[verilog] 看到了一个Zynq基本系统
 楼主| shang651 发表于 2012-10-17 21:00 | 显示全部楼层 |阅读模式
zynq, AN, TE, ST, TI
从网站公布信息来看,Linux等OS需要在Q3,保守点应该在Q4会比较完备。
Xilinx Zynq-7000 Embedded Processing ModuleIN BETA PHASE
Apply for the Mars ZX3 Beta Program!By applying for the Mars ZX3 Beta Program, you may get the chance to be among the very first customers to receive Mars ZX3 EP module hardware. A limited number of Mars ZX3 Beta modules (MA-ZX3-20-1CES) are expected to be available for Beta Program members in September 2012. Fill in and submit the Mars ZX3 Beta Program Application Form today!
OverviewThe Mars ZX3 embedded processing module combines Xilinx’ Zynq-7000 EPP device with fast DDR3 SDRAM, NAND flash, quad SPI flash, a Gigabit Ethernet PHY and an RTC and thus forms a complete and powerful embedded processing system.
The SO-DIMM form factor allows space-saving hardware designs as well as quick and simple integration of the module into the target application.
The Mars ZX3 Embedded Processing module reduces development effort, redesign risk and improves time-to-market for your embedded system.
Highlights
  • Built around Xilinx’ Zynq-7000 Extensible Processing Platform
  • Combines the flexibility of a CPU system with the parallel processing power and real-time capabilities of an FPGA system
  • Supports analog differential inputs
  • Available in the industrial temperature range
  • Supports USB 2.0 OTG, CAN and Gigabit Ethernet
  • Linux BSP and tool chain available
Benefits
  • A complete and powerful embedded processing system in the industry-standard SO-DIMM form factor
  • Simple, low cost and yet rugged assembly
  • Simple and low-cost integration thanks to the on-board standard interfaces (USB, Ethernet, CAN)
  • Fast boot times and plenty of non-volatile memory space thanks to the NAND flash
  • High-bandwidth program and data memory thanks to the high-performance hard-macro memory controller
  • Lowest power consumption thanks to the high-efficiency DC/DC converters
Features
  • Xilinx Zynq-7000 EPP in the CLG484 package (XC7Z020)
    • ARM dual-core Cortex-A9
    • Artix-7 28nm FPGA fabric
  • SO-DIMM form factor (68 x 30 mm, 200 pins)
  • 108 user I/Os
    • ARM peripherals (SPI, SDIO, CAN, I2C, UART)
    • FPGA I/Os (single-ended, differential or analog)
  • Gigabit Ethernet and USB 2.0 OTG PHYs
  • Up to 1 GB DDR3 SDRAM
  • Up to 64 GB NAND flash
  • Single 3.3V supply voltage
Module ArchitectureClick image to enlarge
Product Selection MatrixClick image to enlarge
Minimum order quantities do apply for custom module configurations. Please contactus.
PricingClick image to enlarge
Preliminary pricing for 1.7.2013.
Operating System Support
OSDescriptionPartner
Available in Q3 2012
  • Linux 3.3
  • BSP support for DDR3 SDRAM, NAND Flash, Quad SPI Flash, USB Host and Gigabit Ethernet
  • U-boot bootloader
  • Software design services byNoser Engineering
Available in Q4 2012
  • Android 4.04
  • U-boot bootloader
  • Support for capacitive touch embedded displays
  • VxWorks 6.9
  • BSP support for DDR3 SDRAM, Quad SPI Flash, UART and Gigabit Ethernet
  • Software design services byNetModule
  • eCos 3.0
  • Software design services byAntMicro
