#include <reg52.h>
#include<stdio.h>
#include <intrins.h>
#define uchar unsigned char
#define uint unsigned int
bit Flag;
sbit studylamp=P2^7;
sbit lamp=P2^6;
sbit studykey=P3^2;
sbit remotein=P1^1;
sbit remoteout=P1^0;
sbit txkey=P2^0;
uint i,j,m=255,n,k,s;
uchar idata remotedata[206];
int head;
uint remdata;
int temp=100;
uint ReData,SenData;
void init_chuankou()
SCON = 0x50; //REN=1允许串行接受状态,串口工作模式1
TMOD|= 0x20; //定时器工作方式2
PCON|= 0x80;
//TH1 = 0xFD; //baud*2 /* reload value 19200、数据位8、停止位1。效验位无 (11.0592)
TH1 = 0xF3; // //baud*2 /* 波特率4800、数据位8、停止位1。效验位无 (12M)
TL1 = 0xF3;
TR1 = 1;
ES = 1; //开串口中断
EA = 1; // 开总中断
//一毫秒延时程序
delay1ms(uint t)
for(i=0;i<t;i++)
for(i=0;j<120;j++);
//初始化函数
clearmen()
studylamp=1;
lamp=1;
remoteout=0;
remotein=1;
for(i=0;i<206;i++)
remotedata=0x00;
IE=0x00;
IP=0x01;
TMOD=0x22;
PCON=0X00;
TH1=0xf3;
TL1=0xf3;
IT0=1;
EX0=1;
EA=1;
//键功能函数
void key_tx()
if(txkey==0)
{delay1ms(1);
if(txkey==0)
while(txkey==0);
ET1=1;
TR1=1;
for(i=head;i>0;i--);
remoteout=0;
T1=0;
TR1=0;
n=0;
while(1)
lamp=0;
studylamp=1;
if(remotedata[n]==0x00)
delay1ms(10);
break;
for(i=remotedata[n];i>0;i--)
_nop_();_nop_();_nop_();_nop_();_nop_();
n++;
ET1=1;
TR1=1;
for(i=remotedata[n];i>0;i--);
remoteout=0;
ET1=0;
TR1=0;
n++;
ES=0;
TI=1;
puts("\n ce shi shu ju ru xia .....\n");
// printf("head is :%d\n",head); ////////////////////////////////请问这一句有什么问题啊 注释 就没有问题啦
//printf("a is shi:%d\n",temp);
while(!TI);
TI=0;
ES=1;
Flag=0;
//主函数
void main()
clearmen(); //初始化
init_chuankou();
while(1)
if(Flag==1)
ES=0;
SBUF=SenData; //SUBF接受/发送缓冲器
while(TI==0);
TI=0;
TI=1;
puts("\n hello world\n");
// printf("kai shi ce shi ....\n");
while(!TI);
TI=0;
ES=1;
Flag=0;
break;
while(1)
key_tx(); //按键扫描
//40KHz发生器?????
void time_intt1(void) interrupt 3
remoteout=~remoteout;
//外中断0
void intt0(void) interrupt 0
ET1=0;
TR1=0;
EX0=0;
EA=0;
head=0;
while(studykey==0);
studylamp=0;
lamp=1;
while(remotein==1);
head=0;
while(remotein==0)
head++;
n=0;
remdata=0x0000;
while(1)
while(remotein==1)
remdata++;
if(remdata>m) //高电平>5毫秒退出??
remotedata[n]=0x00;
EX0=1;
EA=1;
goto end;
remotedata[n]=remdata;
n++;
remdata=0x0000;
while(remotein==0)
remdata++;
n++;
remdata=0x00;
end: lamp=0;
studylamp=0;
串口中断程序
void ser_int (void) interrupt 4
// if(RI == 1) //RI接受中断标志
RI = 0; //清除RI接受中断标志
ReData = SBUF; //SUBF接受/发送缓冲器
SenData=ReData;
Flag=1;
