现包含任务规划算法
        task_sequence = TaskSequence()
        # ... 填充任务序列
        self.task_pub.publish(task_sequence)
    def status_callback(self, msg):
        """监控系统状态并调整任务"""
        if msg.error_flag:
            self.handle_error(msg)
    def ui_callback(self, msg):
        """处理UI配置更新"""
        # 解析UI参数并更新任务配置
        self.get_logger().info(f'UI config updated: {msg.data}')
    rclpy.init()
    node = TaskPlanner()
    rclpy.spin(node)
    rclpy.shutdown()
3. 路径规划节点 (path_planner_node)
python
import rclpy
from nav_msgs.msg import OccupancyGrid, Path
from visualization_msgs.msg import MarkerArray
from std_msgs.msg import Bool
import numpy as np
class PathPlanner(Node):
    def __init__(self):
        super().__init__('path_planner')
        # ROS 2接口
        self.task_sub = self.create_subscription(
            TaskSequence, '/task/sequence', self.task_callback, 10)
        self.map_sub = self.create_subscription(
            OccupancyGrid, '/obstacle/map', self.map_callback, 10)
        self.collision_sub = self.create_subscription(
            Bool, '/collision/alerts', self.collision_callback, 10)
        self.path_pub = self.create_publisher(
            Path, '/path/planned', 10)
        self.visualization_pub = self.create_publisher(
            MarkerArray, '/path/visualization', 10)
        # 路径规划状态
        self.current_map = None
        self.timer = self.create_timer(0.1, self.planning_loop)  # 10Hz
    def task_callback(self, msg):
        """存储当前任务序列"""
        self.current_task = msg
    def map_callback(self, msg):
        """更新障碍物地图"""
        self.current_map = msg
    def collision_callback(self, msg):
        """处理碰撞警报触发重规划"""
        if msg.data and self.current_task:
            self.get_logger().warn('Collision detected! Replanning...')
            self.generate_path(self.current_task, self.current_map)
    def planning_loop(self):
        """主规划循环"""
        if self.current_task and self.current_map:
    def generate_path(self, task, map):
        """生成优化路径 (A*/RRT*)"""
        # 实际实现包含路径规划算法
        path = Path()
        # ... 填充路径
        # 发布路径
        self.path_pub.publish(path)
        # 生成可视化标记
        markers = self.create_visualization(path)
        self.visualization_pub.publish(markers)
    rclpy.init()
    node = PathPlanner()
    rclpy.spin(node)
    rclpy.shutdown()
4. 导航避障节点 (navigation_obstacle_node)
python
import rclpy
from sensor_msgs.msg import PointCloud2
from geometry_msgs.msg import PoseStamped
import numpy as np
class NavigationObstacle(Node):
    def __init__(self):
        super().__init__('navigation_obstacle')
        # ROS 2接口
        self.pose_sub = self.create_subscription(
            PoseStamped, '/sensor/pose', self.pose_callback, 10)
        self.pointcloud_sub = self.create_subscription(
            PointCloud2, '/sensor/pointcloud', self.pointcloud_callback, 10)
        self.map_pub = self.create_publisher(
            OccupancyGrid, '/obstacle/map', 10)
        self.collision_pub = self.create_publisher(
            Bool, '/collision/alerts', 10)
        # 避障参数
        self.safety_distance = 0.5  # 安全距离(m)
        self.map_resolution = 0.05  # 地图分辨率(m/cell)
    def pose_callback(self, msg):
        """更新当前位姿"""
        self.current_pose = msg
    def pointcloud_callback(self, msg):
        """处理点云数据生成障碍地图"""
        if hasattr(self, 'current_pose'):
            obstacle_map = self.generate_occupancy_grid(msg)
            self.map_pub.publish(obstacle_map)
            # 检查碰撞风险
            collision_risk = self.check_collision(obstacle_map)
            alert = Bool(data=collision_risk)
            self.collision_pub.publish(alert)
    def generate_occupancy_grid(self, pointcloud):
        """从点云生成占据栅格地图"""
        # 实际实现包含点云处理算法
        return OccupancyGrid()
    def check_collision(self, map):
        """检查碰撞风险"""
        # 实际实现包含安全距离检查
        return False
    rclpy.init()
    node = NavigationObstacle()
    rclpy.spin(node)
    rclpy.shutdown()
5. 运动控制节点 (motion_controller_node)
python
import rclpy
from nav_msgs.msg import Path
from geometry_msgs.msg import Twist
from sensor_msgs.msg import JointState
class MotionController(Node):
    def __init__(self):
        super().__init__('motion_controller')
        # ROS 2接口
        self.path_sub = self.create_subscription(
            Path, '/path/planned', self.path_callback, 10)
        self.cmd_pub = self.create_publisher(
            Twist, '/cmd_vel', 10)
        self.joint_pub = self.create_publisher(
            JointState, '/joint_states', 10)
        self.status_pub = self.create_publisher(
            SystemStatus, '/system/status', 10)
        # 控制参数
        self.control_rate = 100  # Hz
        self.timer = self.create_timer(1/self.control_rate, self.control_loop)
        self.current_path = None
    def path_callback(self, msg):
        """存储当前路径"""
        self.current_path = msg
    def control_loop(self):
        """主控制循环"""
        if self.current_path:
            # 生成控制指令
            cmd_vel = self.generate_control_command()
            self.cmd_pub.publish(cmd_vel)
            # 发布关节状态
            joint_state = self.get_joint_states()
            self.joint_pub.publish(joint_state)
            # 发布系统状态
            status = SystemStatus()
            # ... 填充状态信息
            self.status_pub.publish(status)
    def generate_control_command(self):
        """根据路径生成控制指令"""
        # 实际实现包含轨迹跟踪算法
        return Twist()
    def get_joint_states(self):
        """获取当前关节状态"""
        # 实际实现从硬件读取
        return JointState()
    rclpy.init()
    node = MotionController()
    rclpy.spin(node)
    rclpy.shutdown()
6. Qt UI节点 (qt_ui_node)
python
import rclpy
from PyQt6.QtWidgets import QApplication, QMainWindow
import sys
class QtUINode(Node):
    def __init__(self):
        super().__init__('qt_ui_node')
        # ROS 2接口
        self.ui_pub = self.create_publisher(
            String, '/ui/params', 10)
        self.marker_sub = self.create_subscription(
            MarkerArray, '/path/visualization', self.marker_callback, 10)
        # Qt UI
        self.app = QApplication(sys.argv)
        self.window = MainWindow(self)
        self.window.show()
        """更新UI中的图像显示"""
        self.window.update_image(msg)
    def marker_callback(self, msg):
        """更新UI中的路径可视化"""
        self.window.update_path_visualization(msg)
    def run(self):
        """启动Qt应用"""
        sys.exit(self.app.exec())
class MainWindow(QMainWindow):
    def __init__(self, ros_node):
        super().__init__()
        self.ros_node = ros_node
        # 初始化UI组件
        self.init_ui()
    def init_ui(self):
        """初始化用户界面"""
        # 实际实现包含Qt UI布局
        self.setWindowTitle("ROS 2 Visual Control System")
        self.setGeometry(100, 100, 1200, 800)
    def update_image(self, image_msg):
        """更新图像显示"""
        # 实际实现将ROS图像转换为Qt图像
    def update_path_visualization(self, markers):
        """更新路径可视化"""
        # 实际实现处理可视化标记
    def on_config_changed(self):
        """处理UI配置变更"""
        config = String(data="current config")
        self.ros_node.ui_pub.publish(config)
    rclpy.init()
    node = QtUINode()
    # 在独立线程中运行ROS
    from threading import Thread
    spin_thread = Thread(target=rclpy.spin, args=(node,))
    spin_thread.start()
    # 运行Qt主循环
    node.run()
    rclpy.shutdown()
自定义消息类型
需要在 task_msgs包中定义自定义消息:
TaskSequence.msg
Header header
TaskGoal[] goals
TaskGoal.msg
string goal_id
geometry_msgs/Pose target_pose
string action_type  # e.g., "PICK", "PLACE", "MOVE"
系统部署说明
  1. 依赖安装
sudo apt install ros-jazzy-vision-msgs ros-jazzy-nav-msgs
  1. 构建和运行
colcon build --packages-select vision_processor task_planner path_planner navigation_obstacle motion_controller qt_ui
source install/setup.bash
ros2 launch visual_control_system system.launch.py
  1. 性能优化
    • 路径规划节点使用C++实现以提高实时性
    • 关键控制回路使用实时Linux内核
    • 视觉处理使用GPU加速
系统架构图更新
该实现方案提供了完整的视觉-运动控制系统,满足实时控制要求(运动控制100Hz,路径规划10Hz,任务规划1-5Hz),并通过Qt UI实现人机交互。
1478
1478
