IDE用的是MPLab X 1.30,编译器是XC16 1.0
rtcc。c是抄例程的运行过没错,加到我的project里就出现下面的编译错误
CLEAN SUCCESSFUL (total time: 51ms)
make -f nbproject/Makefile-default.mk SUBPROJECTS= .build-conf
make[1]: Entering directory `C:/Microchip Solutions/workspace/gogo.X'
make -f nbproject/Makefile-default.mk dist/default/production/gogo.X.production.hex
make[2]: Entering directory `C:/Microchip Solutions/workspace/gogo.X'
"C:\Program Files (x86)\Microchip\xc16\v1.00\bin\xc16-gcc.exe" uart.c -o build/default/production/uart.o -c -mcpu=24F16KA102 -MMD -MF "build/default/production/uart.o.d" -g -omf=elf -mlarge-code -O0 -msmart-io=1 -Wall -msfr-warn=off
"C:\Program Files (x86)\Microchip\xc16\v1.00\bin\xc16-gcc.exe" main.c -o build/default/production/main.o -c -mcpu=24F16KA102 -MMD -MF "build/default/production/main.o.d" -g -omf=elf -mlarge-code -O0 -msmart-io=1 -Wall -msfr-warn=off
"C:\Program Files (x86)\Microchip\xc16\v1.00\bin\xc16-gcc.exe" I2C.c -o build/default/production/I2C.o -c -mcpu=24F16KA102 -MMD -MF "build/default/production/I2C.o.d" -g -omf=elf -mlarge-code -O0 -msmart-io=1 -Wall -msfr-warn=off
"C:\Program Files (x86)\Microchip\xc16\v1.00\bin\xc16-gcc.exe" rtcc.c -o build/default/production/rtcc.o -c -mcpu=24F16KA102 -MMD -MF "build/default/production/rtcc.o.d" -g -omf=elf -mlarge-code -O0 -msmart-io=1 -Wall -msfr-warn=off
"C:\Program Files (x86)\Microchip\xc16\v1.00\bin\xc16-gcc.exe" -o dist/default/production/gogo.X.production.elf build/default/production/uart.o build/default/production/main.o build/default/production/I2C.o build/default/production/rtcc.o -mcpu=24F16KA102 -omf=elf -Wl,--defsym=__MPLAB_BUILD=1,,--script=p24F16KA102.gld,--stack=16,--check-sections,--data-init,--pack-data,--handles,--isr,--no-gc-sections,--fill-upper=0,--stackguard=16,--no-force-link,--smart-io,--report-mem
Program Memory [Origin = 0x200, Length = 0x29fe]
section address length (PC units) length (bytes) (dec)
.text 0x200 0xe6 0x159 (345)
.const 0x2e6 0x7e 0xbd (189)
.text 0x364 0xa80 0xfc0 (4032)
.dinit 0xde4 0x1a 0x27 (39)
Total program memory used (bytes): 0x11fd (4605) 28%
Data Memory [Origin = 0x800, Length = 0x600]
section address alignment gaps total length (dec)
.ndata 0x800 0 0x10 (16)
.nbss 0x810 0 0x10 (16)
build/default/production/rtcc.o(.text+0x8c): In function `.LSM26':
: undefined reference to `_rtcc'
build/default/production/rtcc.o(.text+0x92): In function `.LSM27':
build/default/production/rtcc.o(.text+0x98): In function `.LSM28':
build/default/production/rtcc.o(.text+0x9e): In function `.LSM29':
build/default/production/rtcc.o(.text+0xb6): In function `.LSM34':
build/default/production/rtcc.o(.text+0xbc): more undefined references to `_rtcc' follow
Total data memory used (bytes): 0x20 (32) 2%
Dynamic Memory Usage
region address maximum length (dec)
heap 0 0 (0)
stack 0x820 0x5e0 (1504)
Maximum dynamic memory (bytes): 0x5e0 (1504)
make[2]: *** [dist/default/production/gogo.X.production.hex] Error 255
make[1]: *** [.build-conf] Error 2
make: *** [.build-impl] Error 2
make[2]: Leaving directory `C:/Microchip Solutions/workspace/gogo.X'
make[1]: Leaving directory `C:/Microchip Solutions/workspace/gogo.X'
BUILD FAILED (exit value 2, total time: 4s) |
