遇到了NUCLEO-L073RZ开发板的问题, 我使用Atollic Truestudio对NUCLEO开发板进行编程和调试。当我插入开发板并开始调试时,它返回以下错误: Failure at line: 13 in 'Target Software Startup Scripsts'. Please edit the debug configuration settings Error finishing flash operation . 我使用ST-LINK Utility擦除闪存,但仍然出现相同的错误。我还卸载了Atollic Truestudio,同样无法解决这个问题。 调试设置 # Set flash parallelism mode to 32, 16, or 8 bit when using STM32 F2/F4 microcontrollers # Uncomment next line, 2=32 bit, 1=16 bit and 0=8 bit parallelism mode #monitor flash set_parallelism_mode 2 # Set character encoding set host-charset CP1252 set target-charset CP1252 # Reset to known state monitor reset # Load the program executable load # Reset the chip to get to a known state. Remove "monitor reset" command # if the code is not located at default address and does not run by reset. monitor reset # Enable Debug connection in low power modes (DBGMCU->CR) set *0xE0042004 = (*0xE0042004) | 0x7 # Set a breakpoint at main(). tbreak main # Run to the breakpoint.
