请问idata和data都是ram空间吗?vector是中断向量表占的空间吗?
text呢?
那到底占用FLASH.html">FLASH空间的是哪个?
谢谢!
NOTE: AVR Code addresses are word addresses
All other addresses (including ones in FLASH) are byte addresses
Area Addr Size Decimal Bytes (Attributes)
idata 0026 0260 = 608. bytes (rel,con,rom)
Addr GLOBAL Symbol
0026 __idata_start
0286 __idata_end
text 0286 0146 = 326. bytes (rel,con,rom)
Addr GLOBAL Symbol
0143 __start
0143 __text_start
0162 _exit
0163 _putchar
0169 _putstr
0177 _mainmenu
01CE _main
01CF push_gset1
01D2 pop_gset1
01D3 pop
01E6 __text_end
data 0060 0260 = 608. bytes (rel,con,ram)
Addr GLOBAL Symbol
0060 __data_start
02C0 __data_end
vector 0000 0002 = 2. bytes (abs,ovr,rom)
Files Linked [ MODULE(s) ]
C:\icc\lib\crtAVR.o [ crtavr.s ]
menu.o [ menu.c ]
<library> [ gpush.s ]
User GLOBAL Definitions
ram_end = 0x45f
hwstk_size = 0x10
User Base Address Definitions
func_lit = 0x26
data = 0x60
EEPROM:1.512
