PK3Err0040
 楼主| caplzc 发表于 2012-9-25 21:37 | 显示全部楼层 |阅读模式
ce, vi, ic, ev, ICE
开发板可以连接上 但是一运行就报PK3Err0040 The target device is not ready for debugging. Please check your
configuration bit settings and program the device before proceeding.(目标器件
未准备好调试。请检查配置位设置并编程该器件,然后继续。)
nongfuxu 发表于 2013-3-5 15:04 | 显示全部楼层
yewuyi 发表于 2013-3-5 15:41 | 显示全部楼层
设置好正确的CONFIG,编译后下载到目标板中,然后DEBUG
