开发板提供了一个用户按键:
按键KEY1相关的宏定义:
- * [url=home.php?mod=space&uid=247401]@brief[/url] Key1 push-button
- #define KEY1_BUTTON_PIN GPIO_PIN_1
- #define KEY1_BUTTON_GPIO_PORT GPIOA
- #define KEY1_BUTTON_GPIO_CLK RCM_APB2_PERIPH_GPIOA
- #define KEY1_BUTTON_EINT_LINE EINT_LINE_1
- #define KEY1_BUTTON_EINT_PORT_SOURCE GPIO_PORT_SOURCE_A
- #define KEY1_BUTTON_EINT_PIN_SOURCE GPIO_PIN_SOURCE_1
- #define KEY1_BUTTON_EINT_IRQ_NUM EINT1_IRQn
配置为外部中断模式:
- * @brief Board button configuration
- * @param button: Specifies the button to be configured
- * This parameter can be one of following parameters:
- * [url=home.php?mod=space&uid=2817080]@ARG[/url] BUTTON_KEY1: Key1 Push Button
- * @arg BUTTON_KEY2: Key2 Push Button
- * @param Button_Mode: Specifies Button mode.
- * @arg BUTTON_MODE_GPIO: Button will be used as simple IO
- * @arg BUTTON_MODE_EINT: Button will be connected to EINT line
- * with interrupt generation capability
- * @retval None
- void BOARD_BUTTON_Config(BOARD_BUTTON_T button, BOARD_BUTTON_MODE_T mode)
- GPIO_Config_T GPIO_ConfigStruct = {0U};
- EINT_Config_T EINT_ConfigStruct = {0U};
- /* Enable the BUTTON Clock */
- RCM_EnableAPB2PeriphClock(BUTTON_CLK[button] | RCM_APB2_PERIPH_AFIO);
- /* Configure Button pin as input floating */
- GPIO_ConfigStruct.mode = GPIO_MODE_IN_PU;
- GPIO_ConfigStruct.pin = BUTTON_PIN[button];
- GPIO_Config(BUTTON_PORT[button], &GPIO_ConfigStruct);
- if (mode == BUTTON_MODE_EINT)
- /* Connect Button EINT Line to Button GPIO Pin */
- GPIO_ConfigEINTLine(BUTTON_PORT_SOURCE[button], BUTTON_PIN_SOURCE[button]);
- /* Configure Button EINT line */
- EINT_ConfigStruct.line = BUTTON_EINT_LINE[button];
- EINT_ConfigStruct.mode = EINT_MODE_INTERRUPT;
- EINT_ConfigStruct.trigger = EINT_TRIGGER_FALLING;
- EINT_ConfigStruct.lineCmd = ENABLE;
- EINT_Config(&EINT_ConfigStruct);
- /* Enable and set Button EINT Interrupt to the lowest priority */
- NVIC_EnableIRQRequest(BUTTON_IRQn[button], 0x0F, 0x0F);
调用:BOARD_BUTTON_Config(BUTTON_KEY1, BUTTON_MODE_EINT);
中断处理函数:
- * @brief This function handles External lines 1 Handler
- * @param None
- * @retval None
- void EINT1_IRQHandler(void)
- if (EINT_ReadIntFlag(EINT_LINE_1))
- BOARD_LED_Toggle(LED3);
- EINT_ClearIntFlag(EINT_LINE_1);
烧录验证:
